Hi!
I need to permanently disable noise suppression in the IP Communicator (The one in Preferences > Audio > Advanced > Noise Suppression). Currently the setting is being reset at every restart. Where do I find the registry value for that? I've looked in \HKEY_USERS\user\SOFTWARE\Cisco Systems, Inc.\Communicator. I found basically every setting apart from Noise Suppression. Is there a value somewhere, say "EnableNoiseSuppression" so I can just set it to 0?
