No matching outgoing dial-peer
bkhanal1971
Level 3
Level 3
Outbound calls through SIP trunk go fine. However, I am having issues with inbound calls. Looks like calls are not hitting CUCM. I have created SIP trunk between cube and CUCM and it seems to be working fine.
I am receiving E.164 numbers as DNIS type from my itsp. Following is my dial-peer in CUBE
dial-peer voice 21 voip
 description *** CALLS BOUND TO CUCM ***
 destination-pattern +1202.......
 session protocol sipv2
 session target ipv4:10.10.10.10
 voice-class codec 1
 dtmf-relay rtp-nte
 no vad
My translation pattern in CUCM :
pattern \+2022022020 ->11111 where 11111 is my DN
When I call my cell phone to 2022022010 the number is prefixed with +1 and for some reason above dial peer is not matched.
 I am seeing "Warning 399 No Matching Outgoing Dial-peer" errors.
Is there is any quick fix to this problem?
Thanks, Khanal
9 Replies 9
Hi Khanal.
Can you please collect a debug voip diaper inout and a debug ccsip message, call your mobile phone and post the result here?
Carlo
Please rate all helpful posts "The more you help the more you learn"
Did you mean call FROM my mobile phone to internal CUCM numbers or call TO my mobile number?
Yes sorry :)
Carlo
I have attached the debug outputs.
10.10.10.10 : CUCM server
10.10.10.15 : CUBE
200.200.200.201 : SIP signalling IP
202 465 5568: calling number
202 545 6960:  called number
Thank you so much for your help.
~ Khanal
Hi Khanal.
Is there any translation pattern on CUCM such as:
Pattern \+12025456960 as matched pattern and  Eg.
6960 and called party transform mask?
As alternative you can apply a translation rule on VG
Let me know
Carlo
Yes I have a translation pattern that translates \+12025456960 to ext 12888
Hi.
In some way your CUCM isn't matching that TP.
Please verify that partition where the TP is contained is included on Incoming CSS configured on SIP Trunk to CUBE.
Also the CSS in TP should be able to reach 12888 extension.
Please let me know
Carlo
...also on Unified Serviceability Menu.
Use Tools--> Dialled Number Analyser to verify that CUCM matches the incoming called number.
If you can, please post a screenshot of DNA result
thanks
Carlo
I got my problem resolved. I spent a few hours playing with dial-peer, translation rules and translation patterns. Nothing worked. All I was missing to do was to recent the SIP trunk in CUCM :(. I appreciate all the help you provided.
Thanks, Khanal
