No secondary or ring back tone on dailing any number
stanzin
We have a sip trunk as the gateway
I am able to dial any number but especially for international calls it will take almost 15-18 sec to connect. I don't get a sec or a ring back tone.
Checked the Route plan report and all RP & TP starting with 9 has "Provide outside Dial Tone" enabled.
Here's a copy of the sip messages
Aug  9 17:19:28.458: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:90019088873090@10.74.66.5:5060 SIP/2.0
Via: SIP/2.0/TCP 10.167.131.33:5060;branch=z9hG4bK6d35f92b76b51d
From: <sip:20382@10.167.131.33>;tag=57197010~a6b8e9be-4836-49e6-b65d-1c212bf73946-117107293
To: <sip:90019088873090@10.74.66.5>
Date: Thu, 09 Aug 2018 17:19:28 GMT
Call-ID: 5d9cd580-b6c177a0-479e85-2183a70a@10.167.131.33
Supported: timer,resource-priority,replaces
Min-SE:  1800
User-Agent: Cisco-CUCM10.5
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Expires: 180
Allow-Events: presence, kpml
Supported: X-cisco-srtp-fallback,X-cisco-original-called
Call-Info: <sip:10.167.131.33:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
Call-Info: <urn:x-cisco-remotecc:callinfo>;x-cisco-video-traffic-class=VIDEO_UNSPECIFIED
Cisco-Guid: 1570559360-0000065536-0000180993-0562276106
Session-Expires:  1800
P-Asserted-Identity: <sip:20382@10.167.131.33>
Remote-Party-ID: <sip:20382@10.167.131.33>;party=calling;screen=yes;privacy=off
Contact: <sip:20382@10.167.131.33:5060;transport=tcp>
Max-Forwards: 70
Content-Length: 0
Aug  9 17:19:28.462: //25510/5D9CD5800002/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Thu, 09 Aug 2018 18:19:28 CST
CSeq: 101 INVITE
Allow-Events: kpml, telephone-event
Server: Cisco-SIPGateway/IOS-15.5.3.S6
Content-Length: 0
Aug  9 17:19:32.853: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 183 Session Progress
To: <sip:90019088873090@10.74.66.5>;tag=9B3BBDC-1E57
CSeq: 101 INVITE
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Remote-Party-ID: <sip:0019088873092@10.74.66.5>;party=called;screen=no;privacy=off
Contact: <sip:90019088873090@10.74.66.5:5060;transport=tcp>
Supported: sdp-anat
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 335
v=0
o=CiscoSystemsSIP-GW-UserAgent 720 2571 IN IP4 10.74.66.5
s=SIP Call
c=IN IP4 10.74.66.5
t=0 0
m=audio 9088 RTP/AVP 0 18 100 101
c=IN IP4 10.74.66.5
a=rtpmap:0 PCMU/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:100 X-NSE/8000
a=fmtp:100 192-194
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
Sent:
SIP/2.0 200 OK
CSeq: 101 INVITE
Supported: replaces
Supported: sdp-anat
Require: timer
Session-Expires:  1800;refresher=uac
Supported: timer
Content-Length: 335
v=0
s=SIP Call
c=IN IP4 10.74.66.5
t=0 0
c=IN IP4 10.74.66.5
a=fmtp:18 annexb=no
a=fmtp:100 192-194
a=fmtp:101 0-16
a=ptime:20
Aug  9 17:19:32.970: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:90019088873090@10.74.66.5:5060;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 10.167.131.33:5060;branch=z9hG4bK6d36104563566f
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 249
v=0
o=CiscoSystemsCCM-SIP 57197010 1 IN IP4 10.167.131.33
s=SIP Call
c=IN IP4 10.86.102.47
b=TIAS:64000
b=CT:64
b=AS:64
t=0 0
m=audio 24670 RTP/AVP 0 101
a=ptime:20
a=fmtp:101 0-15
Aug  9 17:19:59.584: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:90019088873090@10.74.66.5:5060;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 10.167.131.33:5060;branch=z9hG4bK6d363b5f3adf0a
Max-Forwards: 70
CSeq: 102 BYE
Reason: Q.850;cause=16
Content-Length: 0
Aug  9 17:19:59.614: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Thu, 09 Aug 2018 18:19:59 CST
CSeq: 102 BYE
P-RTP-Stat: PS=1329,OS=265800,PR=1261,OR=252200,PL=0,JI=3,LA=0,DU=26
Content-Length: 0
Jaime Valencia
You need to check the whole dial plan to find out what you could be matching, and not just the RPs/TPs.
If all the possible RPs and TPs have the secondary dial tone checked, then that means something else is being matched.
Use DNA or route plan report.
java
if this helps, please rate
Jaime, thanks for your response
Yes, I checked the call routing and it looked good on my side
I did added "voice call send-alert" and the below command ( under the pots dial peer) which was missing from my config it still didn't fixed my issue, but it did reduce the wait time from 15 sec to 7 sec.
progress_ind alert enable 8
progress_ind connect enable 8
progress_ind progress enable 8
Any suggestions ?
