no SRV Command in ISR 4431
hariharan.s
Hi All,
In 39XX routers we can create the redundancy for UDP like following
ip host _sip._udp.example.abc.com srv 2 10 5060 example1.abc.com
ip host _sip._udp.example.abc.com srv 1 10 5060 example2.abc.com
but in ISR 44XX i could not see srv as a category under ip host
Any thoughts please..
With Regards
Hari>S
Dennis Mink
Yes this is possible,
check out
http://ciscoshizzle.blogspot.com.au/2013/05/using-srv-records-for-redundancy-and.html
Please remember to rate useful posts, by clicking on the stars below.
Ayodeji Okanlawon
Hariharan,
That sounds really strange. Cisco gateways have always supported DNS SRV configuration within IOS. Perhaps you don't have the right feature set
Please rate all useful posts
