One way voice when answered from hunt queue
fei he
Level 2
Level 2
We recently cross an issue where one way audio when answer from hunt queued calls and call flow as below:
ITSP ---sip---> CUBE(SP) --- sip--> CUCM --- sip---> ip phone
PSTN caller 1 call the hunt and answer by IP phone with 2 way audio. Then 2nd PSTN call coming into hunt which configured for Native queuing and 2nd call is queued as all hunt members are already on the call and PSTN caller 2 hear music on hold. IP phone disconnect PSTN caller 1 and PSTN caller 2 previous queued  is ringing to IP Phone and PSTN caller 2 start hear ring back tone. IP Phone answer the call and one-way audio occurs where PSTN caller 2 can hear IP Phone but IP Phone cannot hear PSTN caller 2 (same call flow works perfectly fine when all calling and called party from internal ip phone).
Has anyone came cross similar issue and any suggestion?
Fei
10 Replies 10
Dennis Mink
Sound like either a:  a routing issue (ping between phones and PSTN gateway).
or b, which is most likely, a signalling issue.  when your caller called into the native queueing then the queue will send to your caller that RTP=inactive and it will only play out the music on hold. I am guessing that when a phone becomes available, there is no re-invite to signal that RTP is now 2ways.
can you trace the call and send us the SIP traces.
cheers
Please remember to rate useful posts, by clicking on the stars below.
2nd call coming to the Hunt and call is been queued (on hold), call flow shows Carriage send the original INVITE to the CUBE, CUBE replies and sends a 200OK/SDP for answer with media attribute sendonly.
00171775.002 |17:08:09.600 |AppInfo  |SIPTcp - wait_SdlReadRsp: Incoming SIP TCP message from 10.111.3.253 on port 51977 index 2571831 with 1033 bytes:[525958909,NET]
INVITE sip:+61262644589@10.111.2.5:5060 SIP/2.0
Via: SIP/2.0/TCP 10.111.3.253:5060;branch=z9hG4bK+089560f63f02643084aba99e578d54281+sip+1+ac27ca87
Supported: com.nortelnetworks.firewall,p-3rdpartycontrol,nosec,join,x-nortel-sipvc,gin,com.nortelnetworks.im.encryption,tdialog
From:  <sip:+61280854712@10.111.3.253:5060>;tag=10.111.3.253+1+188e73cd+54b8b409
To: <sip:+61262644589@10.111.2.5:5060>
CSeq: 3996 INVITE
Expires: 180
Content-Length: 190
Call-Info: <sip:10.111.3.253:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
Contact: <sip:10.111.3.253:5060;transport=tcp>
Content-Type: application/sdp
Call-ID: 0e6aafbd5f893e9aadc1978a16c0a3c5@10.111.3.253
Max-Forwards: 49
Allow: INVITE,BYE,CANCEL,ACK,REGISTER,SUBSCRIBE,NOTIFY,MESSAGE,INFO,REFER,OPTIONS,PUBLISH,PRACK
Accept: application/sdp, application/dtmf-relay
v=0
o=PVG 65156409607295 65156409607295 IN IP4 10.111.3.254
s=-
c=IN IP4 10.111.3.254
t=0 0
m=audio 27190 RTP/AVP 8 101
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=ptime:20
00172133.001 |17:08:09.788 |AppInfo  |SIPTcp - wait_SdlSPISignal: Outgoing SIP TCP message to 10.111.3.253 on port 51977 index 2571831 [525958974,NET]
SIP/2.0 200 OK
To: <sip:+61262644589@10.111.2.5:5060>;tag=1590641452~8f65986a-1de3-4cbe-a6b4-16bb52492403-43429771
Date: Tue, 07 Mar 2017 06:08:09 GMT
CSeq: 3996 INVITE
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
Allow-Events: presence
Supported: replaces
Server: Cisco-CUCM10.5
Call-Info: <urn:x-cisco-remotecc:callinfo>;x-cisco-video-traffic-class=MIXED
Supported: X-cisco-srtp-fallback
Supported: Geolocation
P-Asserted-Identity: <sip:+61262644589@10.111.2.5>
Remote-Party-ID: <sip:+61262644589@10.111.2.5>;party=called;screen=yes;privacy=off
Contact: <sip:+61262644589@10.111.2.5:5060;transport=tcp>
Content-Length: 225
v=0
o=CiscoSystemsCCM-SIP 1590641452 1 IN IP4 10.111.2.5
s=SIP Call
c=IN IP4 10.111.3.4
t=0 0
m=audio 4000 RTP/AVP 8 101
a=ptime:20
a=rtpmap:8 PCMA/8000
a=sendonly                  --------------> CUBE instruct EVOLVE this call been queued or on hold.
a=fmtp:101 0-15
Once the queued call is answered, there is a re-INVITE coming from the CUBE and the Carriage replies with 200OK/SDP recvonly which is causing the one way speech.
00185286.001 |17:08:21.728 |AppInfo  |SIPTcp - wait_SdlSPISignal: Outgoing SIP TCP message to 10.111.3.253 on port 5060 index 2401885 [525962245,NET]
INVITE sip:10.111.3.253:5060;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 10.111.2.5:5060;branch=z9hG4bK2bec81347f5a2cd
From: <sip:+61262644589@10.111.2.5:5060>;tag=1590641452~8f65986a-1de3-4cbe-a6b4-16bb52492403-43429771
To: <sip:+61280854712@10.111.3.253:5060>;tag=10.111.3.253+1+188e73cd+54b8b409
Date: Tue, 07 Mar 2017 06:08:21 GMT
Supported: timer,resource-priority,replaces
User-Agent: Cisco-CUCM10.5
CSeq: 104 INVITE
Max-Forwards: 70
Expires: 180
Call-Info: <urn:x-cisco-remotecc:callinfo>;x-cisco-video-traffic-class=DESKTOP
Min-SE:  1800
P-Asserted-Identity: <sip:+61262643770@10.111.2.5>
Remote-Party-ID: <sip:+61262643770@10.111.2.5>;party=calling;screen=yes;privacy=off
Contact: <sip:367e1c51-af86-2224-e512-936a09af226d@10.111.2.5:5060;transport=tcp>
Content-Length: 229
v=0
o=CiscoSystemsCCM-SIP 1590641452 4 IN IP4 10.111.2.5
s=SIP Call
c=IN IP4 10.136.156.120
b=TIAS:64000
b=AS:64
t=0 0
m=audio 18254 RTP/AVP 8 101
a=fmtp:101 0-15
00185341.002 |17:08:21.774 |AppInfo  |SIPTcp - wait_SdlReadRsp: Incoming SIP TCP message from 10.111.3.253 on port 5060 index 2401885 with 803 bytes:
[525962266,NET]
SIP/2.0 200 OK
CSeq: 104 INVITE
Via: SIP/2.0/TCP 10.111.2.5:5060;received=10.111.2.5;branch=z9hG4bK2bec81347f5a2cd
Content-Length: 224
v=0
o=PVG 65156409607295 65156409607296 IN IP4 10.111.3.254
s=-
t=0 0
a=recvonly                 --------------> this cause one way speech
a=fmtp:101 0-15
a=ptime:20
This issue is now resolved after we uncheck "Send send-receive SDP in mid-call INVITE" on SIP profile used by trunk.
By looking at the traces, the invite from the second call comes with no codec. The 200 OK comes with a codec and a send only. so when the 2nd call gets picked up, there is a codec towards PSTN (g711alaw), but no codec i.e. voice from PSTN.
I would reach out to your provider, and ask them why that Eoraly Offer SDP does not contain any codecs.
Please rate if this helps.
Hello I have the same problems. I have try all options.
at the end the log files.
thanks!
Hello I have the same problem.
Please post the output of a debug ccsip message while reproducing the issue.
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi Carlo, thank you for reply.
there is no option for me to attach a file, every time i try i get following error messages:
The attachment's ccsip_messages.txt content type (text/plain) does not match its file extension and has been removed
Hi.
Try without underscore.
Let me know
Cheers
Carlo
Hi Carlo, i have tried it in all possible variations and unfortunately had no success with the upload. So now I'm using this method:
030233: Dec 1 10:52:03.920: //2950717/10B04CC296B9/SIP/Msg/ccsipDisplayMsg:
Received:
UPDATE sip:+491603680613@10.136.33.70:5060 SIP/2.0
Via: SIP/2.0/UDP 10.136.33.60:5060;branch=z9hG4bK13395f7fec074d
From: <sip:+4926379447911@10.136.33.60>;tag=1722336~0048b14b-05aa-49bd-8135-a09e0f721b42-51655550
To: <sip:+491603680613@10.136.33.70>;tag=843B8133-400
Date: Fri, 01 Dec 2023 09:51:42 GMT
Call-ID: 10B09AD6-8F6611EE-96BFDD9B-33AF9DD@10.136.33.70
User-Agent: Cisco-CUCM11.5
Max-Forwards: 70
CSeq: 103 UPDATE
Session-ID: 80d35b4551d6babd3c9256ba51655576;remote=82d2b9a14449591fbe42dfa1224e68c1
Call-Info: <urn:x-cisco-remotecc:callinfo>;x-cisco-video-traffic-class=VIDEO_UNSPECIFIED
Session-Expires: 1800;refresher=uac
Min-SE: 1800
P-Asserted-Identity: <sip:004926379447999@10.136.33.60>
Contact: <sip:+4926379447911@10.136.33.60:5060>
Content-Length: 0
030234: Dec 1 10:52:03.921: //2950717/10B04CC296B9/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Fri, 01 Dec 2023 09:52:03 GMT
Server: Cisco-SIPGateway/IOS-16.12.4a
CSeq: 103 UPDATE
Allow-Events: telephone-event
Contact: <sip:+491603680613@10.136.33.70:5060>
Session-ID: 82d2b9a14449591fbe42dfa1224e68c1;remote=80d35b4551d6babd3c9256ba51655576
Require: timer
Supported: timer
Content-Length: 0
030235: Dec 1 10:52:03.924: //2950717/10B04CC296B9/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:+491603680613@10.136.33.70:5060 SIP/2.0
Via: SIP/2.0/UDP 10.136.33.60:5060;branch=z9hG4bK1339604ed67ab
Supported: 100rel,timer,resource-priority,replaces
Cisco-Guid: 0279989442-2405831150-2528763291-0054196701
CSeq: 104 INVITE
Max-Forwards: 70
Expires: 180
Min-SE: 1800
Content-Length: 0
030236: Dec 1 10:52:03.925: //2950717/10B04CC296B9/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 104 INVITE
Content-Length: 0
030237: Dec 1 10:52:03.925: //2950717/10B04CC296B9/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 104 INVITE
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Supported: replaces
Supported: sdp-anat
Session-ID: 82d2b9a14449591fbe42dfa1224e68c1;remote=00000000000000000000000000000000
Require: timer
Supported: timer
Content-Length: 246
v=0
o=CiscoSystemsSIP-GW-UserAgent 4073 5024 IN IP4 10.136.33.70
s=SIP Call
c=IN IP4 10.136.33.70
t=0 0
m=audio 9846 RTP/AVP 8 101
a=fmtp:101 0-15
a=ptime:20
030238: Dec 1 10:52:03.939: //2950717/10B04CC296B9/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:+491603680613@10.136.33.70:5060 SIP/2.0
Via: SIP/2.0/UDP 10.136.33.60:5060;branch=z9hG4bK13396140169c1e
Max-Forwards: 70
CSeq: 104 ACK
Content-Length: 180
v=0
o=CiscoSystemsCCM-SIP 1722336 3 IN IP4 10.136.33.60
s=SIP Call
c=IN IP4 10.11.20.60
t=0 0
m=audio 29958 RTP/AVP 8
a=X-cisco-media:umoh
a=ptime:20
030239: Dec 1 10:52:04.104: //2950713/330F19000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 100.88.38.226:5060;branch=z9hG4bK35CB8DB
From: <sip:004926379447910@versatel.sip>;tag=843B54DF-207C
To: <sip:004915142614398@versatel.sip>;tag=3jeupg6t-CC-16
Call-ID: 9ED0A9B-8F6611EE-96B6DD9B-33AF9DD@100.88.38.226
Timestamp: 1701424323
CSeq: 103 BYE
P-Access-Network-Info: IEEE-802.11;"ue-ip=100.88.38.226";"ue-port=5060";"location-info=100.88.38.226"
Content-Length: 0
030244: Dec 1 10:52:08.196: //2950717/10B04CC296B9/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.136.33.60:5060;branch=z9hG4bK1339663c002011
Date: Fri, 01 Dec 2023 09:52:08 GMT
CSeq: 105 INVITE
Max-Forwards: 70
Expires: 180
Min-SE: 1800
Content-Length: 0
030245: Dec 1 10:52:08.198: //2950717/10B04CC296B9/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 105 INVITE
Content-Length: 0
030246: Dec 1 10:52:08.198: //2950717/10B04CC296B9/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 105 INVITE
Supported: replaces
Supported: sdp-anat
Require: timer
Supported: timer
Content-Length: 246
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-15
a=ptime:20
030247: Dec 1 10:52:08.363: //2950717/10B04CC296B9/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.136.33.60:5060;branch=z9hG4bK133967243e3e01
Max-Forwards: 70
CSeq: 105 ACK
Content-Length: 247
v=0
o=CiscoSystemsCCM-SIP 1722336 4 IN IP4 10.136.33.60
s=SIP Call
c=IN IP4 10.49.20.161
b=TIAS:64000
b=CT:64
b=AS:64
t=0 0
m=audio 31216 RTP/AVP 8 101
a=ptime:20
a=fmtp:101 0-15
030248: Dec 1 10:52:08.365: //2950717/10B04CC296B9/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.136.33.60:5060;branch=z9hG4bK1339687bf3381c
Max-Forwards: 70
CSeq: 106 UPDATE
Min-SE: 1800
P-Asserted-Identity: "4710" <sip:004926379447999@10.136.33.60>
Content-Length: 0
030249: Dec 1 10:52:08.367: //2950717/10B04CC296B9/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 106 UPDATE
Require: timer
Supported: timer
Content-Length: 0
030287: Dec 1 10:52:25.033: //2950716/10B04CC296B9/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:004926379447911@100.88.38.226:5060 SIP/2.0
Via: SIP/2.0/UDP 100.88.36.38:5060;branch=z9hG4bK3imecm00307d067eodv0cd0000g10.1
Call-ID: fsz5ee6f6frfj6iuqrzzterpfqru3esg@ATS.esn001vas001.voice.huawei.versatel.mpls.13
From: <sip:01603680613@Versatel.de;user=phone>;tag=jgjrg5pp-CC-13
To: <sip:004926379447911@10.200.15.2;transport=udp;user=phone>;tag=843B813F-290
CSeq: 3 BYE
Max-Forwards: 59
Reason: SIP;cause=200;text="User Triggered"
P-Access-Network-Info: xDSL;"location-info=100.88.38.226"
Content-Length: 0
030288: Dec 1 10:52:25.035: //2950716/10B04CC296B9/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Fri, 01 Dec 2023 09:52:25 GMT
CSeq: 3 BYE
Reason: Q.850;cause=16
Content-Length: 0
030289: Dec 1 10:52:25.035: //2950717/10B04CC296B9/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:+4926379447911@10.136.33.60:5060 SIP/2.0
Via: SIP/2.0/UDP 10.136.33.70:5060;branch=z9hG4bK35CB972327
From: <sip:+491603680613@10.136.33.70>;tag=843B8133-400
To: <sip:+4926379447911@10.136.33.60>;tag=1722336~0048b14b-05aa-49bd-8135-a09e0f721b42-51655550
User-Agent: Cisco-SIPGateway/IOS-16.12.4a
Timestamp: 1701424345
CSeq: 103 BYE
Max-Forwards: 59
Content-Length: 0
030290: Dec 1 10:52:25.038: //2950697/F6635C339696/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:+497618832400@10.136.33.70:5060 SIP/2.0
Via: SIP/2.0/UDP 10.136.33.60:5060;branch=z9hG4bK1339762d60c7cd
From: <sip:+4926379447911@10.136.33.60>;tag=1722306~0048b14b-05aa-49bd-8135-a09e0f721b42-51655534
To: <sip:+497618832400@10.136.33.70>;tag=843AD4D8-718
Date: Fri, 01 Dec 2023 09:51:02 GMT
Call-ID: F663F85B-8F6511EE-969CDD9B-33AF9DD@10.136.33.70
Max-Forwards: 70
CSeq: 101 BYE
Session-ID: 541e11b8998c12e11c7687ba51655535;remote=d484bb2dfa3851cb8e2d7a7885ccb242
Content-Length: 0
030291: Dec 1 10:52:25.040: //2950696/F6635C339696/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:+497618832400@100.88.36.38:5060;user=phone;transport=udp SIP/2.0
Via: SIP/2.0/UDP 100.88.38.226:5060;branch=z9hG4bK35CB98482
From: <sip:004926379447911@10.200.15.2;transport=udp;user=phone>;tag=843AD4F1-1632
To: <sip:07618832400@Versatel.de;user=phone>;tag=d33i3j5p-CC-30
Call-ID: z6t353f3srijqedidutf5esid6r5jjze@ATS.esn001vas001.voice.huawei.versatel.mpls.30
CSeq: 101 BYE
Max-Forwards: 70
Content-Length: 0
030292: Dec 1 10:52:25.041: //2950697/F6635C339696/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 101 BYE
Session-ID: d484bb2dfa3851cb8e2d7a7885ccb242;remote=541e11b8998c12e11c7687ba51655535
Content-Length: 0
030293: Dec 1 10:52:25.041: //2950717/10B04CC296B9/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Server: Cisco-CUCM11.5
CSeq: 103 BYE
Content-Length: 0
030294: Dec 1 10:52:25.188: //2950696/F6635C339696/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 BYE
Content-Length: 0
030295: Dec 1 10:52:25.694: //2950730/4DE18D800000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 100.88.38.226:5060;branch=z9hG4bK35CB94193
macnow
I also heve tshi problem
