Nortel Meridian M3904 phones with CUCM
muhammad.cis
One of our client is planning to migrate from Nortel PBX system to CUCM. They are currently using Nortel Meridian Digital Telephones [M3902, M3903, M3904].
http://www.nortelphones.net/phones.html?id=M3904-NTMN34
Can these phone be used with CUCM?
Muhammad
Vipul Jindal
Muhammad,
i dont think they will.....if these support SIP protocol than you can give it a short!!
thanks,
Vipul Jindal
Brandon Svec
Level 7
Level 7
You realize those are not even IP phones, right?
If you must make them work it is theoretically possible with this:
http://www.citel.com/Products/EXTender/suite.asp
In reality, it would likely cost more to keep the old phones, buy these units and pay for the labor to configure and install them then to just buy Cisco IP phones.
You may want to investigate tie lines between the Nortel PBX and CUCM, that is a common migration scenario.
-- please remember to rate and mark answered helpful posts --
