03-05-2015 04:22 AM - edited 03-17-2019 02:13 AM
We got a problem with sporadic "one way audio" one mgcp connections to PSTN.
Call flow:
PSTN-->2811-->mgcp-->cucm-->CP7942-->CFWDall-->CP7942
or
PSTN-->2811-->mgcp-->cucm-->CP7942-->Pickup-->CP7942
or
PSTN-->2811-->mgcp-->cucm-->Huntpilot-->CP7942
If we got an direct call, everything works fine.
We got the Problems since we updated the Gateway to 15.1(4) M7.
Is there a bug? Has anyone an idea?
regards Guido
03-05-2015 09:02 AM
Do you have the 'mgcp bind' commands in the config to tie the calls to the correct interface? This is typically your LAN interface...
Aaron
03-05-2015 11:47 PM
Hi Aaron,
yes we have configured "mgcp bind".
mgcp
mgcp call-agent X.X.X.X 2427 service-type mgcp version 0.1
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
mgcp package-capability srtp-package
mgcp default-package mt-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp validate call-agent source-ipaddr
mgcp fax t38 ecm
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface GigabitEthernet0/1
mgcp bind media source-interface GigabitEthernet0/1
Guido
03-07-2015 10:41 PM
Please try to attach router running configuration.
Regrads
03-05-2015 03:17 PM
although your problem started occuring after IOS upgrade (and is most likely not connectivity related) in general when expereriencing one way audio issues, it good to just test connectivity from the phone to the other RTP end point, by simply pinging it. so in your case, from the phone's subnet to the IP address that MCGP binds to.
03-05-2015 11:48 PM
Hi Dennis,
teh Phone and Gateway are in the same Subnet. We are using sRTP as audio stream.
Guido
03-13-2015 03:09 AM
We found a BUG in IOS:
04-27-2015 06:43 PM
I have exact same issue and I have been working with TAC for over a year to find a bug for this issue.Can you help me with SR number or bug details to confirm 15.1(4) M7 is affected.
CSCtv21900 was fixed in 15.1(4) M4 so I am very surprised it is still affecting 15.1(4) M7.
details would be highly appreciated on the solution for this issue,
my setup:
PSTN>>3925 MGCP Gateway >>8961 IP phone
