TCL - Modify Calling Name
ryan_oconnell
Level 3
Level 3
Hello I found this script modify_calling_name.tcl and thought I could use it to have all outbound calls from my customer default to the company name. It seems to work just fine. Only thing I couldn’t figure out was how to get rid of the Quotes. It appears as though the TCL script is looking for a parameter value and a space is not a valid character. So I had to put “Town of Springfield” in quotes but the call is being shipped out with the quotes.
See my config below and resulting debug. Also TCL is attached
application
service modifyname flash0:modify_caller_name.tcl
dial-peer voice 500000 voip
description **Match all Incoming VOIP**
service modifyname
paramspace modifyname display_name_default "Town of Springfield”
incoming called-number .
voice-class codec 1
voice-class h323 1
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 501000 voip
description **CUCM2**
preference 1
destination-pattern 506.......
session target ipv4:10.x.y.z
voice-class codec 1
voice-class h323 1
no vad
dial-peer voice 502000 voip
description **CUCM1**
preference 2
voice-class codec 1
voice-class h323 1
no vad
dial-peer voice 100000 pots
description **PSTN Incoming dial peer**
direct-inward-dial
port 0/0/0:23
dial-peer voice 100001 pots
description **PSTN Outbound Calls**
destination-pattern 9T
port 0/0/0:23
DEBUG ISDN Q931
004955: Oct 16 20:41:33.507 AST: ISDN Se0/0/0:23 Q931: Applying typeplan for sw-type 0x5 is 0x0 0x0, Calling num 5063334444
004956: Oct 16 20:41:33.507 AST: ISDN Se0/0/0:23 Q931: Sending SETUP  callref = 0x0570 callID = 0x857C switch = primary-dms100 interface = User
004957: Oct 16 20:41:33.507 AST: ISDN Se0/0/0:23 Q931: TX -> SETUP pd = 8  callref = 0x0570
        Bearer Capability i = 0x8090A2
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98397
                Exclusive, Channel 23
        Display i = 0xB1, '"Town of Springfield"'
        Calling Party Number i = 0x0081, '5063334444'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '19021114444'
004958: Oct 16 20:41:33.675 AST: ISDN Se0/0/0:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x8570
004959: Oct 16 20:41:34.523 AST: ISDN Se0/0/0:23 Q931: RX <- ALERTING pd = 8  callref = 0x8570
        Progress Ind i = 0x8088 - In-band info or appropriate now available
004960: Oct 16 20:41:34.527 AST: ISDN Se0/0/0:23 Q931: RX <- NOTIFY pd = 8  callref = 0x8570
        Notification Ind i = 0xF1
        Display i = 0xB2, 'Bart Simpson'
004961: Oct 16 20:41:40.675 AST: ISDN Se0/0/0:23 Q931: RX <- CONNECT pd = 8  callref = 0x8570
004962: Oct 16 20:41:40.675 AST: %ISDN-6-CONNECT: Interface Serial0/0/0:22 is now connected to 19021114444
N/A
004963: Oct 16 20:41:40.675 AST: ISDN Se0/0/0:23 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x0570
paolo bevilacqua
You need to code in tcl so to remove the quotes.
So I need to add code to the TCL? I was hoping it was just a different method of entering the parameter for display_name_default.
To enter spaces in a service parameters, must use double quotes.
To remove double quotes in TCL script, must code for that.
In any case, once you make a call via script, try transferring it.
Or you can use my "outgoing calling name" script that does all the above correcty, from the the website mentioned in my profile.
mathanmogan
Thanks , WORK perfect
