01-25-2012 08:59 AM - edited 03-16-2019 09:12 AM
I have a third party app connected via a SIP trunk to me CUCM 8.6.2 system.
The app receives a call, makes a second call back to CUCM, then issues a SIP REFER to try to get CUCM to transfer the call, so the app can get out of the way.
However, the app gets back a "404 Not Found" from CUCM.
Any suggestions as to how to troubleshoot this ? I've looked at the SIP traces on CUCM, and I can't see anything jumping out at me.
GTG
Solved! Go to Solution.
01-25-2012 09:11 AM
Hi Gordon
Can you look at your SIP trunk on CUCM
Have you set a CSS in this field
May help.
Alex
01-25-2012 09:11 AM
Hi Gordon
May help.
Alex
01-26-2012 12:12 AM
Thanks for that. Works like a charm.
Now for the follow-up questions
1 - Why does a SIP trunk need a reroute calling search space for transfers to work, but a phone (which also has the option for a reroute CSS) doesn't ?
2 - Why would you want different CSSs for normal inbound calls, and for transfered calls ?
3 - What's the difference between the Rerouting CSS & the "Out-of-dialog Refer CSS" ?
GTG
