Not receving digits on incomming calls from E1
W S H FERNANDO
Level 4
Level 4
I have connected E1 to cisco 2921 Router, outgoing calls are working fine with the E1, but when incomming calls, no digits are receving from E1, !!!! what will be the reason for this ?
I have enabled the "debug voip dialpeer" I noticed that not any digits are receving from incomming calls.
Regds
Harmit Singh
Could you attach the config as well as the following debugs for one incoming test call:
debug isdn q931
debug voip ccapi inout
What IOS version are you running?
Also mention the calling and called party numbers for the test call made.
Harmit.
paolo bevilacqua
Are you using ISDN PRI, or E1 R2 ?
I'm using E1 R2
Regds
W S H FERNANDO
Level 4
Level 4
This issue is resolved by adjusing the sezing timer on E1
Regds
