No called and received call history on ip phone
Sonam
I have cucm 11.5 and ip phone models: 7821, 8845 and 8851. in the recent button on ip phone call logs such as received and placed are not showing. Where as missed call log is showing correctly.  It was working a year ago but now it not.. What could cause this?
Kindly help!!
ashok_boin
Level 5
Level 5
Hi Sonam,
Pls refer to this URL.
https://community.cisco.com/t5/ip-telephony-and-phones/call-history-not-displaying-on-ip-phones-ex-missed-calls/td-p/1820518
There are lots of possible issues like firmware compatibility, DHCP server change as well as Phone configuration/device pool settings change etc.
Regards...
Ashok.
With best regards...
Ashok
Thank you Ashok,
Can you kindly give recommended solution/s for each of the possible cause you mentioned.
Thank You
What has recently changed in the cluster?
Please remember to rate useful posts, click on the stars below.
Hi Jonathan,
I remember doing no change in the cluster. I am not very sure.. Please help
