Number of times location resources were unavailable for CCM
Gokul Raj
Hi All,
We used to get  alerts frequently " Number of times location resources were unavailable for CCM ".
CUCM version 6.1.5
Can anyone get this kind of similar alert.
Kind Regards,
Gokul Raj
Chris Deren
This indicates that your Call Admission Control (CAC) was triggered on exhausted bandwidth to/from a specific Location. Make sure your bandwidths for the locations are adequately set. The alerts is coming from RTMT.
Thanks a lot
Aseem Anand
Hi Gokul,
In addition to what Chris mentioned, if the alert is coming for a specific location then there might be a bandwidth leak. You can first try to resync the bandwidth under location and if does not work then restart Cisco Call manager service.
Aseem
Thanks a lot. I was on emergency leave will check and update you
