not able to make outgoing calls ( SIP/2.0 503 Service Unavailable)
monasir
Hi All,
Im facing problems with my Cisco ISR, only outgoing calls are failing incoming calls are working fine.
Ive tried several things
- disabled early offer
-enable/disable MTP in sip trunk
remove keepalive options in dial-peer.
However no success
Please find below sip messages.
CUBE-SCN00214#debug ccsip messages
SIP Call messages tracing is enabled
CUBE-SCN00214#term mopn n   on
CUBE-SCN00214#
007951: Mar 21 08:01:16: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:10.XX.XX.XX:5060 SIP/2.0
Via: SIP/2.0/UDP 10.XX.XX.XX:5060;branch=z9hG4bKa4dad5e151b8e
To: <sip:10.XX.XX.XX>
Date: Thu, 21 Mar 2019 12:01:16 GMT
Call-ID: 66cd380-c9317d0c-a4d73-a5d160a@10.XX.XX.XX
User-Agent: Cisco-CUCM12.0
CSeq: 101 OPTIONS
Contact: <sip:10.XX.XX.XX:5060>
Max-Forwards: 0
Content-Length: 0
007952: Mar 21 08:01:16: //28661/DD580AFDAC55/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:10.XX.XX.XX>;tag=A9C935C-1D36
Date: Thu, 21 Mar 2019 08:01:16 GMT
Server: Cisco-SIPGateway/IOS-15.5.3.S4b
CSeq: 101 OPTIONS
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Allow-Events: kpml, telephone-event
Accept: application/sdp
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Content-Type: application/sdp
Content-Length: 367
v=0
o=CiscoSystemsSIP-GW-UserAgent 2 8238 IN IP4 10.XX.XX.XX
s=SIP Call
c=IN IP4 10.XX.XX.XX
t=0 0
m=audio 0 RTP/AVP 18 0 8 9 4 2 15 3
m=image 0 udptl t38
a=T38FaxVersion:0
a=T38MaxBitRate:14400
a=T38FaxRateManagement:transferredTCF
a=T38FaxMaxBuffer:200
a=T38FaxMaxDatagram:320
a=T38FaxUdpEC:t38UDPRedundancy
007953: Mar 21 08:01:26: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:1234567@10.XX.XX.XX:5060 SIP/2.0
Via: SIP/2.0/UDP 10.XX.XX.XX:5060;branch=z9hG4bKa4db458195273
From: "ABC XX" <sip:1234567@10.XX.XX.XX>;tag=845312~8eaa9458-4704-4a2a-b676-2e79543f0091-19504056
To: <sip:1234567@10.XX.XX.XX>
Date: Thu, 21 Mar 2019 12:01:26 GMT
Call-ID: bca1e00-c9317d15-a4d7a-a5d160a@10.XX.XX.XX
Min-SE: 1800
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Expires: 180
Allow-Events: presence, kpml
Supported: X-cisco-srtp-fallback,X-cisco-original-called
Call-Info: <sip:10.XX.XX.XX:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
Call-Info: <urn:x-cisco-remotecc:callinfo>;x-cisco-video-traffic-class=DESKTOP
Session-ID: 00007aa600105000a00000090ffe0001;remote=00000000000000000000000000000000
Cisco-Guid: 0197795328-0000065536-0000000129-0173872650
Session-Expires: 1800
P-Asserted-Identity: "ABC XX" <sip:1234567@10.XX.XX.XX>
Remote-Party-ID: "ABC XX" <sip:1234567@10.XX.XX.XX>;party=calling;screen=yes;privacy=off
Contact: <sip:1234567@10.XX.XX.XX:5060>;video;audio;+u.sip!devicename.ccm.cisco.com="CSFJWEDERVOORT";bfcp
Max-Forwards: 69
Content-Length: 1440
v=0
o=CiscoSystemsCCM-SIP 845312 1 IN IP4 10.XX.XX.XX
s=SIP Call
c=IN IP4 192.168.73.20
b=TIAS:384000
b=AS:384
t=0 0
a=cisco-mari:v1
a=cisco-mari-rate
m=audio 19782 RTP/AVP 114 9 104 105 0 8 18 111 101
a=extmap:14/sendrecv http://protocols.cisco.com/timestamp#100us
a=rtpmap:114 opus/48000/2
a=rtpmap:9 G722/8000
a=rtpmap:104 G7221/16000
a=fmtp:104 bitrate=32000
a=rtpmap:105 G7221/16000
a=fmtp:105 bitrate=24000
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:111 X-ULPFECUC/8000
a=fmtp:111 max_esel=1420;m=8;max_n=32;FEC_ORDER=FEC_SRTP
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
m=video 27508 RTP/AVP 126 97 111
b=TIAS:384000
a=label:11
a=rtpmap:126 H264/90000
a=fmtp:126 profile-level-id=42E01F;packetization-mode=1;max-fs=3601;max-rcmd-nalu-size=32000;level-asymmetry-allowed=1
a=imageattr:126 recv [x=[32:1:1280],y=[18:1:720],par=1.7778,q=1.00]
a=rtpmap:97 H264/90000
a=fmtp:97 profile-level-id=42E01F;packetization-mode=0;max-fs=3601;level-asymmetry-allowed=1
a=imageattr:97 recv [x=[32:1:1280],y=[18:1:720],par=1.7778,q=1.00]
a=rtpmap:111 X-ULPFECUC/90000
a=content:main
a=recvonly
a=rtcp-fb:* ccm fir
a=rtcp-fb:* ccm tmmbr
a=rtcp-fb:* nack pli
m=application 38212 RTP/AVP 125
a=rtpmap:125 H224/4800
a=rtcp:38213
007954: Mar 21 08:01:26: //28663/0BCA1E000000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Thu, 21 Mar 2019 08:01:26 GMT
CSeq: 101 INVITE
Content-Length: 0
007955: Mar 21 08:01:26: //28663/0BCA1E000000/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <sip:1234567@10.XX.XX.XX>;tag=A9CBA82-207D
CSeq: 101 INVITE
Reason: Q.850;cause=0
Content-Length: 0
007956: Mar 21 08:01:26: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:1234567@10.XX.XX.XX:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
007957: Mar 21 08:01:46: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.22.93.20:5060;branch=z9hG4bKb995d792a52df
Date: Thu, 21 Mar 2019 12:01:46 GMT
Call-ID: 184e7680-c9317d2a-b9921-145d160a@10.22.93.20
CSeq: 101 OPTIONS
Contact: <sip:10.22.93.20:5060>
Max-Forwards: 0
Content-Length: 0
007958: Mar 21 08:01:46: //28673/EF889031AC60/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:10.XX.XX.XX>;tag=A9D0A91-1324
Date: Thu, 21 Mar 2019 08:01:46 GMT
CSeq: 101 OPTIONS
Content-Length: 370
v=0
o=CiscoSystemsSIP-GW-UserAgent 5204 9182 IN IP4 10.XX.XX.XX
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
CUBE-SCN00214#
CUBE-SCN00214#
CUBE-SCN00214#
CUBE-SCN00214#
CUBE-SCN00214#
CUBE-SCN00214#
CUBE-SCN00214#term no mon
CUBE-SCN00214#u all
All possible debugging has been turned off
CUBE-SCN00214# debu
CUBE-SCN00214#debug
Adarsh_Chauhan
Is the provider leg SIP/Digital (PRI T1/E1)/FXO?
You will need to run additional debugs along with debug ccsip messages
debug voice ccapi inout.
debug isdn q931 (if DIGITAL)
debug vpm signal  and debug vtsp all (if FXO)
refer to Voice call troubleshooting:
do not run on terminal if ISR in production.
Adarsh Chauhan
Please mark Correct or helpful
The problem is fixed.
The wrong ip interface was attached to the outgoing dial-peer which points to the ISP.
voice-class sip bind control source-interface GigabitEthernet0/0/0.1
voice-class sip bind media source-interface GigabitEthernet0/0/0.1
This was simply recovered by verifing :
CUBE#sh ip cef XX.XX.XX.XX
0.0.0.0/0
  nexthop XX.XX.XX.XX  GigabitEthernet0/0/0.1
