No compatible sound device - IP Communicator
HGU
Hello all,
We have received this error from time to time.
Normally the headset will recognized  from Ip Communicator.
But some times,  we will get this error massage : There are no compatible sound device installed on this computer.:"
When the user unplug the USB of the Headphone  and plug back in then it´s work again for a short time.  Then come the the massage again. Device is set as default , it´s a Jabra Headphone
Could you give me please a hint?
Advice you to stop using IP Communicator as it is past end of everything. The replacement is to use either Webex or Jabber as your calling client.
Response Signature
Yes, it's planning, but it takes a little time to get new ones.
