Not Able to Make Outbound Calls Through H323 Gateway
Jacob Webb
I have 3 BRIs on a 2911 connected to CUCM 8.6.2 via H323.
Inbound calls work fine, but I get a busy tone when trying to dial out.  Here's the output of debug voip ccapi inout:
*Jan 25 07:07:51.559: //-1/001809BD0200/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=Daisuke Sugimori - 4434
   ----- ccCallInfo IE subfields -----
   cisco-ani=0238290156
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=90238282311
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
*Jan 25 07:07:51.559: //-1/001809BD0200/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x3CB84A90, Call Info(
   Calling Number=0238290156,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=90238282311(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=101, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=13
*Jan 25 07:07:51.559: //-1/001809BD0200/CCAPI/ccCheckClipClir:
   In: Calling Number=0238290156(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
   Out: Calling Number=0238290156(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
*Jan 25 07:07:51.559: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Jan 25 07:07:51.559: :cc_get_feature_vsa malloc success
*Jan 25 07:07:51.559:  cc_get_feature_vsa count is 1
*Jan 25 07:07:51.559: :FEATURE_VSA attributes are: feature_name:0,feature_time:553875016,feature_id:13
*Jan 25 07:07:51.559: //13/001809BD0200/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=0238290156(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=90238282311(TON=Unknown, NPI=Unknown))
*Jan 25 07:07:51.559: //13/001809BD0200/CCAPI/cc_process_call_setup_ind:
   Event=0x3CE4FFE8
*Jan 25 07:07:51.559: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 90238282311
*Jan 25 07:07:51.559: //13/001809BD0200/CCAPI/ccCallSetContext:
   Context=0x39E84764
   >>>>CCAPI handed cid 13 with tag 101 to app "_ManagedAppProcess_Default"
*Jan 25 07:07:51.559: //13/001809BD0200/CCAPI/ccCallProceeding:
*Jan 25 07:07:51.559: //13/001809BD0200/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=9, Params=0x39E85C24, Progress Indication=NULL(0)
*Jan 25 07:07:51.559: //13/001809BD0200/CCAPI/cc_fill_tg_params:
   Not a cic call
   Trunk Group Select Interface Success;
   Interface=0x3CFCB7DC, Selected Interface=1, Selected DSL=0
*Jan 25 07:07:51.559: //13/001809BD0200/CCAPI/ccCheckClipClir:
   Destination Pattern=9T, Called Number=0238282311, Digit Strip=TRUE
   Called Number=0238282311(TON=Unknown, NPI=Unknown),
   Redirect Number=, Display Info=
   Account Number=Daisuke Sugimori - 4434, Final Destination Flag=TRUE,
   Guid=001809BD-5963-312E-0200-1C030A5D7C26, Outgoing Dial-peer=9
*Jan 25 07:07:51.559: //13/001809BD0200/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=0238282311
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
*Jan 25 07:07:51.563: //13/001809BD0200/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x3CFCB7DC, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=0238290156,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=0238282311(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=9, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=BRI-GROUP, tg_label_flag=2, Application Call Id=)
*Jan 25 07:07:51.563: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Jan 25 07:07:51.563: :cc_get_feature_vsa malloc success
*Jan 25 07:07:51.563:  cc_get_feature_vsa count is 2
*Jan 25 07:07:51.563: :FEATURE_VSA attributes are: feature_name:0,feature_time:553874792,feature_id:14
*Jan 25 07:07:51.563: //14/001809BD0200/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
*Jan 25 07:07:51.563: //13/001809BD0200/CCAPI/ccCallSetupRequest:
   Trunk Group Call Setting;
   Call Entry(Retry Count=0, Voice Class Cause Code=0)
*Jan 25 07:07:51.563: //14/001809BD0200/CCAPI/ccCallSetContext:
   Context=0x39E85BD4
*Jan 25 07:07:51.563: //13/001809BD0200/CCAPI/ccSaveDialpeerTag:
*Jan 25 07:07:51.563: //13/001809BD0200/CCAPI/cc_api_modify_tgt_cid_call_active_record:
   Target Trkgrp Route Label=BRI-GROUP, tg_label_flag=TRUE, Call Id=0xD
*Jan 25 07:07:51.603: //14/001809BD0200/CCAPI/cc_api_call_proceeding:
   Interface=0x3CFCB7DC, Progress Indication=NULL(0)
*Jan 25 07:07:51.763: //14/001809BD0200/CCAPI/cc_api_call_disc_prog_ind:
   Cause Value=17, Progress Indication=INBAND(8), Interface=0x3CFCB7DC
   Event(Progress Indication=0x8), Call Entry(Responsed=TRUE)
*Jan 25 07:07:51.763: //13/001809BD0200/CCAPI/ccCallDiscProgInd:
   Call Entry(Responsed=TRUE, Disconnect Cause=17)
*Jan 25 07:07:51.763: //13/001809BD0200/CCAPI/ccConferenceCreate:
   (confID=0xFFFFFFFF, callID1=0xD, gcid=0-0-0-0, tag=0x0)
*Jan 25 07:07:51.767: //14/001809BD0200/CCAPI/ccConferenceCreate:
   (confID=0xFFFFFFFF, callID2=0xE, gcid=0-0-0-0, tag=0x0)
*Jan 25 07:07:51.767: //13/001809BD0200/CCAPI/ccConferenceCreate:
   Conference Id=0xFFFFFFFF, Call Id1=13, Call Id2=14, Tag=0x0
*Jan 25 07:07:51.767: //13/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Jan 25 07:07:51.767: cc_api_get_xcode_stream : 4819
*Jan 25 07:07:51.767: //13/001809BD0200/CCAPI/cc_api_bridge_done:
   Conference Id=0x6, Source Interface=0x3CB84A90, Source Call Id=13,
   Destination Call Id=14, Disposition=0x0, Tag=0x0
*Jan 25 07:07:51.767: //14/001809BD0200/CCAPI/cc_api_bridge_done:
   Conference Id=0x6, Source Interface=0x3CFCB7DC, Source Call Id=14,
   Destination Call Id=13, Disposition=0x0, Tag=0xFFFFFFFF
*Jan 25 07:07:51.767: //13/001809BD0200/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x6, Destination Call Id=14)
   Call Entry(Conference Id=0x6, Destination Call Id=13)
*Jan 25 07:07:51.767: confID:0x6; callEntry1 callID1:0xD, type:1; callEntry2 callID2:0xE, type:6
*Jan 25 07:07:51.767: //14/001809BD0200/CCAPI/cc_api_caps_ind:
   Destination Interface=0x3CB84A90, Destination Call Id=13, Source Call Id=14,
   Caps(Codec=0x1, Fax Rate=0x1, Fax Version:=0, Vad=0x1,
   Modem=0x2, Codec Bytes=20, Signal Type=3)
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
*Jan 25 07:07:51.767: //13/001809BD0200/CCAPI/ccCallNotify:
   Data Bitmask=0x7, Call Id=13
*Jan 25 07:07:51.767: //14/001809BD0200/CCAPI/cc_api_get_called_ccm_detected:
   CallInfo(ccm detected=0)
*Jan 25 07:07:51.767: //13/001809BD0200/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x6, Call Id1=13, Call Id2=14
*Jan 25 07:07:51.823: //13/001809BD0200/CCAPI/cc_api_caps_ind:
   Destination Interface=0x3CFCB7DC, Destination Call Id=14, Source Call Id=13,
   Caps(Codec=0x4, Fax Rate=0x2, Fax Version:=0, Vad=0x1,
   Modem=0x2, Codec Bytes=20, Signal Type=2)
*Jan 25 07:07:51.827: //13/001809BD0200/CCAPI/cc_api_caps_ack:
   Caps(Codec=g729r8(0x4), Fax Rate=FAX_RATE_VOICE(0x2), Fax Version:=0, Vad=OFF(0x1),
   Modem=ON(0x2), Codec Bytes=20, Signal Type=2, Seq Num Start=5864)
*Jan 25 07:07:51.827: //14/001809BD0200/CCAPI/cc_api_caps_ack:
*Jan 25 07:07:51.827: //14/001809BD0200/CCAPI/cc_api_voice_mode_event:
   Call Id=14
rtr-yonezawa2-1#
   Call Entry(Context=0x39E85BD4)
rtr-yonezawa2-1#
*Jan 25 07:07:55.323: //13/001809BD0200/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x3CB84A90, Call Id=13
   Call Entry(Responsed=TRUE, Cause Value=17, Retry Count=0)
*Jan 25 07:07:55.323: //13/001809BD0200/CCAPI/ccConferenceDestroy:
   Conference Id=0x6, Tag=0x0
*Jan 25 07:07:55.323: confID:0x6; callEntry1 callID1:0xD, type:1; callEntry2 callID2:0xE, type:6
*Jan 25 07:07:55.323: //13/001809BD0200/CCAPI/cc_api_bridge_drop_done:
*Jan 25 07:07:55.323: //14/001809BD0200/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=13, Disposition=0x0, Tag=0x0
*Jan 25 07:07:55.323: //13/001809BD0200/CCAPI/cc_generic_bridge_done:
*Jan 25 07:07:55.323: //14/001809BD0200/CCAPI/ccCallDisconnect:
   Cause Value=17, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=17)
   Cause Value=17, Call Entry(Responsed=TRUE, Cause Value=17)
*Jan 25 07:07:55.323: //14/001809BD0200/CCAPI/cc_api_get_transfer_info:
   Transfer Number=NULL
*Jan 25 07:07:55.323: //13/001809BD0200/CCAPI/ccCallDisconnect:
*Jan 25 07:07:55.323: //13/001809BD0200/CCAPI/cc_api_get_transfer_info:
*Jan 25 07:07:55.331: //13/001809BD0200/CCAPI/cc_api_get_transfer_info:
*Jan 25 07:07:55.331: //13/001809BD0200/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x3CB84A90, Tag=0x0, Call Id=13,
   Call Entry(Disconnect Cause=17, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
*Jan 25 07:07:55.331: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Jan 25 07:07:55.335: :cc_free_feature_vsa freeing 21037640
*Jan 25 07:07:55.335: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Jan 25 07:07:55.335:  vsacount in free is 1
*Jan 25 07:07:55.343: //14/001809BD0200/CCAPI/cc_api_call_disc_cause_update:
   Cause Value=17
   Call Entry(Disconnect Cause=17)
*Jan 25 07:07:55.343: //14/001809BD0200/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x3CFCB7DC, Tag=0x0, Call Id=14,
   tg for this call is BRI-GROUP success/fail is 1
*Jan 25 07:07:55.343: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
rtr-yonezawa2-1#
*Jan 25 07:07:55.343: :cc_free_feature_vsa freeing 21037560
*Jan 25 07:07:55.343:  vsacount in free is 0
OK, in that case, the one thing I can think of is calling/called number format & type.
Calling Party Number i = 0x0081, '0238290156'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '0238282311'
if the format & type are correct, then again the pointer goes towards your provider.
Also someone else from this forum would be able to help you if I missed out anything in this case.
Please rate all the useful posts
//Suresh Please rate all the useful posts.
10 Replies 10
Hi Jacob,
I see the call is disconnected with "Cause Value=17" which indicates user busy and it is released by the pstn leg.
you many need to talk to your provider on this.
Also I see Codec=g729r8(0x4) has been negotiated for that outbound call.  have you set the region settings between GW & Phones to negoatiate G729?
Could you please post your running config with debug isdn q931 & debug voice ccapi inout again for a test call?
Here are the call logs yous asked for.  I did notice thre was a problem with the region and I fixed that, but the issue is still the same.  I did the debug voice ccapi inout and debug isdn q931 on 2 different calls (same origination and destination numbers) to help keep them clear.
Oops... for got the log.  LOL.
*Jan 25 08:42:30.063: //-1/80B9FBF50400/CCAPI/cc_api_display_ie_subfields:
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=90238282311
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
*Jan 25 08:42:30.067: //-1/80B9FBF50400/CCAPI/cc_api_call_setup_ind_common:
rget Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=17
*Jan 25 08:42:30.067: //-1/80B9FBF50400/CCAPI/ccCheckClipClir:
*Jan 25 08:42:30.067: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Jan 25 08:42:30.067: :cc_get_feature_vsa malloc success
*Jan 25 08:42:30.067:  cc_get_feature_vsa count is 1
*Jan 25 08:42:30.067: :FEATURE_VSA attributes are: feature_name:0,feature_time:553875016,feature_id:17
*Jan 25 08:42:30.067: //17/80B9FBF50400/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
*Jan 25 08:42:30.067: //17/80B9FBF50400/CCAPI/cc_process_call_setup_ind:
   Event=0x3CE4FFE8
*Jan 25 08:42:30.067: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
*Jan 25 08:42:30.067: //17/80B9FBF50400/CCAPI/ccCallSetContext:
   Context=0x39E89924
   >>>>CCAPI handed cid 17 with tag 101 to app "_ManagedAppProcess_Default"
*Jan 25 08:42:30.067: //17/80B9FBF50400/CCAPI/ccCallProceeding:
*Jan 25 08:42:30.067: //17/80B9FBF50400/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=9, Params=0x39E8ADE4, Progress Indication=NULL(0)
*Jan 25 08:42:30.067: //17/80B9FBF50400/CCAPI/cc_fill_tg_params:
   Not a cic call
*Jan 25 08:42:30.067: //17/80B9FBF50400/CCAPI/ccCheckClipClir:
   Guid=80B9FBF5-8879-312E-0400-1E030A5D7C26, Outgoing Dial-peer=9
*Jan 25 08:42:30.067: //17/80B9FBF50400/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=0238282311
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
*Jan 25 08:42:30.067: //17/80B9FBF50400/CCAPI/ccIFCallSetupRequestPrivate:
*Jan 25 08:42:30.067:  cc_get_feature_vsa count is 2
*Jan 25 08:42:30.067: :FEATURE_VSA attributes are: feature_name:0,feature_time:553874792,feature_id:18
*Jan 25 08:42:30.071: //18/80B9FBF50400/CCAPI/ccIFCallSetupRequestPrivate:
*Jan 25 08:42:30.071: //17/80B9FBF50400/CCAPI/ccCallSetupRequest:
*Jan 25 08:42:30.071: //18/80B9FBF50400/CCAPI/ccCallSetContext:
   Context=0x39E8AD94
*Jan 25 08:42:30.071: //17/80B9FBF50400/CCAPI/ccSaveDialpeerTag:
*Jan 25 08:42:30.071: //17/80B9FBF50400/CCAPI/cc_api_modify_tgt_cid_call_active_record:
   Target Trkgrp Route Label=BRI-GROUP, tg_label_flag=TRUE, Call Id=0x11
*Jan 25 08:42:30.111: //18/80B9FBF50400/CCAPI/cc_api_call_proceeding:
*Jan 25 08:42:30.283: //18/80B9FBF50400/CCAPI/cc_api_call_disc_prog_ind:
*Jan 25 08:42:30.283: //17/80B9FBF50400/CCAPI/ccCallDiscProgInd:
*Jan 25 08:42:30.283: //17/80B9FBF50400/CCAPI/ccConferenceCreate:
   (confID=0xFFFFFFFF, callID1=0x11, gcid=0-0-0-0, tag=0x0)
*Jan 25 08:42:30.283: //18/80B9FBF50400/CCAPI/ccConferenceCreate:
   (confID=0xFFFFFFFF, callID2=0x12, gcid=0-0-0-0, tag=0x0)
   Conference Id=0xFFFFFFFF, Call Id1=17, Call Id2=18, Tag=0x0
*Jan 25 08:42:30.283: //17/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Jan 25 08:42:30.283: cc_api_get_xcode_stream : 4819
*Jan 25 08:42:30.283: //17/80B9FBF50400/CCAPI/cc_api_bridge_done:
   Con
ference Id=0x8, Source Interface=0x3CB84A90, Source Call Id=17,
   Destination Call Id=18, Disposition=0x0, Tag=0x0
*Jan 25 08:42:30.283: //18/80B9FBF50400/CCAPI/cc_api_bridge_done:
   Conference Id=0x8, Source Interface=0x3CFCB7DC, Source Call Id=18,
   Destination Call Id=17, Disposition=0x0, Tag=0xFFFFFFFF
*Jan 25 08:42:30.283: //17/80B9FBF50400/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x8, Destination Call Id=18)
   Call Entry(Conference Id=0x8, Destination Call Id=17)
*Jan 25 08:42:30.283: confID:0x8; callEntry1 callID1:0x11, type:1; callEntry2 callID2:0x12, type:6
*Jan 25 08:42:30.287: //18/80B9FBF50400/CCAPI/cc_api_caps_ind:
   Destination Interface=0x3CB84A90, Destination Call Id=17, Source Call Id=18,
*Jan 25 08:42:30.287: //17/80B9FBF50400/CCAPI/ccCallNotify:
   Data Bitmask=0x7, Call Id=17
*Jan 25 08:42:30.287: //18/80B9FBF50400/CCAPI/cc_api_get_called_ccm_detected:
*Jan 25 08:42:30.287: //17/80B9FBF50400/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x8, Call Id1=17, Call Id2=18
*Jan 25 08:42:30.355: //17/80B9FBF50400/CCAPI/cc_api_caps_ind:
   Destination Interface=0x3CFCB7DC, Destination Call Id=18, Source Call Id=17,
   Caps(Codec=0x1, Fax Rate=0x2, Fax Version:=0, Vad=0x1,
   Modem=0x2, Codec Bytes=160, Signal Type=2)
*Jan 25 08:42:30.355: //17/80B9FBF50400/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Fax Version:=0, Vad=OFF(0x1),
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=7326)
*Jan 25 08:42:30.355: //18/80B9FBF50400/CCAPI/cc_api_caps_ack:
*Jan 25 08:42:30.359: //18/80B9FBF50400/CCAPI/cc_api_voice_mode_event:
   Call Id=18
   Call Entry(Context=0x39E8AD94)
*Jan 25 08:42:35.415: //17/80B9FBF50400/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x3CB84A90, Call Id=17
*Jan 25 08:42:35.415: //17/80B9FBF50400/CCAPI/ccConferenceDestroy:
   Conference Id=0x8, Tag=0x0
*Jan 25 08:42:35.415: confID:0x8; callEntry1 callID1:0x11, type:1; callEntry2 callID2:0x12, type:6
*Jan 25 08:42:35.415: //17/80B9FBF50400/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0x8, Source Interface=0x3CB84A90, Source Call Id=17,
*Jan 25 08:42:35.415: //18/80B9FBF50400/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=17, Disposition=0x0, Tag=0x0
*Jan 25 08:42:35.415: //17/80B9FBF50400/CCAPI/cc_generic_bridge_done:
*Jan 25 08:42:35.415: //18/80B9FBF50400/CCAPI/ccCallDisconnect:
*Jan 25 08:42:35.415: //18/80B9FBF50400/CCAPI/cc_api_get_transfer_info:
*Jan 25 08:42:35.415: //17/80B9FBF50400/CCAPI/ccCallDisconnect:
*Jan 25 08:42:35.415: //17/80B9FBF50400/CCAPI/cc_api_get_transfer_info:
*Jan 25 08:42:35.423: //17/80B9FBF50400/CCAPI/cc_api_get_transfer_info:
*Jan 25 08:42:35.427: //17/80B9FBF50400/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x3CB84A90, Tag=0x0, Call Id=17,
*Jan 25 08:42:35.427: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Jan 25 08:42:35.427: :cc_free_feature_vsa freeing 21037640
*Jan 25 08:42:35.427:  vsacount in free is 1
*Jan 25 08:42:35.431: //18/80B9FBF50400/CCAPI/cc_api_call_disc_cause_update:
   Cause Value=17
*Jan 25 08:42:35.435: //18/80B9FBF50400/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x3CFCB7DC, Tag=0x0, Call Id=18,
*Jan 25 08:42:35.435: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Jan 25 08:42:35.435: :cc_free_feature_vsa freeing 21037560
*Jan 25 08:42:35.435:  vsacount in free is 0
*Jan 25 08:44:39.127: ISDN BR0/0/0 Q931: Applying typeplan for sw-type 0x9 is 0x0 0x0, Calling num 0238290156
*Jan 25 08:44:39.127: ISDN BR0/0/0 Q931: Sending SETUP  callref = 0x0008 callID = 0x800C switch = ntt interface = User
*Jan 25 08:44:39.127: ISDN BR0/0/0 Q931: TX -> SETUP pd = 8  callref = 0x08
        Bearer Capability i = 0x8090A2
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0x89
                Exclusive, B1
        Sending Complete
*Jan 25 08:44:39.163: ISDN BR0/0/0 Q931: RX <- CALL_PROC pd = 8  callref = 0x88
        Channel ID i = 0x89
                Exclusive, B1
*Jan 25 08:44:39.363: ISDN BR0/0/0 Q931: RX <- DISCONNECT pd = 8  callref = 0x88
        Cause i = 0x8291 - User busy
        Progress Ind i = 0x8288 - In-band info or appropriate now available
*Jan 25 08:44:45.047: ISDN BR0/0/0 Q931: TX -> RELEASE pd = 8  callref = 0x08
        Cause i = 0x80E4 - Invalid information element contents
*Jan 25 08:44:45.071: ISDN BR0/0/0 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x88
        Cause i = 0x82E4 - Invalid information element contents
Building configuration...
Current configuration : 9102 bytes
! Last configuration change at 07:00:52 UTC Sat Jan 25 2014
version 15.2
hostname XXXXXXXXX
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
network-clock-participate wic 0
network-clock-participate wic 1
ip cef
ip dhcp excluded-address 10.10.10.1
ip dhcp pool ccp-pool
import all
network 10.10.10.0 255.255.255.248
default-router 10.10.10.1
lease 0 2
ip domain name XXXXXXXX.com
no ipv6 cef
stcapp ccm-group 10
stcapp
isdn switch-type ntt
trunk group BRI-GROUP
hunt-scheme sequential
translation-profile incoming DID-INCOMING
crypto pki trustpoint TP-self-signed-3629130497
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3629130497
revocation-check none
rsakeypair TP-self-signed-3629130497
crypto pki certificate chain TP-self-signed-3629130497
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33363239 31333034 3937301E 170D3133 31303236 30323130
  30335A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 36323931
  33303439 3730819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100B7A5 C4CFD210 5771D7CD 7088B80D 8D346722 93589E40 F372D6CC 1F9265C4
  F7EE499B 570D1935 AB6423E1 8ACFE3CA 79246831 739911EC E2624051 FD58FBEF
  43F3135D 9E238A8A 995F2ECC ABAADEE5 3BE7F891 4705EE9C 91E94706 1D7EF061
  D1E43934 A9DED8CB E955EA06 D2C03F7C 917246BF AEE96A14 6C66E256 97214BE7
  96A90203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 14FAF06E F4D12B28 78C26F41 6E31244A 0071B558 56301D06
  03551D0E 04160414 FAF06EF4 D12B2878 C26F416E 31244A00 71B55856 300D0609
  2A864886 F70D0101 05050003 81810079 E3A71E50 ACA9AA87 0DFE2907 413DE5B0
  F808A5A1 0A5908C4 26E44AD4 A15992D2 57ACF39B 408F6B78 D6A8D2F2 04E5246D
  A374DC1D 1776001D 5423315C A4DD3555 3EF5874F AB822002 60B300C6 EAB23360
  1958C351 8591813B 63C328D6 FB9EC48A 7EB57887 A4CCE3A5 9949654F D96F737A
  31DF7E4E 23AB7DA7 4ED1A832 DB0F3B
        quit
voice-card 0
dspfarm
dsp services dspfarm
voice service voip
ip address trusted list
  ipv4 10.93.24.50
  ipv4 10.93.122.250
  ipv4 10.93.125.252
  ipv4 10.93.122.248
  ipv4 10.93.122.249
  ipv4 10.93.125.251
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol none
modem passthrough nse codec g711ulaw
sip
  bind control source-interface GigabitEthernet0/0
  bind media source-interface GigabitEthernet0/0
  rel1xx disable
  header-passing
  early-offer forced
  midcall-signaling passthru
voice class codec 99
codec preference 1 g711ulaw
codec preference 2 g729r8
voice translation-rule 1
rule 1 /^9/ //
voice translation-rule 2
rule 1 /.*0516$/ /4434/
rule 2 /.*0517$/ /4434/
rule 3 /.*0518$/ /4434/
rule 4 /.*0519$/ /4434/
rule 5 /.*1045$/ /4434/
voice translation-profile DID-INCOMING
translate called 2
voice translation-profile STRIP-9
translate called 1
license udi pid CISCO2911/K9 sn XXXXXXXXX
license accept end user agreement
hw-module pvdm 0/0
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
description Cisco VoIP LAN
ip address 10.93.123.254 255.255.255.0
ip helper-address 10.93.109.43
no ip redirects
no ip unreachables
no ip proxy-arp
load-interval 30
duplex full
speed 1000
h323-gateway voip interface
h323-gateway voip h323-id 10.93.125.252
h323-gateway voip bind srcaddr 10.93.123.254
interface GigabitEthernet0/1
description Cisco Office LAN
ip address 10.83.254.6 255.255.0.0
no ip redirects
no ip unreachables
no ip proxy-arp
load-interval 30
duplex full
speed 1000
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface BRI0/0/0
no ip address
isdn tei-negotiation first-call
isdn point-to-point-setup
isdn spid1 0
isdn spid2 0
isdn incoming-voice voice
isdn sending-complete
isdn static-tei 0
trunk-group BRI-GROUP
interface BRI0/0/1
no ip address
isdn spid1 0
isdn spid2 0
isdn static-tei 0
interface BRI0/1/0
no ip address
isdn spid1 0
isdn spid2 0
isdn static-tei 0
interface BRI0/1/1
no ip address
isdn spid1 0
isdn spid2 0
isdn static-tei 0
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 10.83.254.1
access-list 23 permit 10.10.10.0 0.0.0.7
control-plane
voice-port 0/0/0
timeouts ringing infinity
bearer-cap Speech
voice-port 0/0/1
bearer-cap Speech
voice-port 0/1/0
bearer-cap Speech
voice-port 0/1/1
bearer-cap Speech
mgcp profile default
sccp local GigabitEthernet0/0
sccp ccm 10.93.125.252 identifier 1 priority 1 version 7.0
sccp ccm 10.93.24.50 identifier 2 priority 2 version 7.0
sccp ccm 10.93.122.250 identifier 3 priority 3 version 7.0
sccp
sccp ccm group 10
bind interface GigabitEthernet0/0
associate ccm 1 priority 1
associate ccm 2 priority 2
associate ccm 3 priority 3
associate profile 20 register XXXX-ConfBr-HW
associate profile 33 register XXXX-XCode
dspfarm profile 33 transcode
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
codec g729r8
maximum sessions 16
associate application SCCP
dspfarm profile 20 conference
codec g729br8
codec g729r8
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
maximum sessions 2
dial-peer voice 9 pots
trunkgroup BRI-GROUP
translation-profile outgoing STRIP-9
destination-pattern 9T
incoming called-number .
dial-peer voice 101 voip
preference 1
destination-pattern 4...
session target ipv4:10.93.125.252
voice-class codec 99
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 102 voip
preference 2
session target ipv4:10.93.24.50
no vad
dial-peer voice 103 voip
preference 3
session target ipv4:10.93.122.250
no vad
dial-peer voice 1000 pots
service stcapp
port 0/0/0
dial-peer voice 1001 pots
service stcapp
port 0/0/1
dial-peer voice 1010 pots
service stcapp
port 0/1/0
dial-peer voice 1011 pots
service stcapp
port 0/1/1
gatekeeper
shutdown
telephony-service
srst mode auto-provision none
srst dn line-mode dual
max-ephones 58
max-dn 300
ip source-address 10.93.123.254 port 2000
timeouts interdigit 4
system message SRST MODE ACTIVE
time-zone 44
max-conferences 2 gain -6
transfer-system full-consult
secondary-dialtone 9
banner exec ^CC
This is the Entegris Yonezawa Factory 2 VoIP router rtr-yonezawa2-1.entegris.com
      Please report any problems to ehd_alerts@entegris.com
^C
banner login ^CC
                      Authorized Access Only
              This is the property of Entegris, Inc.
      Disconnect IMMEDIATELY if you are not an authorized user
^C
line con 0
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
access-class 10 in
exec-timeout 30 0
logging synchronous
no login
transport input telnet
transport output telnet
line vty 5 15
access-class 10 in
exec-timeout 30 0
logging synchronous
no login
scheduler allocate 20000 1000
end
Hi Jacod,
we are receiving disconnect from pstn indicating User Busy. Please have a word with your provider on this
Suresh.
Hi Suresh,
The carrier claims this should be functional.  I also have 4 more BRIs in another site across the street with the same configuration that is working.  Is there anything else you can think that I could try?
Jacob, if you have not changed any of your running config recently, then I would say it is something wrong with the provider side.
Please share the isdn debug with them and told them that we receive disconnect from provider side.
Hi Suresh,
This is a new install.
Thanks for the help.  The number format is correct, so if I don't get any other ideas by tomorrow morning I will call TAC and if they can't come up with anything I'll try the provider, just might be tough on a Sunday.
Hi Suresh, you were right.  The carrier needed a specific DID to be sent as the calling number.
