06-22-2012 03:25 AM - edited 03-16-2019 11:48 AM
Hi All,
Can anyone help with this at all?
We have set up SRST fallback on our CUCM 8.0.3 in our lab. we have a both SIP and SCCP phone registered to CUCM and the endpoints fallback to the gateway as required and they can all call between each other.
The problem I have is there are no external calls able to be made.
The gateway is actually the MGCP gateway that CUCM uses to dial out to the E1 trunk via the BT ISDN30 and when CUCM is up I can make calls to PSTN all day long but the moment CUCM is down and the phones fallback to SRST its only internal calls.
Here is some of my configuration;
You can see here this is how call manager fallback is setup;
call-manager-fallback
max-conferences 8 gain -6
transfer-system full-consult
ip source-address 10.1.31.10 port 2000
max-ephones 20
max-dn 50
sip-ua
retry invite 3
retry register 3
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
sip
bind control source-interface GigabitEthernet0/0
bind media source-interface GigabitEthernet0/0
registrar server expires max 600 min 60
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729br8
codec preference 4 g729r8
codec preference 5 g722-64
codec preference 6 g722-56
codec preference 7 g722-48
controller E1 0/3/0
pri-group timeslots 1-31 service mgcp
description E1 to PSTN for Cisco CUCM-8 BT Line
interface Serial0/3/0:15
description Used for PSTN on CUCM8 PSTN
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
dial-peer voice 10 pots
destination-pattern 0T
direct-inward-dial
port 0/3/0:15
forward-digits all
SBCISCOGW81#
SBCISCOGW81#
*Jun 22 10:40:14.647: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=01992706568, Called Number=01992706568, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=01992706568
Result=Success(0) after DP_MATCH_DEST
*Jun 22 10:40:14.647: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=01992706568, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
*Jun 22 10:40:14.647: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
List of Matched Outgoing Dial-peer(s):
1: Dial-peer Tag=10
*Jun 22 10:40:14.647: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=4313, Called Number=, Voice-Interface=0x0,
Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=40002
dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
*Jun 22 10:40:14.647: //-1/7C34AD26849D/DPM/dpAssociateIncomingPeerCore:
Calling Number=4313, Called Number=01992706568, Voice-Interface=0x0,
*Jun 22 10:40:14.647: //-1/7C34AD26849D/DPM/dpMatchSafModulePlugin:
*Jun 22 10:40:14.655: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=, Called Number=01992706568, Peer Info Type=DIALPEER_INFO_SPEECH
*Jun 22 10:40:14.655: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=01992706568, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
*Jun 22 10:40:14.655: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=10
*Jun 22 10:40:14.659: //-1/7C34AD26849D/DPM/dpMatchPeersCore:
*Jun 22 10:40:14.659: //-1/7C34AD26849D/DPM/dpMatchSafModulePlugin:
*Jun 22 10:40:14.659: //-1/7C34AD26849D/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=10
Result=SUCCESS(0)
1: Dial-peer Tag=10
*Jun 22 10:40:14.659: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
*Jun 22 10:40:14.663: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
*Jun 22 10:40:14.663: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=10
*Jun 22 10:40:14.663: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=01992706568, Called Number=, Voice-Interface=0x0,
Result=NO_MATCH(-1) After All Match Rules Attempt
dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
*Jun 22 10:40:14.663: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Result=SUCCESS(0)
1: Dial-peer Tag=10
*Jun 22 10:40:14.663: //-1/7C34AD26849D/DPM/dpMatchPeersCore:
*Jun 22 10:40:14.663: //-1/7C34AD26849D/DPM/dpMatchSafModulePlugin:
*Jun 22 10:40:14.663: //-1/7C34AD26849D/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=10
no ip address
encapsulation hdlc
no cdp enable
And then this Dial Peer;
direct-inward-dial
port 0/3/0:15
forward-digits all
This is the output from DEBUG VOICE DIALPEER when I dial the number from the phone;
It looks like it is matching the dial-peer but no call is being made;
SBCISCOGW81#
SBCISCOGW81#
Result=SUCCESS(0)
1: Dial-peer Tag=10
Result=SUCCESS(0)
1: Dial-peer Tag=10
Result=SUCCESS(0)
1: Dial-peer Tag=10
Result=SUCCESS(0)
1: Dial-peer Tag=10
Result=SUCCESS(0)
1: Dial-peer Tag=10
Result=SUCCESS(0)
1: Dial-peer Tag=10
Result=SUCCESS(0)
1: Dial-peer Tag=10
Any help or advice I've appreciate it very much so.
Solved! Go to Solution.
06-22-2012 06:30 AM
Hey Joe, No sirs here. We are all buddies! Glad to help.
Please rate useful posts
"For the love of God is broader than the measure of man's mind And the heart of the Eternal is most wonderfully kind"
