Outbound dialing on h323 gateway
markedavis
Tested this gateway before we deployed it in another town and have run into a problem  One problem was inbound dialing which I corrected by battery-reversal on the FXO ports.  I still have problem outbound though.  I see the port go off-hook for a second and then back on-hook.  Get a fast busy on the call.  It appears to be hitting the right dial-peer in the ccapi debug but when I do a debug dialpeer I don't see anything.  Like I said, it worked perfectly at the corporate office while testing.  Not sure where else to look.  Any ideas???
Here is the debug ccapi.  Dialed number is 9 9857916891
BN-USHUM01-RTR01#
Aug 20 21:29:23.855: //-1/801D293F0D00/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=Houma Test
   ----- ccCallInfo IE subfields -----
   cisco-ani=9858763175
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=99857916981
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Aug 20 21:29:23.859: //-1/801D293F0D00/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x2AEED678, Call Info(
   Calling Number=9858763175,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=99857916981(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=0, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=47
Aug 20 21:29:23.859: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Aug 20 21:29:23.859: :cc_get_feature_vsa malloc success
Aug 20 21:29:23.859:  cc_get_feature_vsa count is 1
Aug 20 21:29:23.859: :FEATURE_VSA attributes are: feature_name:0,feature_time:1106321696,feature_id:47
Aug 20 21:29:23.859: //47/801D293F0D00/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=9858763175(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=99857916981(TON=Unknown, NPI=Unknown))
Aug 20 21:29:23.859: //47/801D293F0D00/CCAPI/cc_process_call_setup_ind:
   Event=0x2B0CB348
Aug 20 21:29:23.859: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 99857916981
Aug 20 21:29:23.859: //47/801D293F0D00/CCAPI/ccCallSetContext:
   Context=0x420E248C
   >>>>CCAPI handed cid 47 with tag 0 to app "_ManagedAppProcess_Default"
Aug 20 21:29:23.859: //47/801D293F0D00/CCAPI/ccCallProceeding:
Aug 20 21:29:23.859: //47/801D293F0D00/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=6, Params=0x420E399C, Progress Indication=NULL(0)
Aug 20 21:29:23.859: //47/801D293F0D00/CCAPI/ccCheckClipClir:
   In: Calling Number=9858763175(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
   Out: Calling Number=9858763175(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
   Destination Pattern=9[2-9]........., Called Number=99857916981, Digit Strip=TRUE
   Redirect Number=, Display Info=
   Account Number=Houma Test, Final Destination Flag=TRUE,
   Guid=801D293F-70AC-2103-0D00-A0020A200710, Outgoing Dial-peer=6
Aug 20 21:29:23.859: //47/801D293F0D00/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=99857916981
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Aug 20 21:29:23.863: //47/801D293F0D00/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0xC1A17924, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=9858763175,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=99857916981(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=6, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Aug 20 21:29:23.863: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Aug 20 21:29:23.863: :cc_get_feature_vsa malloc success
Aug 20 21:29:23.863:  cc_get_feature_vsa count is 2
Aug 20 21:29:23.863: :FEATURE_VSA attributes are: feature_name:0,feature_time:1106321472,feature_id:48
Aug 20 21:29:23.863: //48/801D293F0D00/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Aug 20 21:29:23.863: //48/801D293F0D00/CCAPI/ccCallSetContext:
   Context=0x420E394C
Aug 20 21:29:23.863: //47/801D293F0D00/CCAPI/ccSaveDialpeerTag:
Aug 20 21:29:23.863: //48/801D293F0D00/CCAPI/cc_api_call_proceeding:
   Interface=0xC1A17924, Progress Indication=NULL(0)
Aug 20 21:29:25.115: //48/801D293F0D00/CCAPI/cc_api_call_disconnected:
   Cause Value=34, Interface=0xC1A17924, Call Id=48
   Call Entry(Responsed=TRUE, Cause Value=34, Retry Count=0)
Aug 20 21:29:25.115: //47/801D293F0D00/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
Aug 20 21:29:25.115: //48/801D293F0D00/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=48
Aug 20 21:29:25.115: //48/801D293F0D00/CCAPI/ccCallDisconnect:
   Cause Value=34, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=34)
   Cause Value=34, Call Entry(Responsed=TRUE, Cause Value=34)
Aug 20 21:29:25.115: //48/801D293F0D00/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0xC1A17924, Tag=0x0, Call Id=48,
   Call Entry(Disconnect Cause=34, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Aug 20 21:29:25.115: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Aug 20 21:29:25.115: :cc_free_feature_vsa freeing 41F12038
Aug 20 21:29:25.115:  vsacount in free is 1
Aug 20 21:29:25.119: //47/801D293F0D00/CCAPI/ccCallDisconnect:
   Cause Value=34, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Aug 20 21:29:25.119: //47/801D293F0D00/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
Aug 20 21:29:25.119: //47/801D293F0D00/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x2AEED678, Tag=0x0, Call Id=47,
Aug 20 21:29:25.119: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Aug 20 21:29:25.119: :cc_free_feature_vsa freeing 41F12118
Aug 20 21:29:25.119:  vsacount in free is 0
Config is attached
paolo bevilacqua
Take debug vpm signal.
markedavis
Actually the debug dial peer is working.    Here is the vpm debug.
BN-USHUM01-RTR01#
Aug 20 21:37:10.327: htsp_timer_stop3 htsp_setup_req
Aug 20 21:37:10.327: htsp_process_event: [0/0/0, FXOLS_ONHOOK, E_HTSP_SETUP_REQ]fxols_onhook_setup
Aug 20 21:37:10.327: [0/0/0] set signal state = 0xC timestamp = 0
Aug 20 21:37:10.327: htsp_timer - 1300 msec
Aug 20 21:37:10.579: htsp_process_event: [0/0/0, FXOLS_WAIT_DIAL_TONE, E_DSP_SIG_1100]fxols_power_denial_detected
Aug 20 21:37:10.579: htsp_timer2 - 1000 msec
Aug 20 21:37:10.579: htsp_timer_stop
Aug 20 21:37:11.579: htsp_process_event: [0/0/0, FXOLS_WAIT_DIAL_TONE, E_HTSP_EVENT_TIMER2]fxols_power_den_disc
Aug 20 21:37:11.579: htsp_timer_stop
Aug 20 21:37:11.579: htsp_timer_stop2
Aug 20 21:37:11.579: [0/0/0] set signal state = 0x4 timestamp = 0
Aug 20 21:37:11.579: htsp_process_event: [0/0/0, FXOLS_ONHOOK, E_HTSP_RELEASE_REQ]fxols_onhook_release
BN-USHUM01-RTR01#
There is some issue with the circuit, low or unrealiable loop current.
Battery reversal fixed inbound calling? Makes me start to think you might be hitting a ground start circuit but your debugs are showing it as loop start. Try switching the signaling and see if that helps. Make sure you do a shut no shut on the voice port for the change to take place.
