11-15-2018 04:51 PM - edited 03-17-2019 01:43 PM
I have two SIP links configured on Voice gateway router from the same service providers to have redundancy. Also I have configured SIP trunk between CUCM and Voice gateway with that two CE IP addresses. Outbound Calls are working fine through primary SIP link but through backup SIP link I received the following error with cause code=20
Can anyone help me to how fix this issue?
8342018: Nov 15 15:44:43.408: //4832237/3FC4C8000000/CCAPI/cc_api_call_disconnected:
Cause Value=20, Interface=0x22916108, Call Id=4832237
8342019: Nov 15 15:44:43.408: //4832237/3FC4C8000000/CCAPI/cc_api_call_disconnected:
Call Entry(Responsed=TRUE, Cause Value=20, Retry Count=0)
11-16-2018 12:35 AM
11-16-2018 06:03 AM
Can you please post your CUBE config?
When you say you have 2 SIP links, do you mean separate dial-peers, etc.? Or are these registered SIP trunks?
