09-11-2024
02:07 AM
- last edited on
09-11-2024
06:30 AM
by
shazubai
im wondering, is there an easy option for using old cisco phone like 79xx series as an 'extension' for smartphone? Like cell 2 jack for old landline phones?
09-13-2024 04:08 AM
Yes, you can repurpose old Cisco 79xx series phones as extensions to your smartphone using a few different approaches. However, unlike the simple "Cell 2 Jack" devices for landlines, it requires more complex integration since Cisco IP phones use SIP (Session Initiation Protocol) for VoIP.
Here are two common methods:
If you have Cisco Unified Communications Manager (CUCM) set up, you can configure the 79xx series phone to register as a SIP endpoint and set up call forwarding from your smartphone to the IP phone:
This method requires a CUCM or other compatible call management system.
For a more cost-effective solution, you can use an open-source VoIP PBX like Asterisk or FreePBX. Here’s how:
This method gives more flexibility and can work in both home and office environments.
09-15-2024 11:09 PM
The 79XX phones are not SIP-only; they also support SCCP. The majority of 79XX phones come with SCCP, and in most cases, we convert them to SIP.
09-15-2024 11:07 PM
To use the Cell 2 jack, you need an analog phone, such as a Panasonic.
If you have a subscription with a third-party SIP provider, you can use the 79XX phone by registering it directly with them. If the phone is loaded with SCCP firmware, you will need to convert it to SIP before registering it with the SIP provider. Additionally, some tweaking might be necessary.
