11-08-2013 12:25 PM - edited 03-16-2019 08:18 PM
I am unable to receive inbounds calls on my 1760 router from my SP provider. I can make outbound calls without a problem. I have tested this SIP account on a different router (2851 with 15.1IOS) and it works for both inbound and outbound. Therefore the SIP account is find.
I am running c1700-entservicesk9-mz.124-15.T7.bin on this router with 98MB of RAM.
Attached is my config file and below is my DEBUG CCSIP MESSAGES results. Any idea what I can do to get ibound calls to work?
PS. The 15.1 IOS has an option in the credentials command called NUMBER which is not in the 12.4 IOS. This seems to be the the problem but I amnot sure plus there may be a work-a-round.
Michael
A call was place to 925.338.1577 from 386.243.9001 and below is the debug CCSIP Messages results. My IP address is 70.209.13.4 and my SIP provider's IP address is 185.35.78.40
Nov 8 20:22:01.556: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:1000@70.209.13.4:10063;transport=tcp SIP/2.0
Max-Forwards: 20
Via: SIP/2.0/TCP 185.35.78.40:5070;alias;rport;branch=z9hG4bK2111436929
From: "LAKE CITY FL" <sip:13862439001@185.35.78.40>;tag=627859077
To: <sip:1000@70.209.13.4:10063;transport=tcp>
Call-ID: 1074458783@185.35.78.40
CSeq: 11584 INVITE
User-Agent: GVGW
Contact: <sip:13862439001@185.35.78.40:5070>
Allow: ACK, INVITE, BYE, CANCEL, REGISTER, REFER, OPTIONS, INFO, MESSAGE
Content-Type: application/sdp
Content-Length: 206
v=0
o=yate 1383942121 1383942121 IN IP4 185.35.78.40
s=SIP Call
c=IN IP4 185.35.78.40
t=0 0
m=audio 23436 RTP/AVP 0 3 101
a=rtpmap:0 PCMU/8000
a=rtpmap:3 GSM/8000
a=rtpmap:101 telephone-event/8000
Nov 8 20:22:01.572: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 400 Bad Request - 'Invalid Host'
To: <sip:1000@70.209.13.4:10063;transport=tcp>;tag=75DD4A-900
Date: Fri, 08 Nov 2013 20:22:01 GMT
Server: Cisco-SIPGateway/IOS-12.x
CSeq: 11584 INVITE
Allow-Events: telephone-event
Reason: Q.850;cause=100
Content-Length: 0
Nov 8 20:22:01.672: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:1000@70.209.13.4:10063;transport=tcp SIP/2.0
CSeq: 11584 ACK
Max-Forwards: 20
User-Agent: GVGW
Content-Length: 0
11-08-2013 02:08 PM
It looks like 70.209.13.4 is sending an invite to 1000.
70.209.13.4 is not understanding what 1000 is. You may need an outgoing translation rule to replace 1000 with your sip ID.
Otherwise add your sip ID as a secondary number to your ephone-dn
ephone-dn 100
number 100 secondary SIPID no-reg primary
I am still trying to figure out where I have gone wrong as well, as my incoming is not working either without adding the SIPID as a secondary number on my ephone-dn. I have a thread in this forum as well.
I do notice there are a few other discrepencies in your config that may/may not be relavant such as your register server under voice service voip and I believe your realm under sip-ua should have the domain portion.
Hope this all helps. Have a read through if you have not already:
11-08-2013 03:34 PM
Evan, Thanks for the response but the problem is with inbound not outbound. The 1000@70.209.13.4 is coming from my SIP provider it should be 9253381577@70.209.13.4 but its not and I have no idea why its doing that.
If the sip-ua had the credentials number option I am sure it would work.
11-09-2013 10:09 AM
Could the problem be from the Invalid Host error above? IOS 12.4 does not have a Voice Service Voip -> IP Address Trusted List option like IOS 15.1 does. is there a work-a-round for this?
11-11-2013 02:54 PM
I spoke with my SIP provider about this problem and here is his reply:
The '1000' username would come from the GVGW if that's the username your router registered with. In other words, when you register, you are telling the gateway, "send me calls at user XXXX and ip address 1.2.3.4 and port 5060" (for example). Essentially you are registering a SIP URI of XXXX@1.2.3.4:5060 at which you want to be contacted
Somehow my 1st extension is telling my SIP provider my numenr is 1000 not 9253381577.
Therefore the question becomes; how do I tell the SIP provider my number is 9253381577? What command in CME 4.1 does that?
11-11-2013 06:10 PM
what is the output of show sip-ua register status?
11-12-2013 12:29 PM
Here are the resuslts you aked for:
Router#sh sip-ua register stat
Router#sh sip-ua register status
Line peer expires(sec) registered
1001 20002 16 yes
1020 400 40 yes
1021 401 53 yes
9253381577 20001 54 yes
GV1925338157 -1 17 yes
I played around with the ephone-dn 1 and changed the number from 1000 to 9253381577 and the secondary number to 9253381577. Stil no inbound ringing at the IP phone but the debug ccsip messages no show the inbound number at 9253381577. But again, the phone still does not ring.
Also, I did remove the voice translation-rule 1 and also removed that from the dial-peer. We are so close yet so far.
I noticed that in the debug ccsip messages it shows UNAUTHORIZED. Any idea why? Alsom why are all of my extensions trying to register with my SIP provider? I just need the one niumber to register. 9253381577.
I do have a working 2851 running 15.1 IOS with the same SIP provider should you need me to provide any known working debug results.
debvug ccsip messages:
REGISTER sip:gvgw8.simonics.com:5070 SIP/2.0
Via: SIP/2.0/TCP 192.168.69.200:5060;branch=z9hG4bK27ACF1C
To: <>>1001@gvgw8.simonics.com>
Date: Tue, 12 Nov 2013 19:30:59 GMT
Call-ID: 2B81EA0C-2BDE11D6-8006A600-8D78358E
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
Timestamp: 1384284659
CSeq: 2031 REGISTER
Contact: <1001>1001>
Expires: 300
Content-Length: 0
Nov 12 19:30:59.513: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/TCP 192.168.69.200:5060;branch=z9hG4bK27ACF1C;received=70.209.13.4
CSeq: 2031 REGISTER
Server: GVGW
Content-Length: 0
Nov 12 19:30:59.789: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 401 Unauthorized
CSeq: 2031 REGISTER
WWW-Authenticate: Digest realm="GVGW", nonce="79dda79baea82bdad31f12da375cb36d.1384284659", stale=FALSE, algorithm=MD5
Server: GVGW
Content-Length: 0
Nov 12 19:30:59.797: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/TCP 192.168.69.200:5060;branch=z9hG4bK27AD346
Max-Forwards: 70
CSeq: 2032 REGISTER
Expires: 300
Authorization: Digest username="GV19253381577",realm="GVGW",uri="sip:gvgw8.simonics.com:5070",response="a8210e3015f5ae53016e37f350ead862",nonce="79dda79baea82bdad31f12da375cb36d.1384284659",algorithm=MD5
Content-Length: 0
Nov 12 19:30:59.925: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/TCP 192.168.69.200:5060;branch=z9hG4bK27AD346;received=70.209.13.4
CSeq: 2032 REGISTER
Server: GVGW
Content-Length: 0
Nov 12 19:31:00.214: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
To: <>>1001@gvgw8.simonics.com>;tag=659892092
CSeq: 2032 REGISTER
Expires: 300
Contact: <1001>;expires=3001001>
P-NAT-Refresh: 25
X-Real-Contact: sip:1001@70.209.13.4:10438;transport=tcp
Server: GVGW
Content-Length: 0
Nov 12 19:31:00.727: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/TCP 192.168.69.200:5060;branch=z9hG4bK27AE458
From: <>>GV19253381577@gvgw8.simonics.com>;tag=F8DA638-C27
To: <>>GV19253381577@gvgw8.simonics.com>
Date: Tue, 12 Nov 2013 19:31:00 GMT
Call-ID: 2B330DCE-2BDE11D6-8004A600-8D78358E
Max-Forwards: 70
Timestamp: 1384284660
CSeq: 2032 REGISTER
Contact:
Expires: 300
Content-Length: 0
Nov 12 19:31:00.835: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/TCP 192.168.69.200:5060;branch=z9hG4bK27AE458;received=70.209.13.4
CSeq: 2032 REGISTER
Server: GVGW
Content-Length: 0
Nov 12 19:31:01.107: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 2032 REGISTER
WWW-Authenticate: Digest realm="GVGW", nonce="959010c50d483214551f0be14ad11c31.1384284660", stale=FALSE, algorithm=MD5
Server: GVGW
Content-Length: 0
Nov 12 19:31:01.115: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/TCP 192.168.69.200:5060;branch=z9hG4bK27AF1215
Date: Tue, 12 Nov 2013 19:31:01 GMT
Max-Forwards: 70
Timestamp: 1384284661
CSeq: 2033 REGISTER
Contact:
Expires: 300
Authorization: Digest username="GV19253381577",realm="GVGW",uri="sip:gvgw8.simonics.com:5070",response="fb395a97461a2862247e49b4470d2aea",nonce="959010c50d483214551f0be14ad11c31.1384284660",algorithm=MD5
Content-Length: 0
Nov 12 19:31:01.219: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/TCP 192.168.69.200:5060;branch=z9hG4bK27AF1215;received=70.209.13.4
CSeq: 2033 REGISTER
Server: GVGW
Content-Length: 0
Nov 12 19:31:01.288: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
To: <>>GV19253381577@gvgw8.simonics.com>;tag=876590097
CSeq: 2033 REGISTER
Expires: 300
Contact:
P-NAT-Refresh: 25
X-Real-Contact: sip:GV19253381577@70.209.13.4:10438;transport=tcp
Server: GVGW
Content-Length: 0
Nov 12 19:31:01.324: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:GV19253381577@70.209.13.4:10438;transport=tcp SIP/2.0
Max-Forwards: 20
Via: SIP/2.0/TCP 185.35.78.40:5070;alias;rport;branch=z9hG4bK1807861277
From: "LAKE CITY FL" <13862439001>;tag=50068341013862439001>
To:
Call-ID: 39478491@185.35.78.40
CSeq: 15904 INVITE
User-Agent: GVGW
Contact: <13862439001>13862439001>
Content-Length: 206
v=0
o=yate 1384284661 1384284661 IN IP4 185.35.78.40
s=SIP Call
t=0 0
m=audio 21864 RTP/AVP 0 3 101
a=rtpmap:3 GSM/8000
Nov 12 19:31:01.340: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To:
CSeq: 15904 INVITE
Content-Length: 0
Nov 12 19:31:01.448: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:GV19253381577@70.209.13.4:10438;transport=tcp SIP/2.0
To:
CSeq: 15904 ACK
Max-Forwards: 20
User-Agent: GVGW
Content-Length: 0
Router#
Nov 12 19:31:22.896: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/TCP 192.168.69.200:5060;branch=z9hG4bK27B01AA9
To: <>>1020@gvgw8.simonics.com>
Date: Tue, 12 Nov 2013 19:31:22 GMT
Call-ID: 2B1A97D5-2BDE11D6-8002A600-8D78358E
Max-Forwards: 70
Timestamp: 1384284682
CSeq: 2032 REGISTER
Contact: <1020>1020>
Expires: 300
Content-Length: 0
Nov 12 19:31:23.044: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/TCP 192.168.69.200:5060;branch=z9hG4bK27B01AA9;received=70.209.13.4
CSeq: 2032 REGISTER
Server: GVGW
Content-Length: 0
Nov 12 19:31:23.328: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 2032 REGISTER
WWW-Authenticate: Digest realm="GVGW", nonce="3206ad87bfb7a90fe9f0cc5176c8d119.1384284682", stale=FALSE, algorithm=MD5
Server: GVGW
Content-Length: 0
Nov 12 19:31:23.336: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/TCP 192.168.69.200:5060;branch=z9hG4bK27B114D4
Date: Tue, 12 Nov 2013 19:31:23 GMT
Max-Forwards: 70
Timestamp: 1384284683
CSeq: 2033 REGISTER
Expires: 300
Authorization: Digest username="GV19253381577",realm="GVGW",uri="sip:gvgw8.simonics.com:5070",response="954471c3fd0bd522266d75be7eb5ecf4",nonce="3206ad87bfb7a90fe9f0cc5176c8d119.1384284682",algorithm=MD5
Content-Length: 0
Nov 12 19:31:23.448: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/TCP 192.168.69.200:5060;branch=z9hG4bK27B114D4;received=70.209.13.4
CSeq: 2033 REGISTER
Server: GVGW
Content-Length: 0
Nov 12 19:31:23.729: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
To: <>>1020@gvgw8.simonics.com>;tag=714685352
CSeq: 2033 REGISTER
Expires: 300
Contact: <1020>;expires=3001020>
P-NAT-Refresh: 25
X-Real-Contact: sip:1020@70.209.13.4:10438;transport=tcp
Server: GVGW
Content-Length: 0
Nov 12 19:31:36.029: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/TCP 192.168.69.200:5060;branch=z9hG4bK27B2C79
To: <>>1021@gvgw8.simonics.com>
Date: Tue, 12 Nov 2013 19:31:36 GMT
Call-ID: 2B29E219-2BDE11D6-8003A600-8D78358E
Max-Forwards: 70
Timestamp: 1384284696
CSeq: 2032 REGISTER
Contact: <1021>1021>
Expires: 300
Content-Length: 0
Nov 12 19:31:36.182: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/TCP 192.168.69.200:5060;branch=z9hG4bK27B2C79;received=70.209.13.4
CSeq: 2032 REGISTER
Server: GVGW
Content-Length: 0
Nov 12 19:31:36.458: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 2032 REGISTER
WWW-Authenticate: Digest realm="GVGW", nonce="e2d4f397c80eccfbd1ed8e0690ba35c8.1384284696", stale=FALSE, algorithm=MD5
Server: GVGW
Content-Length: 0
Nov 12 19:31:36.466: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/TCP 192.168.69.200:5060;branch=z9hG4bK27B316ED
Max-Forwards: 70
CSeq: 2033 REGISTER
Expires: 300
Authorization: Digest username="GV19253381577",realm="GVGW",uri="sip:gvgw8.simonics.com:5070",response="03978a03cca061bdb48165ceb93d90d0",nonce="e2d4f397c80eccfbd1ed8e0690ba35c8.1384284696",algorithm=MD5
Content-Length: 0
Nov 12 19:31:36.554: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/TCP 192.168.69.200:5060;branch=z9hG4bK27B316ED;received=70.209.13.4
CSeq: 2033 REGISTER
Server: GVGW
Content-Length: 0
Nov 12 19:31:36.843: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
To: <>>1021@gvgw8.simonics.com>;tag=504264205
CSeq: 2033 REGISTER
Expires: 300
Contact: <1021>;expires=3001021>
P-NAT-Refresh: 25
X-Real-Contact: sip:1021@70.209.13.4:10438;transport=tcp
Server: GVGW
Content-Length: 0
Nov 12 19:31:37.123: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/TCP 192.168.69.200:5060;branch=z9hG4bK27B4124F
From: <>>9253381577@gvgw8.simonics.com>;tag=F8E3464-167F
To: <>>9253381577@gvgw8.simonics.com>
Date: Tue, 12 Nov 2013 19:31:37 GMT
Call-ID: 7F953882-4A5B11E3- 8007A600-8D78358E
Max-Forwards: 70
Timestamp: 1384284697
CSeq: 618 REGISTER
Contact: <9253381577>9253381577>
Expires: 300
Content-Length: 0
Nov 12 19:31:37.247: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/TCP 192.168.69.200:5060;branch=z9hG4bK27B4124F;received=70.209.13.4
Call-ID: 7F953882-4A5B11E3-8007A600-8D78358E
CSeq: 618 REGISTER
Server: GVGW
Content-Length: 0
Nov 12 19:31:37.528: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 618 REGISTER
WWW-Authenticate: Digest realm="GVGW", nonce="b9c8c1e129b3d47d46b76a36cd842114.1384284697", stale=FALSE, algorithm=MD5
Server: GVGW
Content-Length: 0
Nov 12 19:31:37.540: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/TCP 192.168.69.200:5060;branch=z9hG4bK27B5A20
Max-Forwards: 70
CSeq: 619 REGISTER
Expires: 300
Authorization: Digest username="GV19253381577",realm="GVGW",uri="sip:gvgw8.simonics.com:5070",response="24da9d08bb3933a3d084fbe62c97739d",nonce="b9c8c1e129b3d47d46b76a36cd842114.1384284697",algorithm=MD5
Content-Length: 0
Nov 12 19:31:37.644: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/TCP 192.168.69.200:5060;branch=z9hG4bK27B5A20;received=70.209.13.4
CSeq: 619 REGISTER
Server: GVGW
Content-Length: 0
Nov 12 19:31:37.744: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
To: <>>9253381577@gvgw8.simonics.com>;tag=2067908552
CSeq: 619 REGISTER
Expires: 300
Contact: <9253381577>;expires=3009253381577>
P-NAT-Refresh: 25
X-Real-Contact: sip:9253381577@70.209.13.4:10438;transport=tcp
Server: GVGW
Content-Length: 0
11-12-2013 06:17 PM
Michael,
I notice your incoming dial peer would not match the number your ITSP is sending you. The dot only matches any 1 digit. Try removing that and replacing it with the SIP number.
dial-peer voice 200 voip
description *** Incoming Calls VoIP ***
translation-profile incoming Incoming_calls
preference 1
voice-class codec 1
session protocol sipv2
session target sip-server
incoming called-number .
dtmf-relay rtp-nte
no vad
Also add "no-reg both" to your ephone-dn's to prevent them from trying to register to the sip provider.
Please post show sip-ua register status and debug from incoming call. If you have a working incoming call example from your other router, please post that as well as the config. Having a working debug/config to compare to usually helps.
11-12-2013 07:01 PM
Here is the current dial-peer:
preference 1
voice-class codec 1
incoming called-number 9253381577
dtmf-relay rtp-nte
no vad
Still no ringing the phone on incoming calls.
There is no command no-reg both in this version of the IOS.
Here is a current debug ccsip messages on the 12.4 IOS router:
Nov 13 02:44:29.785: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 20
Via: SIP/2.0/TCP 185.35.78.40:5070;alias;rport;branch=z9hG4bK892538993
From: "LAKE CITY FL" <13862439001>;tag=191326469813862439001>
To:
Call-ID: 428928807@185.35.78.40
CSeq: 16604 INVITE
User-Agent: GVGW
Content-Length: 206
v=0
o=yate 1384310669 1384310669 IN IP4 185.35.78.40
s=SIP Call
t=0 0
m=audio 24302 RTP/AVP 0 3 101
a=rtpmap:3 GSM/8000
Nov 13 02:44:29.797: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To:
Date: Wed, 13 Nov 2013 02:44:29 GMT
CSeq: 16604 INVITE
Content-Length: 0
Nov 13 02:44:29.881: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To:
CSeq: 16604 ACK
Max-Forwards: 20
User-Agent: GVGW
Content-Length: 0
I see an error called INVALID HOST. I once had this in the 15.1 IOS and there is a command called voice service voip where you enter an IP in the IP trusted list list. But that option is also not in 12.4. I think my system does not see the SIP provider as a valid host and thus blocks it. Somehow we need to tell my router to trust my SIP porivder... but how?
WORKING debug ccsip debug during an inbound call on my 15.1 IOS router:
000490: 2d01h: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:3862439001@70.209.13.4:10432;transport=tcp SIP/2.0
Max-Forwards: 20
Via: SIP/2.0/TCP 185.35.78.39:5070;alias;rport;branch=z9hG4bK1473277297
From: "MICHAEL DURHAM" <13525381577>;tag=72252908213525381577>
To: <3862439001>3862439001>
Call-ID: 1115096104@185.35.78.39
CSeq: 52502 INVITE
User-Agent: GVGW
Contact: <13525381577>13525381577>
Content-Length: 206
v=0
o=yate 1384311551 1384311551 IN IP4 185.35.78.39
s=SIP Call
c=IN IP4 185.35.78.39
t=0 0
m=audio 27628 RTP/AVP 0 3 101
a=rtpmap:3 GSM/8000
000491: 2d01h: //7304/67DF2CF481EA/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Wed, 13 Nov 2013 02:59:11 GMT
CSeq: 52502 INVITE
Content-Length: 0
000492: 2d01h: //7304/67DF2CF481EA/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To: <3862439001>;tag=AB243C0-E2F3862439001>
CSeq: 52502 INVITE
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Remote-Party-ID: <1000>;party=called;scre1000>
CME_Router#en=no;privacy=off
Contact: <3862439001>3862439001>
Content-Length: 0
CME_Router#u a
000493: 2d01h: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CANCEL sip:3862439001@70.209.13.4:10432;transport=tcp SIP/2.0
CSeq: 52502 CANCEL
User-Agent: GVGW
Max-Forwards: 70
Content-Length: 0
000494: Nov 12 2013 21:59:18.704: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId 67DF2CF44B4611E381EA88E5BB4D28BD, SetupTime 21:59:11.390 Eastern Tue Nov 12 2013, PeerAddress 1000, PeerSubAddress , DisconnectCause 10 , DisconnectText normal call clearing (16), ConnectTime 21:59:18.704 Eastern Tue Nov 12 2013, DisconnectTime 21:59:18.704 Eastern Tue Nov 12 2013, CallOrigin 1, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
000495: Nov 12 2013 21:59:18.704: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:11/12/2013 21:59:11.384,cgn:13525381577,cdn:1000,frs:0,fid:182,fcid:67DF2CF44B4611E381EA88E5BB4D28BD,legID:1C89,bguid:67DF2CF44B4611E381EA88E5BB4D28BD
000496: 2d01h: //7304/67DF2CF481EA/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Wed, 13 Nov 2013 02:59:18 GMT
CSeq: 52502 CANCEL
Content-Length: 0
000497: 2d01h: //7304/67DF2CF481EA/SIP/Msg/ccsipDisplayMsg:
Sent:
CME_Router#u all
All possible debugging has been turned off
CME_Router#SIP/2.0 487 Request Cancelled
CSeq: 52502 INVITE
Reason: Q.850;cause=16
Content-Length: 0
000498: 2d01h: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:3862439001@70.209.13.4:10432;transport=tcp SIP/2.0
Reason: SIP;text="Request Terminated"
Via: SIP/2.0/TCP 185.35.78.39:5070;alias;rport;branch=z9hG4bK1031829754
CSeq: 52503 BYE
User-Agent: GVGW
Max-Forwards: 70
Content-Length: 0
000499: 2d01h: //7304/67DF2CF481EA/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 52503 BYE
P-RTP-Stat: PS=0,OS=0,PR=0,OR=0,PL=0,JI=0,LA=0,DU=179462
Content-Length: 0
000500: 2d01h: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:3862439001@70.209.13.4:10432;transport=tcp SIP/2.0
CSeq: 52502 ACK
Max-Forwards: 20
User-Agent: GVGW
Content-Length: 0
000501: Nov 12 2013 21:59:18.848: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 2, ConnectionId 67DF2CF44B4611E381EA88E5BB4D28BD, SetupTime 21:59:11.378 Eastern Tue Nov 12 2013, PeerAddress 13525381577, PeerSubAddress , DisconnectCause 10 , DisconnectText normal call clearing (16), ConnectTime 21:59:18.848 Eastern Tue Nov 12 2013, DisconnectTime 21:59:18.848 Eastern Tue Nov 12 2013, CallOrigin 2, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
CME_Router#
000502: Nov 12 2013 21:59:18.848: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:11/12/2013 21:59:11.376,cgn:13525381577,cdn:3862439001,frs:0,fid:181,fcid:67DF2CF44B4611E381EA88E5BB4D28BD,legID:1C88,bguid:67DF2CF44B4611E381EA88E5BB4D28BD
CME_Router#
11-12-2013 08:58 PM
Here is what I am thinking (keep in mind I am no sip expert)
I see the invite for your non working router
and then the working router
I interpret this debug as your provider basically saying it does not understand "GV19253381577" it is looking for something like sip:3862439001.
Under sip-ua try to change to:
authentication username 9253381577 password
One other thing to note is IP trusted list is an added feature to prevent toll fraud. It should not prevent you from sucess, just acts as an added layer of security.
Evan
11-13-2013 10:37 AM
I see you point about the INVITE info and that make a lot of sence. I tried you suggestion but Authentication is for outbound calls. I did try changing the username in the Credentiuals (which is for inbound calls) but my sit provider rejects me now.
The NUMBER option was added in 15.0(1)XA for the following reason:
The number keyword and number argument were added and the username keyword and username argument reintroduced to configure credentials for a given registrar when multiple registrars are configured
I also found a way to modify the sip invite information but sip profiles is in a new version of IOS 12.4 than I have.
I am stumped.
