IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5548 Views
  • 14 replies
Hello,   I have a requirement to force callers from a gateway/trunk when dialing a number to CUCM 11.5 cluster to be prompted for a auth code to connect the call. I was going to use a CMC (client matter code) on a Route pattern, but recently discover...
We are facing issue with SNR feature  on CIPC ..when we call on CIPC ext from mobile number parallel call not rings on users personal mobile number it only rings on users CIPC phone   1. End user configuration created with Checked Box for Enable Mobi...
Resolved! Dial Peer
Hi, Is it mandatory for an outbound pots dial peer a voice port has to be mentioned as well? If there isn't any voice ports mentioned for the dial peer can it automatically select which voice port to take? Thanks in advance.
Hello.       We have call manager 4.1 Head office and our branch office is having CME 7.0. We are not able to do a conference between Head office ext 7250---6250 and vice versa.But on the other hand the conference between local phones are working ver...
1. What are the functions of the loopback interface in voice gateways? 2. Since loopback interface is always up unless the router is broken, is it advisable to tie the interface which generates H323  traffic to the loopback interface?
Hello, When we try to edit phones in CUCM, specifically adding lines or changing their order, we would click on the Modify Button Items button.  It would pop up a small window where we could change line order, associate and disassociate lines as need...
ma_slepko by Level 1
  • 1271 Views
  • 2 replies
