No SIP messages to ITSP
smartns04
I have the following setup.
ITSP <---> CUBE (4321) <---> CUCM.
I am on the initial setup and trying to register CUBE with ITSP. However when I give the sip-ua commands i dont see any SIP messages for register. Instead I am getting the following output from debug ccsip all.
Jul 16 10:27:16.062: //-1/xxxxxxxxxxxx/SIP/Info/notify/262144/ccsip_register_cred_user: Sending msg type 2 to register process from parser for user +30XXXXXXXXXX
Jul 16 10:27:16.062: %PARSE_RC-4-PRC_NON_COMPLIANCE: ` credentials number +30XXXXXXXXXX username +30XXXXXXXXXX@ims.otenet.gr password XXXXXXXXX realm ims.otenet.gr'
Jul 16 10:27:16.063: //-1/xxxxxxxxxxxx/SIP/Info/notify/262144/ccsip_spi_register_process_e164_registration: CCSIP_REGISTER:: e164 number (+30XXXXXXXXXX): tenant tag (0)
Jul 16 10:27:16.063: //-1/xxxxxxxxxxxx/SIP/Info/critical/4096/ccsip_register_search_e164_table: ****No entry found in E164 Table
Jul 16 10:27:16.640: //-1/xxxxxxxxxxxx/SIP/Info/notify/262144/ccsip_register_reset_dns_cache: CCSIP_REGISTER:: registrar 0 DNS resolved addr reset
Jul 16 10:27:16.641: //-1/xxxxxxxxxxxx/SIP/Info/notify/262144/ccsip_spi_register_update_e164_registrations: CCSIP_REGISTER:: e164 number (+30XXXXXXXXXX) event (1)
Jul 16 10:27:16.641: //-1/xxxxxxxxxxxx/SIP/Info/critical/4096/ccsip_register_search_e164_table: ****No entry found in E164 Table
Jul 16 10:27:16.641: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/ccsip_spi_register_get_rcb: Getting New RCB [0x7FFB283303F8]
Jul 16 10:27:16.641: //-1/xxxxxxxxxxxx/SIP/Info/verbose/512/ccsip_get_vrf_from_sip_bind: vrfid 0 for tag 0, sip_vrfid 0, voice_vrfid 0
Jul 16 10:27:16.641: //-1/xxxxxxxxxxxx/SIP/Info/critical/262144/ccsip_spi_outgoing_register: Process CCSIP_SPI_CONTROL not UP yet; send no Register msg
Jul 16 10:27:16.641: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_register_delete_from_e164_table:Invalid Entry for search key
Jul 16 10:27:16.641: //-1/xxxxxxxxxxxx/SIP/Info/verbose/262144/ccsipGetCCBFromRCB: Retrived CCB pointer [0x0]
Jul 16 10:27:16.641: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/ccsip_spi_register_free_rcb: Freeing rcb [0x7FFB283303F8]
On show process | i CCSIP_SPI i dont see any process for CCSIP_SPI_CONTROL.
I have tried multiple IOS.
I used the same configuration on a 881 and it registered with the ITSP at once.
Any idea what I am missing?
Attached the configuration.
smartns04
Just to update. I have opened TAC and it seems that you need to create a dial-peer first, for the CCSIP_SPI_CONTROL service to come up and then proceed with the sip-ua configuration.
7 Replies 7
R0g22
Interesting. What IOS have you tried ? Upgrade to the latest version, 16.8
Hi Nipun,
I have used 16.03.06,16.06.04, 16.07.02 which are the recommended and also i think it came with 16.04.02. As per your suggestion i just tried 16.8 but still getting the same debug output.
Can you try removing you SIP-UA config and re-configuring it ? It has helped me in the past.
Abhay Singh Reyal
The Only Way To Do Great Work Is To Love What You Do. If You Haven’t Found It Yet, Keep Looking. Don’t Settle
Hi Abhay,
I have done that several times but no luck.
Have you tried:
Debug ccsip non-call
Or
Debug ccsip all
Just a thought.
smartns04
What you need is your SIP bind statement and ideally you will add that to your dial-peer. What is happening is that your gateway cant connect to the ITSP IP address because its trying to originate the SIP request from a wrong interface due to the fact you do not have the correct SP bind statement. I just resolved similar issue for a colleague at work
Please rate all useful posts
