01-04-2016 06:58 AM - edited 03-17-2019 05:23 AM
Today I reset phone 8861 to default setting(Menu -> Admin Settings -> Reset settings -> Reset device).
After this operation phone are reboot but I see statement: "Welcome, enter activation code or service domain".
Anyone had a similar message? Which code I need to restore woking phone ?
Solved! Go to Solution.
01-04-2016 07:06 AM
This is because there is no TFTP option defined hence the phone assumes it needs to connect over MRA. Make sure phone gets TFTP option 150 from DHCP server or set it up manually on the phone.
01-04-2016 07:06 AM
01-05-2016 12:46 AM
It was problem with TFTP server. Thank you for help.
02-09-2017 08:05 AM
Agreed. When the phone comes out of the box it doesn't have much to go off of unless Option 150 is configured on the switch properly.
I configured TFTP manually on the phone to point to my TFTP server and all was good in a matter of minutes.
09-01-2017 09:23 AM
Hey, I just bought this phone and having the same issue. How did you set it up manually on the phone?
01-23-2018 01:15 AM
On your phone, Settings-->Admin Settings-->Network Setup-->ipv4/ipv6-->Alternate TFTP= yes, and give ip address of your TFTP server. Hope this works
06-25-2018 01:24 PM
Hello everyone,
I'm new to the blog. I'm having this issue on the Welcome Screen is asking me to enter the Activation code or Service domain. I checked and TFTP are good I reset the device via settings and still asking for code any suggestions.
05-30-2025 01:48 PM
Having the same issue
05-30-2025 09:16 PM
If you get this message it means that the phone isn’t able pick up its configuration. Make sure that the DHCP scope used to provide an IP address to the device contains Option 150 and that it is configured to provide the IP of your TFTP server(s) and that the device is configured, with the appropriate phone model and directory number, in your Communications Manager.
07-24-2018 12:00 AM
I have the same problem now, but i have not TFTP server. Or i am not sure what is TFTP server.
Maybe i should put there the IP of my Vigor VoIP center or?
07-24-2018 12:54 AM
The TFTP server is where the phone is going to pick up its configuration file from. The file is in the form of SEP<mac address>.cnf.xml. This configuration file will contain the Call processing server where the phone should register to. The phone reads this file and sends a REGISTER message to the call processing server to register to it.
07-24-2018 12:55 AM
The TFTP server is where the phone is going to pick up its configuration file from. The file is in the form of SEPmac address.cnf.xml. This configuration file will contain the Call processing server where the phone should register to. The phone reads this file and sends a REGISTER message to the call processing server to register to it.
06-22-2018 08:41 AM
I had a user having weird voice prompting for everything he did on his phone, and had him do a hard reset followed by Admin Setting, Reset all Settings which cleared up his problem. When I mentioned it to a coworker, he advised someone told him about this secret way of activating/deactivating it which can be used as a prank. With an idle 8861 (etc.) hit the select ring enter button in the center three times (to the speed of saying "1, 2, 3.). This activates Voice Prompting for all your activity. After you complete testing and disconnect your phone call, follow the same procedure to hit the center select button three times to deactivate this feature. Google did not find this secret method, but perhaps it is not documented.
Chris
06-22-2018 09:45 AM
My engineer just advised me this new feature is called Voice Feedback and was added to recent firmware to assist vision impaired users. It can be enabled/disabled via the phone’s Accessibility settings menu or by triple tapping a session key. It’s purely a phone setting and is not controlled whatsoever by CallManager.
We’ve had several users accidentally enable this already.
Chris
