06-14-2022 02:04 PM
Hi All,
I am getting a one way audio issue. I know this is typically a routing issue or a firewall issue but my network team has told me this is not the case. I would just like to see if there are any tools I can use to help prove that it is or is not the network. The issue is happening with calls to and from the PRI. The internal phone is unable to hear callers from the PRI but the callers from the PRI can hear the internal IP phone.
Is there a command that will show me the RTP stream that is leaving the gateway and going to the IP phone? I can then look at the phone logs to show the packets never arrive? Any other suggestions are welcome.
Solved! Go to Solution.
06-20-2022 12:22 PM
In the end I did a reload of the T1 card and everything started working
06-14-2022 08:01 PM
You can use trace route from the Phones network to the PRI network and from the PRI network to the phones network. This is going to show you if packets follow the same path.
Another situation for one way audio is nat. If during your trace route, you see packet loss, this usually means a firewall. You can ask to check if they are performing NAT in the path.
06-15-2022 02:00 PM
Trace route was fine with no drops. There is no firewall between these two networks.
06-14-2022 10:41 PM
Check From gateway if you are able to ping phone subnet. From the phone status message you can see if you receive any packets or not.
Since its an issue with PSTN call , this can also be due to the ISP issues.
Can you share the show controller E1/T1 out put ?
06-15-2022 02:04 PM
The ping works fine from the gateway to the phone. I got the network guys to setup a packet tracer on the switch/vlan the gateway is on and we didn't see any RTP coming from the gateway at all.
Here are the results from the show command.
T1 0/1/0 is up
Applique type is Channelized T1
Cablelength is long gain36 0db
No alarms detected.
alarm-trigger is not set
Soaking time: 3, Clearance time: 10
AIS State:Clear LOS State:Clear LOF State:Clear
Framing is ESF, Line Code is B8ZS, Clock Source is Line Primary.
BER thresholds: SF = 10e-3 SD = 10e-6
Data in current interval (363 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Data in Interval 1:
Data in Interval 2:
Data in Interval 3:
Data in Interval 4:
Data in Interval 5:
Data in Interval 6:
Data in Interval 7:
Data in Interval 8:
Data in Interval 9:
Data in Interval 10:
Data in Interval 11:
Data in Interval 12:
Data in Interval 13:
Data in Interval 14:
Data in Interval 15:
Data in Interval 16:
Data in Interval 17:
Data in Interval 18:
Data in Interval 19:
Data in Interval 20:
Data in Interval 21:
Data in Interval 22:
Data in Interval 23:
Data in Interval 24:
Data in Interval 25:
Data in Interval 26:
Data in Interval 27:
Data in Interval 28:
Data in Interval 29:
Data in Interval 30:
Data in Interval 31:
Data in Interval 32:
Data in Interval 33:
Data in Interval 34:
Data in Interval 35:
Data in Interval 36:
Data in Interval 37:
Data in Interval 38:
Data in Interval 39:
Data in Interval 40:
Data in Interval 41:
Data in Interval 42:
Data in Interval 43:
Data in Interval 44:
Data in Interval 45:
Data in Interval 46:
Data in Interval 47:
Data in Interval 48:
Data in Interval 49:
Data in Interval 50:
Data in Interval 51:
Data in Interval 52:
Data in Interval 53:
Data in Interval 54:
Data in Interval 55:
Data in Interval 56:
Data in Interval 57:
Data in Interval 58:
Data in Interval 59:
Data in Interval 60:
Data in Interval 61:
Data in Interval 62:
Data in Interval 63:
Data in Interval 64:
Data in Interval 65:
Data in Interval 66:
Data in Interval 67:
Data in Interval 68:
Data in Interval 69:
Data in Interval 70:
Data in Interval 71:
Data in Interval 72:
Data in Interval 73:
Data in Interval 74:
Data in Interval 75:
Data in Interval 76:
Data in Interval 77:
Data in Interval 78:
Data in Interval 79:
Data in Interval 80:
Data in Interval 81:
Data in Interval 82:
Data in Interval 83:
Data in Interval 84:
Data in Interval 85:
Data in Interval 86:
Data in Interval 87:
Data in Interval 88:
Data in Interval 89:
Data in Interval 90:
Data in Interval 91:
Data in Interval 92:
Data in Interval 93:
Data in Interval 94:
Data in Interval 95:
Data in Interval 96:
Total Data (last 24 hours)
0 Line Code Violations, 0 Path Code Violations,
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
06-15-2022 10:24 PM
I have faced similar issue due to isp problems.
I cannot see any errors on the line so you need to open a ticket with ISP.
06-20-2022 12:22 PM
