one way no audio internal to external calling
de.101
 I'm trying to get an idea on how to approach troubleshooting one way no audio issue as below.
-Cisco IP phone to PSTN, calls connect but external party cannot hear audio, Cisco Phone can hear external party.
-Internal to Internal calling, no audio issues
-Calls from PSTN to Cisco IP phones, no audio issues.
This was escalated to Telephone Service provider and senior team, but out of interest and keen junior Cisco technician I would like to see proper way to approach and troubleshoot the above issue. From Firewall to Voice Gateway.
Thanks in advance!
HARIS_HUSSAIN
As a starter you can try below
1) Approach :1 :- Find out Packets sent and received on Phone
         ===> Here we will make a live test call see the Packet received and sent counters on IP Phone To isolate issue is between Which Subnet to Which Subnet
                  ====> Once Call is active you can view Call Statistics in Phone by settings > Admin Settings >Status>Call Statistices on 7800 Model or Press ? button twice on 7900 Models
2) Check if required Ports are open in the path were you are facing issue i,e RTP Ports  16384 - 32767 UDP. Check the ACLs, Routing , Firewall Rules
3) Check if SIP/SCCP Inspection is disabled in firewall. Also check if path involved any NAT.
Haris
** Please rate and mark solution accepted if applicable.
5 Replies 5
balaji.bandi
Most of the time one way voice Due to NAT issue, also  considering looking at  Codec Translation.
BB
HARIS_HUSSAIN
Haris
We have done Wireshark capturing from Cisco IP Phone, no issues were picked up, all looked good.
We have then disabled SIP/SCCP Inspection. Once disabled the one way audio issue was resolved.
Now, is it best practice to leave SIP/SCCP Inspection disabled permanently? are there any issues with leaving it disabled in this case?
Much appreciated with help received!
George Sotiropoulos
You better check on your firewall if SIP inspection is enabled and if it is test by disabling it.
George
Please Rate Posts (by clicking on Star) and/or Mark Solutions as Accepted, when applies
