05-05-2013 10:32 PM - edited 03-16-2019 05:09 PM
(Ext-5200)User#1-------PABX(FXO)-------(FXS)GW#1--------IP-------------GW#2(FXO)-------------(FXS)PABX-----------User#2(Ext-6555)
Above line illestrat my topology of cisco Gateway with analog PABX system for voice communications.
I just try to brif a details about the problem !!
From User#1(Ext-5200) dial to User#2 (Ext-6555) and User#2 recive the phone but didnt hear anything from User#1 , but User#1 hear User#2 voice ! in that time if User#1 press any one phone key like-1 or 2 or 3 ... (except #*) than both user hear voice conversation smoothly and this additional key prees only work from origination side phone set !!! without this audio conversation always work oneway !!!
I need help to avoid additional key press for both side voice conversation !
Rafiq /Bangladesh
05-06-2013 05:37 AM
Hi Rafiq.
Can you please send a show run of your cisc gateway an the output of the following debug during a call.
debug vpn all
Carlo
Please rate all helpful posts
"The more you help the more you learn"
05-06-2013 05:51 AM
Hi Rafi,
Most of the time, one way audio problem is cause by routing issue (network routing).
How are GW1 and GW2 connected? Do you have a VPN stablish?
Please remember to rate useful posts clicking on the stars below.
Favor calificar todos las respuestas útiles.
___________________________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
