No Ringback from SIP Provider after Unity Transfer
I've run into an issue where callers coming from the PSTN do not hear ringback after being transferred using a Cisco Unity call handler.
Ringback works internally between phones, and also works internally if I dial the call handler DN and request a transfer.
Call flow is this: SIP Provider -> CUBE -> SIP Trunk -> CUCM -> Unity Connection (SCCP)
The caller just hears dead air until the phone is picked up, or it bounces to voicemail.
There is an MRGL assigned to the SIP trunk to CUBE that contains an announciator and MoH.
The weird thing is the caller does hear about a second of MoH when Unity begins the transfer, but nothing after that.
debug ccsip messages:
1111111111 is the called party/number, 2222222222 is the calling number (my cellphone)
000925: Sep 18 14:08:06.696 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:1111111111@184.71.242.2:5060 SIP/2.0
Via: SIP/2.0/UDP 208.43.85.75:5060;branch=z9hG4bK27e0cc04;rport
From: "2222222222" <sip:2222222222@208.43.85.75>;tag=as2bec68a8
To: <sip:1111111111@184.71.242.2:5060>
Contact: <sip:2222222222@208.43.85.75>
Call-ID: 264119bc6be819f81634da4a67543569@208.43.85.75
CSeq: 102 INVITE
User-Agent: Asterisk PBX
Max-Forwards: 70
Remote-Party-ID: "2222222222" <sip:2222222222@208.43.85.75>;privacy=off;screen=no
Date: Thu, 18 Sep 2014 20:08:06 GMT
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY
Supported: replaces
Content-Type: application/sdp
Content-Length: 361
v=0
o=root 1022 1022 IN IP4 208.43.85.75
s=session
c=IN IP4 208.43.85.75
b=CT:384
t=0 0
m=audio 11300 RTP/AVP 0 8 101
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=silenceSupp:off - - - -
a=ptime:20
a=sendrecv
m=video 14308 RTP/AVP 34 99
a=rtpmap:34 H263/90000
a=rtpmap:99 H264/90000
a=sendrecv
000926: Sep 18 14:08:06.708 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:700@10.135.191.12:5061 SIP/2.0
Via: SIP/2.0/TLS 172.18.0.1:5061;branch=z9hG4bK40E577
Remote-Party-ID: "2222222222" <sip:2222222222@172.18.0.1>;party=calling;screen=no;privacy=off
From: "2222222222" <sip:2222222222@sip1.ixica.com>;tag=1D82524-20B8
To: <sip:700@10.135.191.12>
Call-ID: 56A4B001-3EA611E4-8227D749-31CC0927@172.18.0.1
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 1453513609-1051070948-2183255881-0835455271
User-Agent: Cisco-SIPGateway/IOS-15.2.4.M6a
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1411070886
Contact: <sip:2222222222@172.18.0.1:5061;transport=tls>
Expires: 180
Allow-Events: telephone-event
Max-Forwards: 69
Content-Disposition: session;handling=required
Content-Length: 394
v=0
o=CiscoSystemsSIP-GW-UserAgent 6324 6685 IN IP4 172.18.0.1
s=SIP Call
c=IN IP4 172.18.0.1
t=0 0
m=audio 16420 RTP/AVP 0 101
c=IN IP4 172.18.0.1
a=fmtp:101 0-16
a=ptime:20
m=video 16422 RTP/AVP 34 119
c=IN IP4 172.18.0.1
a=fmtp:34 CIF=1
a=rtpmap:119 H264/90000
a=fmtp:119 profile-level-id=000000
000927: Sep 18 14:08:06.712 MST: //1040/56A2DB898221/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 102 INVITE
Server: Cisco-SIPGateway/IOS-15.2.4.M6a
Content-Length: 0
000928: Sep 18 14:08:06.716 MST: //1042/56A2DB898221/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Allow-Events: presence
Content-Length: 0
000929: Sep 18 14:08:06.728 MST: //1042/56A2DB898221/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <sip:700@10.135.191.12>;tag=6169~dc062259-9b0a-4df2-b05d-e4de329c1980-23733830
CSeq: 101 INVITE
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
Server: Cisco-CUCM10.5
Supported: X-cisco-srtp-fallback
Supported: Geolocation
P-Asserted-Identity: "Cisco Unity" <sip:800@10.135.191.12>
Remote-Party-ID: "Cisco Unity" <sip:800@10.135.191.12>;party=called;screen=yes;privacy=off
Contact: <sip:700@10.135.191.12:5061;transport=tls>
Content-Length: 0
000930: Sep 18 14:08:06.732 MST: //1040/56A2DB898221/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To: <sip:1111111111@184.71.242.2:5060>;tag=1D82538-D9C
CSeq: 102 INVITE
Remote-Party-ID: "Cisco Unity" <sip:800@184.71.242.2>;party=called;screen=yes;privacy=off
Contact: <sip:700@184.71.242.2:5060>
Content-Length: 0
000931: Sep 18 14:08:06.804 MST: //1042/56A2DB898221/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Allow-Events: presence, kpml
Supported: replaces
Session-Expires:  1800;refresher=uas
Require:  timer
Contact: <sip:700@10.135.191.12:5061;transport=tls>;isFocus
Content-Length: 406
v=0
o=CiscoSystemsCCM-SIP 6169 1 IN IP4 10.135.191.12
s=SIP Call
c=IN IP4 10.135.191.12
b=TIAS:64000
b=CT:64
b=AS:64
t=0 0
m=audio 25280 RTP/AVP 0 101
a=ptime:20
a=fmtp:101 0-15
m=video 0 RTP/AVP 31 34 96 97
a=rtpmap:31 H261/90000
a=rtpmap:96 H263-1998/90000
a=rtpmap:97 H264/90000
a=content:main
a=inactive
000932: Sep 18 14:08:06.808 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:700@10.135.191.12:5061;transport=tls SIP/2.0
Via: SIP/2.0/TLS 172.18.0.1:5061;branch=z9hG4bK40F1BB8
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
000933: Sep 18 14:08:06.812 MST: //1040/56A2DB898221/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 102 INVITE
Contact: <sip:1111111111@184.71.242.2:5060>
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Length: 292
v=0
o=CiscoSystemsSIP-GW-UserAgent 4672 7011 IN IP4 184.71.242.2
s=SIP Call
c=IN IP4 184.71.242.2
t=0 0
m=audio 16416 RTP/AVP 0 101
a=fmtp:101 0-16
a=ptime:20
m=video 0 RTP/AVP 34
000934: Sep 18 14:08:06.896 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:1111111111@184.71.242.2:5060 SIP/2.0
Via: SIP/2.0/UDP 208.43.85.75:5060;branch=z9hG4bK243fd8d0;rport
CSeq: 102 ACK
Max-Forwards: 70
Content-Length: 0
000935: Sep 18 14:08:17.351 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
UPDATE sip:2222222222@172.18.0.1:5061;transport=tls SIP/2.0
Via: SIP/2.0/TLS 10.135.191.12:5061;branch=z9hG4bK8347ed20ac
From: <sip:700@10.135.191.12>;tag=6169~dc062259-9b0a-4df2-b05d-e4de329c1980-23733830
To: "2222222222" <sip:2222222222@sip1.ixica.com>;tag=1D82524-20B8
Date: Thu, 18 Sep 2014 20:08:07 GMT
User-Agent: Cisco-CUCM10.5
Max-Forwards: 70
Supported: timer,resource-priority,replaces
CSeq: 101 UPDATE
Call-Info: <urn:x-cisco-remotecc:callinfo>;x-cisco-video-traffic-class=VIDEO_UNSPECIFIED
Session-Expires:  1800;refresher=uac
Min-SE:  1800
P-Asserted-Identity: "Anthony" <sip:270@10.135.191.12>
Remote-Party-ID: "Anthony" <sip:270@10.135.191.12>;party=calling;screen=yes;privacy=off
Content-Length: 0
000936: Sep 18 14:08:17.351 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Thu, 18 Sep 2014 20:08:17 GMT
CSeq: 101 UPDATE
Contact: <sip:270@172.18.0.1:5061;transport=tls>
Require: timer
Supported: timer
Content-Length: 0
000937: Sep 18 14:08:22.894 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:1111111111@184.71.242.2:5060 SIP/2.0
Via: SIP/2.0/UDP 208.43.85.75:5060;branch=z9hG4bK7d5b6278;rport
CSeq: 103 BYE
Max-Forwards: 70
Content-Length: 0
000938: Sep 18 14:08:22.898 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Thu, 18 Sep 2014 20:08:22 GMT
CSeq: 103 BYE
Reason: Q.850;cause=16
P-RTP-Stat: PS=804,OS=128640,PR=693,OR=98712,PL=0,JI=0,LA=0,DU=16
Content-Length: 0
000939: Sep 18 14:08:22.898 MST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:700@10.135.191.12:5061;transport=tls SIP/2.0
Via: SIP/2.0/TLS 172.18.0.1:5061;branch=z9hG4bK4102F8
Max-Forwards: 70
Timestamp: 1411070902
CSeq: 102 BYE
P-RTP-Stat: PS=693,OS=98712,PR=804,OR=128640,PL=0,JI=0,LA=0,DU=16
Content-Length: 0
000940: Sep 18 14:08:22.902 MST: //1042/56A2DB898221/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Date: Thu, 18 Sep 2014 20:08:23 GMT
CSeq: 102 BYE
Content-Length: 0
CUBE Dialpeers and voice config:
voice service voip
 ip address trusted list
 mode border-element
 allow-connections sip to sip
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 sip
  registrar server expires max 1200 min 300
  rel1xx disable
  midcall-signaling passthru
  g729 annexb-all
dial-peer voice 1000 voip
 description *** Outbound CUCM ***
 destination-pattern ...
 session protocol sipv2
 session target ipv4:XXXXXX
 session transport tcp tls
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
dial-peer voice 2000 voip
 description *** Inbound CUCM ***
 incoming called-number ...
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
dial-peer voice 101 voip
 description *** Incoming Dial-Peer ***
 translation-profile incoming INCOMING1
 session target sip-server
 incoming called-number 1111111111
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
dial-peer voice 1 voip
 description *** Outbound Dial-Peer ***
 translation-profile outgoing Strip9
 destination-pattern 9.+
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
99 Replies 99
Tried enabling rel1xx on both CUBE and CUCM to always send PRACKs, didn't help.
Also tried disabling early media on 180, also did not help.
I found a lot of other threads referencing similar problems, but most seem to have had H323 somewhere in the mix, which I do not.
Any help is appreciated, I'll keep digging as well.
Hi.
Can you please try to add what follows
Under voice service voip
no supplementary service sip moved-temporarily
no supplementary service refer
Try these two commands and let me know
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi Carlo,
After playing with this I gave up and opened a case with TAC, currently waiting for them to provide a fix or more insight.
I really couldn't find what the issue was...
Anthony
To be specific as I should have been in the first place I did try these commands and they had no effect seemingly.
Hi.
Just to give a try, can you please change the transfer type on UC call handler from "Supervise Transfer" to "Release Switch" and see if it makes differences..
Please after this change post a debug ccsip message from your CUBE
Carlo
Hi Carlo,
CUC is already set to release to switch mode:
I can't even seem to set this to a supervised transfer, unless I am looking in the wrong place?
http://i.imgur.com/9XJV4mz.png
Thank you,
Anthony
Hi Anthony.
From your screenshot you are looking in a wrong place.
You should first look at call handler with original called number than as transfer rule you should find the destination internal number.
There you should find the option switch release.
If you want you can post a screenshot of current configuration.
Let me know
Carlo
Hi Carlo,
I don't quite understand where I should be looking, I'm not as familiar with CUC as I would like to be.
The only transfer rule that is enabled in the call handler is "standard" which is the page I screenshotted earlier.
I see that I can change the transfer type in the caller input screen if a caller presses a key, right now this is all set to release to switch.
Anthony
In my case, I was able to fix it yesterday night adding the ANN into the MRGL between CM and CUBE.
It looks like is necessary to reconnect the audio stream to the ANN to emulate a ringback tone...
I hope it helps you...
You would be correct here, CUCM should be providing the ringback through the use of an announciator, but for some reason it's not... The MRGL has an announciator in it, and the announciator shows as registered.
It's really strange.
Glad to hear you fixed your issue though :)
I would reset all the ANNs, and do not forget to reset the Trunk as well...since it is simple and it will not hurt even we know is showing as registered...I would give it a try...
Another possibility would be to change from SCCP to SIP between your CM and CUC because this is the only difference from your scenario to mine...not sure if it might be a bug, but in my case using all the way SIP, adding ANN has fixed it.
I did try resetting the ANNs and trunks earlier in the troubleshooting process and it didn't seem to make a difference.
I have toyed with the idea of moving to SIP integration from CUC to CUCM, I don't think it's a laborious process, just been putting it off in hopes that this would be fixed.
I have looked in detail at your logs and here is what I observed..
+++CUCM indeed selected an annunciator for the call+++
08056608.001 |08:30:17.452 |AppInfo  |AnnDControl::waiting_PolicyAndCACRegisterRes - Device Name = ANN_2, Ann CI = 25208342, RSVP Success
08056608.002 |08:30:17.452 |AppInfo  |AnnDControl::handleAnnSuccess Annunciator successfully allocated for CI= 25208344
8056614.001 |08:30:17.453 |AppInfo  |ARBTRY-ConnectionManager-wait_MediaConnectRequest(25208335,25208344)
+++However something strange happened here. When cucm told announciator to start playing announcement (ringback in this case), the remote ip address was to itself++++
This is the OLCAck. Note that the port number is different and ip is the same++
08056668.001 |08:30:17.457 |AppInfo  |AnnDControl(ANN_2) - star_StationOpenReceiveChannelAck - Received from ANN Device Status=0, PartyId=16778504, IP=213878538, Port=27948
08056676.002 |08:30:17.457 |AppInfo  |DET-AgenaInterfaceBase-(474)::setDeviceOLCAckInfo, lcn=1, ip=10.135.191.12, port=27950
++here we see where ANN is sending its announcement to, same ip but different port number+++
08056679.001 |08:30:17.457 |AppInfo  |AnnDControl::star_MediaExchangeStartTalking StartAnnoucement locale =1 AnnID=36= playMode=2 endAnnAck=0
08056680.000 |08:30:17.457 |SdlSig   |MediaPartyConnectInfoInd               |interfacesEstablished          |MediaExchange(1,100,145,636)     |AgenaInterface(1,100,244,326)    |1,100,14,140069.19268^10.135.191.12^MTP_2 |[R:N-H:0,N:2,L:0,V:0,Z:0,D:0]  CI =25208344 EXPECT_CONNECTINFO_FROM_ALL_HOPS Unspecified MediaSecurity=F MMCap=0x1 Aud Info[ RecvRtpTa= ipAddrType=0 ipv4=10.135.191.12:27948 ActiveLineStackIdx=0 Codec=4 64 Kbps 20 Msec V4] No Main Video No Sec video
08056681.000 |08:30:17.457 |SdlSig   |StationOutputStartMediaTransmission    |waiting                        |AnnDControl(1,100,242,6)         |AnnDControl(1,100,242,6)         |1,100,14,140069.19268^10.135.191.12^MTP_2 |[R:N-H:0,N:2,L:0,V:0,Z:0,D:0] ConfId=25208344 remoteIpAddr=.type=0 .addr=0x{a,87,bf,c,0,0,0,0,0,0,0,0,0,0,0,0}(10.135.191.12) Port=27950 PacketSize=20 PayloadType=4 CI=25208344 DiffServ=0xb8 (DSCP=0x2e) Silent=0 MaxFrms=0 G723BitRate=0 PartyId=0x1000508 RFC2833PayloadType=0 mixingMode=0 partyDir=0
08056681.001 |08:30:17.457 |AppInfo  |AnnDControl - stationOutputStartMediaTransmission TCPPid = [1.100.14.140071] myIP: cbf870a (10.135.191.12)
08056681.002 |08:30:17.457 |AppInfo  |AnnDControl - RemoteIpAddr: cbf870a (10.135.191.12) RemoteRtpPortNumber: 27950 msecPacketSize: 20 compressionType: 4
08056682.000 |08:30:17.457 |SdlSig   |StationStartAnnouncement               |waiting                        |AnnDControl(1,100,242,6)         |AnnDControl(1,100,242,6)         |1,100,14,140069.19268^10.135.191.12^MTP_2 |[R:N-H:0,N:1,L:0,V:0,Z:0,D:0]  ConferenceId=25208344 Locale =1 Country =6 AnnId =36 AnnAckReq=0 AnnPlayMode=2 HearingMask=0
08056682.001 |08:30:17.457 |AppInfo  |AnnDControl - star_StationOutputStationStartAnnouncement ConferenceID: 25208344, TCPPid = [1.100.14.140071] myIP: cbf870a (10.135.191.12)
To confirm this, I contrasted this with my working solution and here is what I see, observe that remote ip and port number is different from myip and port number++++
In an ideal scenario like this one below the remote ip should be pointing to the gateway like mine is.
62753747.001 |16:32:58.443 |AppInfo  |AnnDControl - stationOutputStartMediaTransmission TCPPid = [28.100.13.419] myIP: 1028690a (10.105.40.16)
62753747.002 |16:32:58.443 |AppInfo  |AnnDControl - RemoteIpAddr: 4a28690a (10.105.40.74) RemoteRtpPortNumber: 25540 msecPacketSize: 20 compressionType: 11
62753748.000 |16:32:58.443 |SdlSig   |StationStartAnnouncement               |waiting                        |AnnDControl(28,100,232,1)        |AnnDControl(28,100,232,1)        |28,100,13,99714.20012^10.105.40.74^*     |[R:N-H:0,N:3,L:0,V:0,Z:0,D:0]  ConferenceId=485031105 Locale =33 Country =63 AnnId =36 AnnAckReq=0 AnnPlayMode=2 HearingMask=0
62753748.001 |16:32:58.443 |AppInfo  |AnnDControl - star_StationOutputStationStartAnnouncement ConferenceID: 485031105, TCPPid = [28.100.13.419] myIP: 1028690a (10.105.40.16)
So here are my suggestions:
1. Restart CUCM service
2. Restart IPVDMS service
3. You can try using sip for integration  but if this behaviour continues, then it wont make any difference
Please rate all useful posts
Thanks for the suggestions. I restarted the two mentioned services but no difference was observed in behaviour.
At least I have a better idea of what's going on with this. In your opinion does this look like a bug? Or is it still possible I've managed to misconfigure something?
Anthony
