04-14-2015 05:55 AM - edited 03-17-2019 02:38 AM
hi,
we have cucm8.6 and gateway 2811 with ios12.4T
everything was working fine till last week then users started complaining about call drops to certain numbers.
when i checked on gateway i got q.850 cause 127 error in debug ccsip messages.
i called ITSP and those guys told me there is no early offer in SDP.
i configured the early offer support for voice and video calls(insert MTP if needed) but still i am not able to call those numbers.
and ITSP saying they are not receiving early offer.
i tried to force that on gateway but the command is not available in voice service voip or dial-peer.
please can anyone help me
04-14-2015 06:21 AM
Can you please provide the output of "debug ccsip messages" together with the "show run"?
Thank you,
Shadi
04-14-2015 06:22 AM
I think there are 2 options.
1. Manually set the codec on GW dial-peer what PSTN provides expects
2. Upgrade to right IOS which consists of "early-offer forced" command
The following links may help...
https://supportforums.cisco.com/discussion/11527131/sip-trunk-early-offer
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/voice/cube_sip/configuration/xe-3s/cube-sip-xe-3s-book/do-to-eo.html
Please provide SIP traces if it fails. Hope you have SIP trunk configuration from CUCM to PSTN provider.
Regards..
Ashok.
04-14-2015 10:29 AM
Generally ITSP has nothing to do with EO OR DO. It has to be proper messages with SDP either on EO or DO to make that call work.
as per 127 cause code this is the probable issue.
The following error codes are generated when the call is released by the SIP interface:
•127 - Interworking, unspecified
–Acknowledgment not received on final or reliable provisional response to a SIP 'Invite' or 'Re-Invite' sent.
–When the Session Description Protocol (SDP) is not received in a SIP 'Ack' request and is expected.
–When 200 class response to an initial 'Invite' is sent or received and SDP is expected but not available.
Secondly do you see in the ccsip message on 2811 router do INVITE has SDP ? Please post the debug ccsip message and ccapi inout debug for one unsuccessfull call.
Br,
Nadeem
04-14-2015 11:06 PM
Thank you for the replies,
i was not able to test as my working hours were over,
attaching the debugs..
i cannot see the SDP in the invite ,i don't know why?
i have early-media disabled 180 in sip-ua on gateway, if i remove that there will be no ring back tone for all calls.
04-16-2015 01:13 AM
As per the attached files, it looks like Delayed offer as the SDP sent after "200/Trying".
If possible, can we have a diagram and give the details to understand the issue better?
Have you tried the options provided above for Early offer?
Regards...
Ashok.
04-16-2015 01:21 AM
the issue got resolved with the help of TAC.
actually we have h.323 and sip gateway configured on CUCM and the outbound calls were using H.323 as it was pointed to cube in RL,RG.
now we changed it to sip trunk and the calls with sdp are successful.
08-15-2019 03:07 PM
Hi, how you configure the sdp on invite on sip trunk?
