02-10-2010 07:12 PM - edited 03-18-2019 11:05 AM
Hi All,
Have got a 7937 on a remote site that cant make more than 2 outbound calls on a 7937 conf phone. We have the same phone and configuration on the main site that can do 6 calls. Any clues as to why this one wont work?
Cucm - 6.1.4
Remote site - 2811 gateway
Taff
Solved! Go to Solution.
02-11-2010 02:36 AM
Hi Taff,
I would hazard a guess that the remote site doesn't have conference resources configured for it. It should need DSP resources to make/receive more than two calls at once as the on-board DSP can only handle two. Is it configured for a MRGL?
Cheers,
Phil
02-10-2010 08:56 PM
If you goto the Directory Number Configuration of the phone and check under the "Multiple Call/Call Waiting Settings on Device" section
there should be a setting for "Maximum Number of Calls". The value in this text box should determine the Max amount of calls allowed.
I'm using CUCM 7.0.2 but the Directory number configs should be the same.
02-10-2010 09:01 PM
Yeah the max number of calls is set to 6 with a busy trigger of 2..
02-10-2010 09:25 PM
Have you tried to increase the busy trigger? Because the busy trigger is set to 2 the third call will be busy.
02-10-2010 09:39 PM
Busy trigger is for inbound calls and they are trying to conference in via outbound calls.
02-10-2010 09:59 PM
I'm assuming you have enough channels available on your gateway ? PRI or FXO ?
02-10-2010 10:12 PM
Yeah 30 channel pri with heaps spare.
02-11-2010 02:36 AM
Hi Taff,
Cheers,
Phil
02-11-2010 05:41 PM
Yup you nailed it!
Thanks Phil..
