04-23-2012 07:05 AM - edited 03-16-2019 10:46 AM
Hi There,
We have configured Analog Ports in VG224 , It showing registered in CUCM, But there is no dial tone in FXS Ports, may i know what could be a problem?
Faxmode is: Fax Relay
Bala
04-23-2012 07:11 AM
So, when you connect analog port and you go off hook you do not hear anything? Sounds like cabling issue.
Are you sure your patching/cabling is correct? Are you using patch panel/110 block/66 block to extend the ampahol connection?
Chris
04-23-2012 07:15 AM
Hi Chris,
Yes, Cabling is fine, We used 2 more VG224 in the same LAN, It worked, This one is new VG224 which is not gving dial tone.
Bala
04-23-2012 09:58 AM
Bala,
If you are sure your wiring set up is good.
Have wee look at this link.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00805552e9.shtml
May be a DC voltage level issue
Alex
04-23-2012 02:07 PM
Are these VG224s all running the exact same version of IOS ?
GTG
