Not able to view Backup devices on CUCM/Call manager
voipeee
Level 3
Level 3
Hi Guys,
I am getting these error while trying to view Backup devices on call manager.
Any help please?
Aeby Vinod
Level 3
Level 3
You might want to regenerate the ipsec.pem certificate.
Complete these steps in the below order:
1) Log into Cisco Unified Communications Manager OS Administration page.
2) Choose Security > Certificate Management. The Certificate List window displays.
3) You can use the Find controls in order to filter the certificate list.
4) Click the ipsec.pem file, and then click Regenerate.
5) After the successful regeneration of the ipsec.pem file, Restart the Master Agent (MA)/Local Agent (LA).
The IPsec certificate is primarily used for DRS, Secure SIP profiles, CTL Client, and secure connections to gateways. If the IPsec certificate is renewed, reset DRF Master and DRF Local on the publisher AND DRF local on the subscribers. Restarting these will restart the DRS feature (DRS is used for backups and restoring for backup).
If this doesn't help you might want to consider a reboot of the server, the uptime is 180+ . I've seen issues popping up for some environments with that much uptime.
Please rate if you find this helpful.
Aeby
Aeby
12 Replies 12
Hi @voipeee,
 please take a look at the following bug: CSCun07019.
Hope this helps,
 Marcelo Morais
Firstly, Check for NTP server reachability from CUCM. Secondly, try restarting Cisco DRF Master and Local in PUB.
regds,
aman
I tried to use different browser, restarted DRF and TOMCAT. Got the NTP fixed still the same issue.
Muk
Hi @voipeee,
 you are using a Linux OS account (used by OS Admin and DRS) ... are you able to log in the OS Admin with no problem?
Best regards,
 Marcelo Morais
Hi @Marcelo Morais,
Yes, everything works fine. Even I am able to login to Admin,OS as well as DRS page. But when I click Backup devices nothing happens.
I thing this problem started after I regenerated few certificates before sometime however, I am not sure about this. And I regenerated Cisco Tomcat and restarted the service after that.
Aeby Vinod
Level 3
Level 3
Aeby
Aeby
In addition to what Vinod has mentioned, are the IP addresses of sftp created  under Backup devices reachable from CUCM?
regds,
aman
Hi @Aman Soi,
Thanks but I think it has nothing to do with the reachable because even if I have to add the devices I have to go to the same page.
Muk
I was referring to Backup devices if already created in CUCM.
Good the issue got resolved.
regds,
aman
Hi @Aeby Vinod,
I agree with you and this might be the case. I will update you about the status.
Thanks in advance.
Hi @Aeby Vinod,
The ipsec certificate is valid. I have pasted here certificate along with the expiry date. Thanks for your help.
CallManager  02/08/2023 Self-signed certificate generated by system
CallManager-ECDSA  08/19/2022 Self-signed certificate generated by system
CallManager-trust CAPF-16f3496d Self-signed RSA CAPF 12/16/2016
CallManager-trust Cisco_Manufacturing_CA_SHA2 CA-signed RSA Cisco_Manufacturing_CA_SHA2 Cisco_Root_CA_M2 11/12/2037
CallManager-trust Cisco_Root_CA_M2 Self-signed RSA Cisco_Root_CA_M2 Cisco_Root_CA_M2 11/12/2037
CallManager-trust CAPF-d201ea8d Self-signed RSA CAPF-d201ea8d CAPF-d201ea8d 02/08/2023
CallManager-trust Cisco_Manufacturing_CA CA-signed RSA Cisco_Manufacturing_CA Cisco_Root_CA_2048 05/14/2029
CallManager-trust 02/08/2023 Trust Certificate
CallManager-trust CAPF-962bd1bb Self-signed RSA CAPF-962bd1bb CAPF-962bd1bb 03/26/2018
CallManager-trust CAPF-49e87588 Self-signed RSA CAPF-49e87588 CAPF-49e87588 12/16/2016 Trust Certificate
CallManager-trust 12/16/2016 Trust Certificate
CallManager-trust Cisco_Root_CA_2048 Self-signed RSA Cisco_Root_CA_2048 Cisco_Root_CA_2048 05/14/2029
CallManager-trust CAP-RTP-001 Self-signed RSA CAP-RTP-001 CAP-RTP-001 02/06/2023
CallManager-trust CAPF-0aa24f9a Self-signed RSA CAPF-0aa24f9a CAPF-0aa24f9a 02/08/2023 Trust Certificate
CallManager-trust ACT2_SUDI_CA CA-signed RSA ACT2_SUDI_CA Cisco_Root_CA_2048 05/14/2029
CallManager-trust CAP-RTP-002 Self-signed RSA CAP-RTP-002 CAP-RTP-002 10/10/2023
CallManager-trust CAPF-1ddfa6e0 Self-signed RSA CAPF-1ddfa6e0 CAPF-1ddfa6e0 03/26/2018 Trust Certificate
CAPF CAPF-d201ea8d Self-signed RSA CAPF-d201ea8d 02/08/2023 Self-signed certificate generated by system
CAPF-trust CAPF-16f3496d Self-signed RSA CAPF-16f3496d CAPF-16f3496d 12/16/2016
CAPF-trust Cisco_Manufacturing_CA_SHA2 CA-signed RSA Cisco_Manufacturing_CA_SHA2 Cisco_Root_CA_M2 11/12/2037
CAPF-trust Cisco_Root_CA_M2 Self-signed RSA Cisco_Root_CA_M2 Cisco_Root_CA_M2 11/12/2037
CAPF-trust CAPF-d201ea8d Self-signed RSA CAPF-d201ea8d CAPF-d201ea8d 02/08/2023
CAPF-trust Cisco_Manufacturing_CA CA-signed RSA Cisco_Manufacturing_CA Cisco_Root_CA_2048 05/14/2029
CAPF-trust CAPF-962bd1bb Self-signed RSA CAPF-962bd1bb CAPF-962bd1bb 03/26/2018
CAPF-trust Cisco_Root_CA_2048 Self-signed RSA Cisco_Root_CA_2048 Cisco_Root_CA_2048 05/14/2029
CAPF-trust CAP-RTP-001 Self-signed RSA CAP-RTP-001 CAP-RTP-001 02/06/2023
CAPF-trust ACT2_SUDI_CA CA-signed RSA ACT2_SUDI_CA Cisco_Root_CA_2048 05/14/2029
CAPF-trust CAP-RTP-002 Self-signed RSA CAP-RTP-002 CAP-RTP-002 10/10/2023
ipsec 02/08/2023 Self-signed certificate generated by system
ipsec-trust  02/08/2023 Trust Certificate
ITLRecovery  08/15/2037 Self-signed certificate generated by system
tomcat  02/08/2023 Self-signed certificate generated by system
tomcat-ECDSA  08/19/2022 Self-signed certificate generated by system
tomcat-trust 08/19/2022 Trust Certificate
tomcat-trust  09/26/2022 Trust Certificate
tomcat-trust 02/08/2023 Trust Certificate
tomcat-trust  09/25/2022 Trust Certificate
tomcat-trust VeriSign_Class_3_Secure_Server_CA_-_G3 CA-signed RSA VeriSign_Class_3_Secure_Server_CA_-_G3 VeriSign_Class_3_Public_Primary_Certification_Authority_-_G5 02/07/2020 Trust Certificate
TVS fl.us 12/13/2016
Hey Abey,
This worked for me. Basically I regenerated this ipsec before few days and it displayed to restart DRS M/A however, this is out of mind now. Thank you so much for your help! I really appreciate.
Muk
