NO REGISTRATION ON VOIP SP
Jesutofunmi O
Hello Guys,
Registration keeps failing with my voip service provider. I am not a voice guy and this is my first time. I have authentication details from my provider but registration never occurs. Please assist. Config is below.
Current configuration : 22041 bytes
! Last configuration change at 14:35:36 UTC Wed Feb 6 2019 by admin
! NVRAM config last updated at 14:16:00 UTC Wed Feb 6 2019 by admin
version 15.3
service password-encryption
hostname WEBER
boot-start-marker
boot-end-marker
aqm-register-fnf
! card type command needed for slot/vwic-slot 0/1
logging buffered 5000000
no logging console
no logging monitor
no aaa new-model
ip domain name WEBER
ip cef
no ipv6 cef
crypto pki trustpoint TP-self-signed-2743843390
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2743843390
revocation-check none
rsakeypair TP-self-signed-2743843390
voice-card 0
dspfarm
dsp services dspfarm
voice service voip
callmonitor
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
bind control source-interface GigabitEthernet0/1
bind media source-interface GigabitEthernet0/1
registrar server expires max 3600 min 600
no call service stop
voice register global
mode cme
source-address 172.16.121.5 port 5060
max-dn 80
max-pool 165
authenticate realm cme.telecoms.com
create profile sync 1538559805332485
voice register template 1
voice translation-rule 1
rule 1 /^1009/ /0xxxxxx7/
voice translation-profile GSM-Outbound
translate calling 1
license udi pid CISCO2951/K9 sn FJC1928A0AP
hw-module ism 0
hw-module pvdm 0/0
hw-module pvdm 0/1
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface ISM0/0
no ip address
shutdown
!Application: CUE Running on ISM
description CONNECTION TO WB
ip address 172.16.121.5 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface ISM0/1
description Internal switch interface connected to Internal Service Module
no ip address
interface Vlan1
no ip address
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:GUI
ip route 0.0.0.0 0.0.0.0 172.16.121.1
no logging trap
nls resp-timeout 1
cpd cr-id 1
tftp-server flash:/term45.default.loads alias term45.default.loads
control-plane
voice-port 0/2/0
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
sccp local GigabitEthernet0/1
sccp ccm 172.16.121.5 identifier 1 priority 1 version 7.0
sccp
sccp ccm group 1
bind interface GigabitEthernet0/1
associate ccm 1 priority 1
associate profile 1 register WEBER
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 6
associate application SCCP
dial-peer cor custom
name DIR
name PSTN
dial-peer cor list DIRECTORY-ACCESS
member DIR
dial-peer cor list PSTN-ACCESS
member DIR
member PSTN
dial-peer cor list DIRECTORY-CALLS
member DIR
dial-peer cor list PSTN-CALLS
member PSTN
dial-peer voice 9 voip
translation-profile outgoing GSM-Outbound
destination-pattern 9[0][78][01]T
session protocol sipv2
session target dns:cme.telecoms.com
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte
codec g711ulaw
no vad
sip-ua
credentials username 0xxxxxx7 password 7 UBEIERUIBBVJKKBLG realm cme.telecoms.com
authentication username 0xxxxxx7 password 7 THKLILDNKBSFBKEJG realm cme.telecoms.com
retry register 10
registrar dns:cme.telecoms.com expires 3600
sip-server dns:cme.telecoms.com
host-registrar
gatekeeper
shutdown
telephony-service
sdspfarm units 10
sdspfarm tag 1 Weber
conference hardware
max-ephones 80
max-dn 80
ip source-address 172.16.121.5 port 2000
timeouts interdigit 4
timeouts ringing 20
system message Weber
url directories http://172.16.121.5/localdirectory
cnf-file location flash:
cnf-file perphone
load 7945 SCCP45.9-2-1S.loads
time-zone 21
date-format dd-mm-yy
max-conferences 8 gain -6
web admin system name admin secret 5 $r3rdrdtrdtrdjh
dn-webedit
time-webedit
transfer-system full-consult
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-template 1
softkeys hold Resume Newcall Join Select
softkeys idle Newcall Redial Cfwdall ConfList Join RmLstC Pickup
softkeys seized Meetme Redial Endcall Cfwdall Pickup
softkeys connected Hold Endcall Trnsfer Confrn ConfList Join RmLstC
ephone-dn 9 dual-line
number 1009
label 1009
description Test Phone
name Test Phone
ephone 9
mac-address 7G54.8754.9JU7
ephone-template 1
type 7945
button 1:9
line con 0
logging synchronous
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line 195
no exec
transport input all
stopbits 1
line vty 0 4
privilege level 15
password 7 13261E010803557878
login local
transport input telnet ssh
transport output none
line vty 5 15
privilege level 15
login local
scheduler allocate 20000 1000
ntp master 3
ntp update-calendar
end
WEBER#
WEBER#
13 Replies 13
add the output of 'debug ccsip messages'
regards
Hello @Daniele Giordano
Please find attached and below.
May 6 15:07:32.794: //151196/000000000000/SIP/Error/act_sent_register_wait_100:
act_sent_register_wait_100: Out of retries
May 6 15:07:32.794: //151196/000000000000/SIP/Error/ccsip_api_register_result_ind:
Message Code Class 4xx Method Code 100 received for REGISTER
May 6 15:07:32.794: //-1/xxxxxxxxxxxx/SIP/Error/sipDestroyContainerContext:
Corrupted/Freed Container=0x0
SIP Registration Retries Exhausted
May 6 15:07:32.802: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
Freeing NULL pointer!
May 6 15:07:32.802: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REGISTER sip:cme.telecoms.com:5060 SIP/2.0
Via: SIP/2.0/UDP 172.16.121.5:5060;branch=z9hG4bK1A6B5CE5
To: <sip:1034@cme.telecoms.com>
Date: Mon, 06 May 2019 15:07:32 GMT
Call-ID: 6CF29BE8-6F4711E9-BB60E817-C0100652
User-Agent: Cisco-SIPGateway/IOS-15.3.3.M5
Max-Forwards: 70
Timestamp: 1557155252
CSeq: 2 REGISTER
Contact: <sip:1034@172.16.121.5:5060>
Expires: 3600
Supported: path
Content-Length: 0
May 6 15:07:32.806: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
May 6 15:07:32.806: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 172.16.121.5:5060;branch=z9hG4bK1A6B62041
To: <sip:1035@cme.telecoms.com>
Call-ID: 6CF29BE8-6F4711E9-BB61E817-C0100652
Max-Forwards: 70
CSeq: 2 REGISTER
Contact: <sip:1035@172.16.121.5:5060>
Expires: 3600
Supported: path
Content-Length: 0
Sent:
Via: SIP/2.0/UDP 172.16.121.5:5060;branch=z9hG4bK1A6B723D2
From: <sip:1036@cme.telecoms.com>;tag=19776BDC-1984
To: <sip:1036@cme.telecoms.com>
Call-ID: 6CF33810-6F4711E9-BB62E817-C0100652
Max-Forwards: 70
CSeq: 2 REGISTER
Contact: <sip:1036@172.16.121.5:5060>
Expires: 3600
Supported: path
Content-Length: 0
May 6 15:07:32.814: //151197/000000000000/SIP/Error/act_sent_register_wait_100:
May 6 15:07:32.814: //151197/000000000000/SIP/Error/ccsip_api_register_result_ind:
May 6 15:07:32.814: //-1/xxxxxxxxxxxx/SIP/Error/sipDestroyContainerContext:
May 6 15:07:32.818: //151198/000000000000/SIP/Error/act_sent_register_wait_100:
May 6 15:07:32.818: //151198/000000000000/SIP/Error/ccsip_api_register_result_ind:
May 6 15:07:32.818: //-1/xxxxxxxxxxxx/SIP/Error/sipDestroyContainerContext:
May 6 15:07:32.818: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
May 6 15:07:32.818: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 172.16.121.5:5060;branch=z9hG4bK1A6B817FC
From: <sip:1037@cme.telecoms.com>;tag=19776BDC-141D
To: <sip:1037@cme.telecoms.com>
Call-ID: 6CF33810-6F4711E9-BB63E817-C0100652
Max-Forwards: 70
CSeq: 2 REGISTER
Contact: <sip:1037@172.16.121.5:5060>
Expires: 3600
Supported: path
Content-Length: 0
May 6 15:07:32.822: //151199/000000000000/SIP/Error/act_sent_register_wait_100:
May 6 15:07:32.822: //151199/000000000000/SIP/Error/ccsip_api_register_result_ind:
May 6 15:07:32.822: //-1/xxxxxxxxxxxx/SIP/Error/sipDestroyContainerContext:
May 6 15:07:32.826: //151200/000000000000/SIP/Error/act_sent_register_wait_100:
May 6 15:07:32.826: //151200/000000000000/SIP/Error/ccsip_api_register_result_ind:
May 6 15:07:32.826: //-1/xxxxxxxxxxxx/SIP/Error/sipDestroyContainerContext:
May 6 15:07:32.830: //151201/000000000000/SIP/Error/act_sent_register_wait_100:
May 6 15:07:32.830: //151201/000000000000/SIP/Error/ccsip_api_register_result_ind:
May 6 15:07:32.830: //-1/xxxxxxxxxxxx/SIP/Error/sipDestroyContainerContext:
May 6 15:07:32.834: //151202/000000000000/SIP/Error/act_sent_register_wait_100:
May 6 15:07:32.834: //151202/000000000000/SIP/Error/ccsip_api_register_result_ind:
May 6 15:07:32.834: //-1/xxxxxxxxxxxx/SIP/Error/sipDestroyContainerContext:
May 6 15:07:32.842: //151203/000000000000/SIP/Error/act_sent_register_wait_100:
May 6 15:07:32.842: //151203/000000000000/SIP/Error/ccsip_api_register_result_ind:
May 6 15:07:32.842: //-1/xxxxxxxxxxxx/SIP/Error/sipDestroyContainerContext:
May 6 15:07:32.842: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
May 6 15:07:32.842: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 172.16.121.5:5060;branch=z9hG4bK1A6B91F71
To: <sip:1038@cme.telecoms.com>
Call-ID: 6CF33810-6F4711E9-BB64E817-C0100652
Max-Forwards: 70
CSeq: 2 REGISTER
Contact: <sip:1038@172.16.121.5:5060>
Expires: 3600
Supported: path
Content-Length: 0
your registrar is set as a DNS configuration - registrar dns:cme.telecoms.com, but is cme.telecoms.com reachable or resolvable from the router? It does not look like the SIP request is making it to the carrier.
Hello Mike,
Yes. The registrar dns:cme.telecoms.com is reachable from the router.
#ping cme.telecoms.com
Sending 5, 100-byte ICMP Echos to XX.XX.XX.XX, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms
As you can see, the router sends a lot of register messages but not answares are received. could be a nat issue. The router use its private ip 172.16....
Do you nave an other router in front of it? Is SIP nat helper o SIP ALG active?
BR
Yes. I had an ASA Firewall. That was the device responsible for the NAT. The connection was such as;
SP Modem-->Cisco ASA FW--->Core Switch--->CME
Now, what I have done now is to configure an outside interface for the CME itself.
I did a default route to the internet gateway. Configured an access list to allow the CME interface range access to internet. please find attached the current CME config and "debug ccsip all".
I understand registration is sent out the 172.16.121.5 interface but where does it stop. Now, I expect it to go out through the default GW to the Service Provider SBC but it is still not registering.
Yes. I had an ASA Firewall. That was my NAT device for all devices on my network. The connection was such as;
Now, what I have done is to configure an outside interface for the CME itself.
I did a default route to the internet gateway. Configured an access list to allow the CME interface range access to internet. Please find attached the current CME config and "debug ccsip all".
ok great, so the SIP provider is reachable.
As you have an auth and credentials set, can you show the output of the following:
sh sip-ua register status
the reg column should say yes, if not, try to pull the ccsip messages from the registration attempts, not from a call attempt.
You can force a re-registration by removing the line - "registrar dns:cme.telecoms.com" expires 3600, and adding it back in.
Hello @Mike_Brezicky
I have attached the "Show CCSIP message" result. The number meant to register is 01631XXXX. So you may lookout for it. Also, below is some of the output.
May 9 14:25:31.662: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 172.16.121.5:5060;branch=z9hG4bK2A6C026C4
From: <sip:01631XXXX@cme.telecoms.com>;tag=28C395C4-1E9B
To: <sip:01631XXXX@cme.telecoms.com>
Date: Thu, 09 May 2019 14:25:31 GMT
Call-ID: FB3AA5D1-719C11E9-8A1DE817-C0100652
Max-Forwards: 70
Timestamp: 1557411931
CSeq: 2 REGISTER
Contact: <sip:01631XXXX@172.16.121.5:5060>
Expires: 3600
Supported: path
Content-Length: 0
May 9 14:25:35.606: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 172.16.121.5:5060;branch=z9hG4bK2A68425AB
From: <sip:1009@cme.telecoms.com>;tag=28C3957C-2687
To: <sip:1009@cme.telecoms.com>
Date: Thu, 09 May 2019 14:25:35 GMT
Call-ID: FB2FA9D1-719C11E9-89E8E817-C0100652
Max-Forwards: 70
Timestamp: 1557411935
CSeq: 2 REGISTER
Contact: <sip:1009@172.16.121.5:5060>
Expires: 3600
Supported: path
Content-Length: 0
Sent:
Via: SIP/2.0/UDP 172.16.121.5:5060;branch=z9hG4bK2A68554E
To: <sip:1010@cme.telecoms.com>
Call-ID: FB3045F9-719C11E9-89E9E817-C0100652
Max-Forwards: 70
CSeq: 2 REGISTER
Contact: <sip:1010@172.16.121.5:5060>
Expires: 3600
Supported: path
Content-Length: 0
Sent:
Via: SIP/2.0/UDP 172.16.121.5:5060;branch=z9hG4bK2A687935
From: <sip:1011@cme.telecoms.com>;tag=28C39580-1E98
To: <sip:1011@cme.telecoms.com>
Call-ID: FB3045F9-719C11E9-89EAE817-C0100652
Max-Forwards: 70
CSeq: 2 REGISTER
Contact: <sip:1011@172.16.121.5:5060>
Expires: 3600
Supported: path
Content-Length: 0
Sent:
Via: SIP/2.0/UDP 172.16.121.5:5060;branch=z9hG4bK2A68811B0
To: <sip:1012@cme.telecoms.com>
Call-ID: FB3045F9-719C11E9-89EBE817-C0100652
Max-Forwards: 70
CSeq: 2 REGISTER
Contact: <sip:1012@172.16.121.5:5060>
Expires: 3600
Supported: path
Content-Length: 0
Sent:
Via: SIP/2.0/UDP 172.16.121.5:5060;branch=z9hG4bK2A6891316
From: <sip:1013@cme.telecoms.com>;tag=28C39584-1208
To: <sip:1013@cme.telecoms.com>
Call-ID: FB30E221-719C11E9-89ECE817-C0100652
Max-Forwards: 70
CSeq: 2 REGISTER
Contact: <sip:1013@172.16.121.5:5060>
Expires: 3600
Supported: path
Content-Length: 0
Sent:
Via: SIP/2.0/UDP 172.16.121.5:5060;branch=z9hG4bK2A68B822
From: <sip:1014@cme.telecoms.com>;tag=28C39584-1652
To: <sip:1014@cme.telecoms.com>
Call-ID: FB30E221-719C11E9-89EDE817-C0100652
Max-Forwards: 70
CSeq: 2 REGISTER
Contact: <sip:1014@172.16.121.5:5060>
Expires: 3600
Supported: path
Content-Length: 0
Sent:
Via: SIP/2.0/UDP 172.16.121.5:5060;branch=z9hG4bK2A68C1B1B
From: <sip:1015@cme.telecoms.com>;tag=28C39588-26A0
To: <sip:1015@cme.telecoms.com>
Call-ID: FB317E49-719C11E9-89EEE817-C0100652
Max-Forwards: 70
CSeq: 2 REGISTER
Contact: <sip:1015@172.16.121.5:5060>
Expires: 3600
Supported: path
Content-Length: 0
Can you please show the output of the following:
The only thing I see from the ccsip messages is your router continues to retry registration, but the far end is not even sending a response.
Is there a firewall in between that may be blocking port 5060?
Hello Mike,
The output of "show sip-ua register status" has been and is still "no" which is why I am here asking for help here.
Secondly, it was behind a firewall. I removed the config and then connected it directly to ISP and did a NAT. Still the same. Please see attached screenshot
Line peer expires(sec) reg survival P-Associ-URI
01631XXXXX -1 5 no normal
1001 20001 5 no normal
1002 20002 0 no normal
1003 20003 1 no normal
1004 20004 148 no normal
Ok, so is cme.telecoms.com the actual registrar or are you masking it on your config.  Can you check to make sure the carrier information is correct and port 5060 is open.
If cme.telecoms.com is correct, I am resolving it to 212.153.70.31, which does not have port 5060 open.
cme.telecoms.com is not the real domain. Just used it to make the post.
This issue is still unresolved and I am open to solutions.
One of the observations from the packet capture is that my extensions are also sending register request to the SP's SBC which then makes the SP blacklist my IP thereby making subsequent "register" request fail completely. I do not know why this is. I reckon that registration will be successful if i am able to get to the roots of why my extensions are also sending registration requests to the SP's SBC.
