ā10-10-2013 06:21 AM - edited ā03-16-2019 07:49 PM
Hi..
Can anyone help me here!
I ahve 7945 phone and when enabling call forward all from phone its working and after 24 hours its not functioning.
The current firmware version is SCCP45.9-0-2SR1S.
Anbarasan
ā10-10-2013 06:47 AM
Do you have other models the IP Phone with same problem?
CUCM don“t check time for this, if problem is in 7945 upgrade the Fw for latest version (9-3-1SR2-1).
Regards.
J Rosa
ā10-10-2013 07:09 AM
So, the phone and CCMAdmin still show the CFA but the phone rings?
But only after 24 hours?
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
ā10-10-2013 07:26 AM
Yes, the CFA get removed automatically after 24 hours and the phone rings.
Thanks and warm regards,
Anbarasan P
ā10-10-2013 07:38 AM
What is your CM ver ?
ā10-10-2013 07:41 AM
The current version is 8.0.2.40000-1
ā10-15-2013 01:54 AM
I'm not aware of any specific defect with this version of CUCM which causes CFA to stop working. If the phones are registered to the subscriber, change the Device Pool on a couple of phones such that they register to the publisher. When registered to the publisher, if this issue doesn't occur, then this would normally point to a DB replication issue and therefore you would need to fix DBReplication first.
ā10-15-2013 05:13 AM
Are both the phones sharing same device pool?
