No IP Address via DHCP for 7940
cmattogno
I have read quite a few discussions regarding no DHCP for these phones, but none of the fixes have worked for me, so here goes...
We are changing from an ATM based network to a straight IP based one. I have set up what I can for a lab to test things. However, due to facilities limitiations I am not able to set up a lab with easy access to the CallManager Publisher, just a subscriber.
My problem:
Phones (and computers) at Site 1 (Quality Hill) get IP addresses and boot fine. Computers a Site 2 (Mule Mountain) get addresses fine, but the phones do not boot, or get IP addresses. I have been banging my head for over a week, and I am totally stumped. Hopefully I just need a second set of eyes on the issue.
Thank you all in advance.
My setup:
Site 1 (Quality Hill):
7206 VXR IOS 12.4 Adv IP Services
Cat3560 PoE (12.2)
CallManager (Subscriber) 4.1(3)sr8a
IP Phone 7940g (and non-g)
DHCP server (MS 2k3)
Site 2 (Mule Mountain):
7206 VXR IOS 12.4
Cat3560 -not PoE(12.2)
| Site 1 (Quality Hill) |
--> Router:
BCurrent configuration : 31843 bytes
! No configuration change since last restart
upgrade fpd auto
upgrade fpd path disk2:
version 12.4
no service pad
service timestamps log datetime localtime
service sequence-numbers
no service dhcp
hostname QH-NOC-7206
boot-start-marker
boot system flash disk2:c7200-advipservicesk9-mz.124-24.T2.bin
boot bootldr bootflash:c7200-boot-mz.124-24.T2.bin
boot-end-marker
card type t3 1
card type t1 4
logging message-counter syslog
no logging console
enable secret 5 xxxxxxxxxxxxxxxxxxx
enable password 7 xxxxxxxxxxxxxxxx
aaa new-model
aaa authentication login default group tacacs+ enable
aaa authorization exec default group tacacs+ if-authenticated
aaa authorization network default group tacacs+ if-authenticated
aaa accounting exec default
action-type stop-only
group tacacs+
aaa accounting commands 15 default
group tacacs+
aaa session-id common
clock timezone AZ -7
clock calendar-valid
dspint DSPfarm4/0
ip source-route
ip cef
no ip dhcp conflict logging
ip domain name cochise.gov
ip name-server 10.10.0.1
ip multicast-routing
no ipv6 cef
isdn switch-type primary-5ess
voice call send-alert
voice rtp send-recv
voice class h323 1
h225 timeout tcp establish 5
--snip crypto key--
call-history-mib retain-timer 500
call-history-mib max-size 500
archive
log config
hidekeys
controller T1 4/0
cablelength short 110
pri-group timeslots 1-24
description Voice Trunk to PSTN
controller T1 4/1
shutdown
cablelength long 0db
ip ftp username cisco
ip ftp password cisco
class-map match-all video
match access-group 101
policy-map video-police
class video
priority 480
class class-default
fair-queue 64
interface Loopback0
ip address 10.0.0.1 255.255.255.252
no ip route-cache cef
no ip route-cache
interface GigabitEthernet0/1
description - QUALITY HILL CAMPUS
ip address 10.10.252.1 255.255.252.0
ip pim sparse-dense-mode
no ip route-cache
no ip mroute-cache
load-interval 30
duplex auto
speed auto
media-type rj45
no negotiation auto
ntp broadcast
interface GigabitEthernet0/1.50
description - ACCESS TO WIC SERVER
encapsulation dot1Q 50
ip address 192.168.11.1 255.255.255.224
no ip route-cache
no ip mroute-cache
interface GigabitEthernet0/1.100
description - INFORMATION TECHNOLOGIES SERVER FARM
encapsulation dot1Q 100
ip address 10.10.3.254 255.255.252.0
ip helper-address 10.10.0.1
no ip route-cache
no ip mroute-cache
interface GigabitEthernet0/1.101
description - DISTRIBUTION TO ADMINISTRATION
encapsulation dot1Q 101
ip address 10.10.7.254 255.255.252.0
no ip route-cache
no ip mroute-cache
interface GigabitEthernet0/1.102
description - DISTRIBUTION TO ANNEX
encapsulation dot1Q 102
ip address 10.10.11.254 255.255.252.0
no ip route-cache
no ip mroute-cache
interface GigabitEthernet0/1.103
description - DISTRIBUTION TO SUPERIOR COURT
encapsulation dot1Q 103
ip address 10.10.15.254 255.255.252.0
no ip route-cache
no ip mroute-cache
interface GigabitEthernet0/1.104
description - DISTRIBUTION TO OLD HIGHSCHOOL
encapsulation dot1Q 104
ip address 10.10.19.254 255.255.252.0
no ip route-cache
no ip mroute-cache
interface GigabitEthernet0/1.105
description - DISTRIBUTION TO INFORMATION TECHNOLOGIES
encapsulation dot1Q 105
ip address 10.10.23.254 255.255.252.0
no ip route-cache
no ip mroute-cache
interface GigabitEthernet0/1.150
description - VOICE VLAN 150 SERVER FARM
encapsulation dot1Q 150
ip address 10.15.3.254 255.255.252.0
no ip route-cache
no ip mroute-cache
interface GigabitEthernet0/1.151
description - VOICE VLAN 151 ADMINISTRATION
encapsulation dot1Q 151
ip address 10.15.7.254 255.255.252.0
no ip route-cache
no ip mroute-cache
interface GigabitEthernet0/1.152
description - VOICE VLAN 152 ANNEX
encapsulation dot1Q 152
ip address 10.15.11.254 255.255.252.0
no ip route-cache
no ip mroute-cache
interface GigabitEthernet0/1.153
description - VOICE VLAN 153 SUPERIOR COURT
encapsulation dot1Q 153
ip address 10.15.15.254 255.255.252.0
no ip route-cache
no ip mroute-cache
interface GigabitEthernet0/1.154
description - VOICE VLAN 154 OLD HIGH SCHOOL
encapsulation dot1Q 154
ip address 10.15.19.254 255.255.252.0
no ip route-cache
no ip mroute-cache
interface GigabitEthernet0/1.155
description - VOICE VLAN 155 ITS
encapsulation dot1Q 155
ip address 10.15.23.254 255.255.252.0
no ip route-cache
no ip mroute-cache
interface GigabitEthernet0/2
no ip address
no ip route-cache
shutdown
duplex auto
speed auto
media-type rj45
no negotiation auto
interface GigabitEthernet0/3
ip address 192.168.123.1 255.255.255.252
no ip route-cache
duplex auto
speed auto
media-type rj45
no negotiation auto
interface Serial4/0:23
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
interface Serial1/0
ip address 10.0.10.1 255.255.255.252
no dsu remote accept
dsu bandwidth 44210
framing c-bit
cablelength 10
clock source internal
ip forward-protocol nd
no ip forward-protocol udp tftp
no ip forward-protocol udp domain
no ip forward-protocol udp time
no ip forward-protocol udp netbios-ns
no ip forward-protocol udp netbios-dgm
no ip forward-protocol udp tacacs
ip route 0.0.0.0 0.0.0.0 10.10.3.253
ip route 10.0.0.0 255.255.0.0 10.0.10.2
ip route 10.3.0.26 255.255.255.255 10.10.0.25
ip route 10.20.0.0 255.255.0.0 10.0.10.2
ip route 10.25.0.0 255.255.0.0 10.0.10.2
ip route 10.30.0.0 255.255.0.0 10.0.10.2
ip route 10.35.0.0 255.255.0.0 10.0.10.2
ip route 10.40.0.0 255.255.0.0 10.0.10.2
ip route 10.45.0.0 255.255.0.0 10.0.10.2
ip route 10.50.0.0 255.255.0.0 10.0.10.2
ip route 10.55.0.0 255.255.0.0 10.0.10.2
ip route 10.60.0.0 255.255.0.0 10.0.10.2
ip route 10.65.0.0 255.255.0.0 10.0.10.2
ip route 10.70.1.0 255.255.255.0 10.10.0.25
ip route 10.70.21.0 255.255.255.0 10.10.3.253
ip route 10.71.9.128 255.255.255.224 10.10.3.253
ip route 10.71.9.160 255.255.255.224 10.10.3.253
ip route 10.71.9.192 255.255.255.224 10.10.3.253
ip route 10.71.10.0 255.255.255.224 10.10.3.253
ip route 10.71.11.160 255.255.255.224 10.10.3.253
ip route 10.71.14.0 255.255.255.192 10.10.3.253
ip route 10.71.14.64 255.255.255.192 10.10.3.253
ip route 10.71.15.0 255.255.255.192 10.10.3.253
ip route 10.71.16.0 255.255.255.192 10.10.3.253
ip route 10.71.21.0 255.255.255.0 10.10.3.253
ip route 10.71.24.0 255.255.255.0 10.10.3.253
ip route 10.80.0.0 255.255.0.0 10.0.10.2
ip route 10.85.0.0 255.255.0.0 10.0.10.2
ip route 10.92.1.0 255.255.255.0 10.10.0.25
ip route 10.100.0.0 255.255.0.0 10.0.10.2
ip route 10.110.0.0 255.255.0.0 10.0.10.2
ip route 10.200.0.0 255.255.255.0 10.10.0.25
ip route 10.200.1.0 255.255.255.0 10.10.0.25
ip route 10.200.2.0 255.255.255.0 10.10.0.25
ip route 10.200.3.0 255.255.255.0 10.10.0.25
ip route 10.200.4.0 255.255.255.0 10.10.0.25
ip route 10.200.5.0 255.255.255.0 10.10.0.25
ip route 159.36.64.0 255.255.255.0 192.168.11.2
ip route 159.36.134.0 255.255.255.0 192.168.11.2
ip route 159.36.249.0 255.255.255.0 192.168.11.2
ip route 159.36.250.0 255.255.255.0 192.168.11.2
ip route 159.87.59.0 255.255.255.0 10.10.3.253
ip route 159.87.70.0 255.255.255.0 10.10.3.253
ip route 159.87.250.0 255.255.255.0 10.10.3.253
ip route 166.89.199.176 255.255.255.240 10.10.0.25
ip route 172.16.1.0 255.255.255.0 10.10.3.253
ip route 172.27.72.27 255.255.255.255 10.10.0.30
ip route 192.168.96.0 255.255.255.0 10.10.3.253
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 600 life 86400 requests 10000
ip pim rp-address 10.30.252.1
ip access-list extended Inside-Outbound
remark Block NBT
deny tcp any any range 137 139
deny udp any any range netbios-ns netbios-ss
permit ip any any
ip access-list extended outside-inbound-des
remark block NBT from DES
remark Allow Inbound Traffic From DES
permit tcp host 192.168.10.1 eq 23027 any
permit tcp host 192.168.10.2 any eq lpd
deny ip any any
ip access-list extended outside-inbound-wic
remark Block NBT From WIC
remark permit Traffic From WIC Server
permit tcp host 159.36.64.194 any established
deny ip any any
logging trap debugging
logging 10.10.20.35
logging 10.10.252.1
access-list 101 permit tcp any any range 3230 3231
access-list 101 permit udp any any range 3230 3235
snmp-server engineID local 00000009020000027ED5C400
snmp-server community pessimist RO
snmp-server community Opt!m!st RW
snmp-server packetsize 2048
snmp-server location Information Technologies, Quality Hill
snmp-server contact neteng@co.cochise.az.us
snmp-server chassis-id 72712940
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps tty
snmp-server enable traps envmon
snmp-server enable traps isdn call-information
snmp-server enable traps isdn layer2
snmp-server enable traps isdn chan-not-avail
snmp-server enable traps config
snmp-server enable traps dial
snmp-server enable traps entity
snmp-server enable traps frame-relay multilink bundle-mismatch
snmp-server enable traps frame-relay subif
snmp-server enable traps hsrp
snmp-server enable traps ipmulticast
snmp-server enable traps msdp
snmp-server enable traps rsvp
snmp-server enable traps ipsla
snmp-server enable traps syslog
snmp-server host 10.10.0.19 pessimist
snmp-server host 10.10.0.70 pessimist
tacacs-server host 10.30.0.28
tacacs-server directed-request
tacacs-server key 0pt!m!st
control-plane
voice-port 4/0:23
echo-cancel coverage 32
bearer-cap Speech
mgcp fax t38 ecm
dial-peer cor custom
-- snip --
gatekeeper
shutdown
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
privilege level 15
password 7 xxxxxxxxxxxxxxxxxxx
line vty 5 15
ntp update-calendar
end
---> Switch
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname QH-ITS-3548
no logging console
enable secret 5 $1$xxxxx$xxxxx
enable password 7 xxxxxxxxxxxxxxxxx
aaa new-model
aaa authentication login web group tacacs+ enable
aaa authorization exec web group tacacs+ if-authenticated
aaa accounting exec default stop-only group tacacs+
aaa accounting commands 15 default stop-only group tacacs+
ip subnet-zero
ip routing
ip domain-name cochise.gov
no file verify auto
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
vlan internal allocation policy ascending
interface FastEthernet0/1
description - TRUNK TO 7206
switchport trunk native vlan 400
switchport mode trunk
switchport voice vlan 451
load-interval 30
duplex full
speed 100
spanning-tree portfast
interface FastEthernet0/2
switchport trunk native vlan 105
switchport voice vlan 155
duplex full
speed 100
-- snip  -- all the same --
description - TRUNK TO ADMIN
description TRUNK TO QH-ITS-3750
shutdown
interface Vlan1
ip address 10.10.252.2 255.255.252.0
no ip mroute-cache
ip default-gateway 10.10.252.1
ip classless
ip http server
ip http authentication aaa login-authentication web
ip http authentication aaa exec-authorization web
logging 10.30.0.28
logging 10.10.0.5
snmp-server engineID local 00000009020000027D713580
snmp-server chassis-id FAA0429J007
snmp-server enable traps cluster
snmp-server enable traps vtp
snmp-server enable traps stpx root-inconsistency loop-inconsistency
snmp-server enable traps vlan-membership
snmp-server host 10.10.0.5 pessimist
snmp-server host 10.10.0.6 pessimist
tacacs-server key 7 1447021F4D096B3830
radius-server source-ports 1645-1646
control-plane
banner motd ^CCQH-ITS-3548^C
line con 0
stopbits 1
line vty 0 4
line vty 5 15
transport input none
ntp clock-period 36028891
ntp server 10.10.0.24 key 0 prefer
ntp server 10.0.0.24
end
| Site 2 (Mule Mountain) |
---> Router:
Current configuration : 6498 bytes
upgrade fpd auto
version 12.4
no service pad
hostname MM-COM-7206
boot-start-marker
boot system flash disk2:c7200-adventerprisek9-mz.124-24.T1.bin
boot bootldr bootflash:c7200-kboot-mz.124-24.T1.bin
boot-end-marker
card type t1 5
card type t1 6
no logging console
enable secret 5 xxxxxxxxxxxxxxxxxxxxx
enable password 7 xxxxxxxxxxxxxxxxxxxx
aaa new-model
group tacacs+
group tacacs+
ip source-route
ip cef
no ipv6 cef
fax interface-type fax-mail
archive
log config
  hidekeys
controller T3 3/0
no channelized
description DS3 to Black Knob
controller T3 3/1
shutdown
no channelized
controller T3 4/0
no channelized
controller T3 4/1
shutdown
no channelized
controller T1 5/0
channel-group 1 timeslots 1-24
description Douglas T1-1
controller T1 5/1
description Douglas T1-2
controller T1 5/2
description Douglas T1-3
controller T1 5/3
description Douglas T1-4
controller T1 5/4
shutdown
controller T1 5/5
shutdown
controller T1 5/6
shutdown
controller T1 5/7
shutdown
controller T1 6/0
description T1-1 Benson
controller T1 6/1
description T1-2 Benson
controller T1 6/2
shutdown
controller T1 6/3
shutdown
controller T1 6/4
description T1-1 Willcox
controller T1 6/5
description T1-2 Willcox
controller T1 6/6
shutdown
controller T1 6/7
shutdown
interface Multilink1
description Douglas
ip address 10.0.60.2 255.255.255.252
no ip route-cache
ppp multilink
ppp multilink group 1
interface Multilink2
description Benson
ip address 10.0.50.2 255.255.255.252
no ip route-cache
ppp multilink
ppp multilink group 2
interface Multilink3
description Willcox
ip address 10.0.80.2 255.255.255.252
no ip route-cache
ppp multilink
ppp multilink group 3
description - Mule Mt Comm Site
ip address 10.100.252.1 255.255.252.0
no ip route-cache
no ip mroute-cache
duplex auto
speed auto
media-type rj45
no negotiation auto
description DISTRIBUTION TO MULE MOUNTAIN
ip address 10.100.3.254 255.255.252.0
no ip route-cache
no ip mroute-cache
description - VOICE VLAN 150 Mule Mountain
ip address 10.105.3.254 255.255.252.0
no ip route-cache
no ip mroute-cache
no ip address
no ip route-cache
shutdown
duplex auto
speed auto
media-type rj45
no negotiation auto
no ip address
no ip route-cache
shutdown
duplex auto
speed auto
media-type rj45
no negotiation auto
interface Serial3/0
ip address 10.0.110.2 255.255.255.252
dsu bandwidth 44210
framing c-bit
cablelength 10
interface Serial3/1
description DS3 to Sierra Vista
ip address 10.0.40.2 255.255.255.252
dsu bandwidth 44210
framing c-bit
cablelength 10
interface Serial4/0
description DS3 to Quality Hill
ip address 10.0.10.2 255.255.255.252
dsu bandwidth 44210
framing c-bit
cablelength 10
interface Serial4/1
no ip address
dsu bandwidth 44210
framing c-bit
cablelength 10
interface Serial5/0:1
no ip address
encapsulation ppp
ppp multilink
interface Serial5/1:1
no ip address
encapsulation ppp
ppp multilink
interface Serial5/2:1
no ip address
encapsulation ppp
ppp multilink
interface Serial5/3:1
no ip address
encapsulation ppp
ppp multilink
interface Serial6/0:1
no ip address
encapsulation ppp
ppp multilink
interface Serial6/1:1
no ip address
encapsulation ppp
ppp multilink
interface Serial6/4:1
no ip address
encapsulation ppp
ppp multilink
interface Serial6/5:1
no ip address
encapsulation ppp
ppp multilink
ip route 0.0.0.0 0.0.0.0 10.0.10.1
ip route 10.20.0.0 255.255.0.0 10.0.110.1
ip route 10.25.0.0 255.255.0.0 10.0.110.1
ip route 10.30.0.0 255.255.0.0 10.0.110.1
ip route 10.35.0.0 255.255.0.0 10.0.110.1
ip route 10.40.0.0 255.255.0.0 10.0.40.1
ip route 10.45.0.0 255.255.0.0 10.0.40.1
ip route 10.50.0.0 255.255.0.0 10.0.50.1
ip route 10.55.0.0 255.255.0.0 10.0.50.1
ip route 10.60.0.0 255.255.0.0 10.0.60.1
ip route 10.65.0.0 255.255.0.0 10.0.60.1
ip route 10.80.0.0 255.255.0.0 10.0.80.1
ip route 10.85.0.0 255.255.0.0 10.0.80.1
ip route 10.110.0.0 255.255.0.0 10.0.110.1
ip http server
no ip http secure-server
control-plane
mgcp fax t38 ecm
mgcp behavior g729-variants static-pt
gatekeeper
shutdown
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
end
---> Switch:
version 12.2
no service pad
hostname MM-COMM-3550
aaa new-model
system mtu routing 1500
ip subnet-zero
ip name-server 10.10.0.2
no ip igmp snooping
no file verify auto
description - TRUNK TO 3660
speed 100
switchport access vlan 100
switchport mode access
interface FastEthernet0/3
switchport trunk native vlan 100
switchport voice vlan 150
interface FastEthernet0/4
-- all the same except --
interface FastEthernet0/24
description TAIT TB9100 P25 RPT
switchport trunk native vlan 150
switchport mode dynamic desirable
interface Vlan1
ip address 10.100.252.2 255.255.252.0
no ip route-cache
no ip mroute-cache
ip default-gateway 10.100.252.1
ip classless
ip http server
snmp-server engineID local 0000000902000002B9D79D40
snmp-server chassis-id FAA0429G0P1
snmp-server host 10.30.0.27 pessimist
snmp-server host 10.30.0.28 pessimist
tacacs-server host 10.10.0.5
tacacs-server key 7 03544B1F4702605F5A
control-plane
banner motd ^MM-COMM-3550^
line con 0
line vty 0 4
line vty 5 15
end
gogasca
Level 10
Level 10
Could you describe exact locations for DHCP server and traffic flow ?
check IP helper command in L# interfaces including VVLAN
do you have DHCP pool for IP Phone subnets?
and verify if IP Phone has correct VLAN assigned
Hardcode manually static IP addresses and check if that works
paolo bevilacqua
Are you the end user ?
Why don't you engage a certified partner or reputable consultant that will guranteee professionalr esults and save you effort and frustation.
sbarasiscom
Can you try to use this command,
ip forward-protocol udp bootpc
