04-11-2016 04:40 AM - edited 03-17-2019 06:31 AM
Hi Experts,
Some of the phones for outgoing calls are getting failed. History of the problem is that we have seperate PT and CSS for E1 and SIP trunks, e.g Before SIP_CSS contains SIP-PTs and E1-PTs, where E1_CSS has only E1-PTs. Offcourse the seperate route patterns also.
like
SIP_CSS E1_CSS
E1-Local-PT E1-Local-PT
E1-National-PT E1-National-PT
SIP-Local-PT
SIP-National-PT
I removed E1-PTs from SIP_CSS in order to make outgoing call totally Isolate either SIP or E1.
By removing E1-PTs from SIP_CSS; phones were no more able to call outside; not sure how many phone.
After getting complaint from some users which were in SIP_CSS, i changed SIP_CSS to E1_CSS; phones work.
Changing SIP_CSS to E1_CSS and revert back to SIP_CSS; works for some phone and not for some phones even the same model, config etc. Did reset phone from cucm with intention; may phone didn't refresh their CSS.
Call from E1 works always fine.
Now the issue is some phones are not able to call outside with SIP_CSS --> SIP TRUNK
Today i noticed below issue on the Gateway, where SIP trunk is connected.
%VOICE_IEC-3-GW: SIP: Internal Error (200, codec mismatch): IEC=1.1.278.7.106.1 on callID 1648039 GUID=1BCCD78000010000000017500C190F0A
VG1RC39FAHQR90AW#sh voice iec description 1.1.278.7.106.1
IEC Version: 1
Entity: 1 (Gateway)
Category: 278 (Media Negotiation Failure due to non-existing Codec)
Subsystem: 7 (SIP)
Error: 106 (200, codec mismatch)
Diagnostic Code: 1
417596: Apr 11 11:16:54.890: %VOICE_IEC-3-GW: SIP: Internal Error (INVITE, invalid IE content): IEC=1.1.100.7.35.2 on callID -1
VG1RC39FAHQR90AW#sh voice iec description 1.1.100.7.35.2
IEC Version: 1
Entity: 1 (Gateway)
Category: 100 (invalid ie contents (100))
Subsystem: 7 (SIP)
Error: 35 (INVITE, invalid IE content)
Diagnostic Code: 2
Your help please.
04-11-2016 08:30 AM
Have you checked the region settings between the phone and the sip trunk and also the codec configured on the dial-peer of your sip trunk..
Please send us "debug ccsip message" from the router
04-12-2016 07:40 AM
Hi Ayodeji,
I will try to send the traces for failed call but till that below is the dial-peer config.
Region, Codec list and SIP trunk on cm snap are attached.
voice service voip
no ip address trusted authenticate
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
signaling forward unconditional
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
early-offer forced
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729br8
dial-peer voice 499 voip
description **** outgoing call to STC SIP***
translation-profile outgoing STC-OUT
destination-pattern 0[123]T
session protocol sipv2
session target ipv4:10.200.7.157
session transport udp
voice-class codec 1
voice-class sip early-offer forced
voice-class sip bind control source-interface GigabitEthernet0/2
voice-class sip bind media source-interface GigabitEthernet0/2
dtmf-relay rtp-nte
no vad
04-12-2016 11:00 AM
Hi Mohsin,
Can you please provide debugs and cucm traces?
04-13-2016 04:16 AM
These error are keep showing on the gateway. I am not sure these are related to call attempt
000160: Apr 13 11:06:01.253: %VOICE_IEC-3-GW: SIP: Internal Error (200, codec mismatch): IEC=1.1.278.7.106.1 on callID 14564 GUID=F544A30000010000000033C40C190F0A
--More--
000161: Apr 13 11:06:06.253: %VOICE_IEC-3-GW: SIP: Internal Error (200, codec mismatch): IEC=1.1.278.7.106.1 on callID 14566 GUID=F70E668000010000000033C50C190F0A
--More--
000162: Apr 13 11:06:46.665: %VOICE_IEC-3-GW: SIP: Internal Error (200, codec mismatch): IEC=1.1.278.7.106.1 on callID 14583 GUID=1017178000010000000033CE0C190F0A
--More--
000163: Apr 13 11:07:15.133: %VOICE_IEC-3-GW: SIP: Internal Error (200, codec mismatch): IEC=1.1.278.7.106.1 on callID 14592 GUID=20C78D8000010000000033D30C190F0A
--More--
000164: Apr 13 11:07:30.997: %VOICE_IEC-3-GW: SIP: Internal Error (200, codec mismatch): IEC=1.1.278.7.106.1 on callID 14597 GUID=2A50F58000010000000033D60C190F0A
--More--
000165: Apr 13 11:07:41.361: %VOICE_IEC-3-GW: SIP: Internal Error (200, codec mismatch): IEC=1.1.278.7.106.1 on callID 14599 GUID=30DF6D0000010000000033D90C190F0A
--More--
000166: Apr 13 11:08:46.773: %VOICE_IEC-3-GW: SIP: Internal Error (200, codec mismatch): IEC=1.1.278.7.106.1 on callID 14629 GUID=579DA38000010000000033EA0C190F0A
--More--
000167: Apr 13 11:08:49.973: %VOICE_IEC-3-GW: SIP: Internal Error (200, codec mismatch): IEC=1.1.278.7.106.1 on callID 14631 GUID=5967670000010000000033EB0C190F0A
--More--
000168: Apr 13 11:08:58.881: %VOICE_IEC-3-GW: SIP: Internal Error (200, codec mismatch): IEC=1.1.278.7.106.1 on callID 14635 GUID=5EC4B18000010000000033ED0C190F0A
--More--
000169: Apr 13 11:09:06.261: %VOICE_IEC-3-GW: SIP: Internal Error (200, codec mismatch): IEC=1.1.278.7.106.1 on callID 14640 GUID=6389658000010000000033EF0C190F0A
--More--
000170: Apr 13 11:09:12.401: %VOICE_IEC-3-GW: SIP: Internal Error (200, codec mismatch): IEC=1.1.278.7.106.1 on callID 14644 GUID=671CEC8000010000000033F10C190F0A
--More--
000171: Apr 13 11:09:16.553: %VOICE_IEC-3-GW: SIP: Internal Error (200, codec mismatch): IEC=1.1.278.7.106.1 on callID 14646 GUID=68E6B00000010000000033F20C190F0A
--More--
000172: Apr 13 11:09:21.421: %VOICE_IEC-3-GW: SIP: Internal Error (200, codec mismatch): IEC=1.1.278.7.106.1 on callID 14650 GUID=6C7A370000010000000033F40C190F0A
--More--
000173: Apr 13 11:09:27.393: %VOICE_IEC-3-GW: SIP: Internal Error (200, codec mismatch): IEC=1.1.278.7.106.1 on callID 14653 GUID=700DBE0000010000000033F80C190F0A
--More--
000174: Apr 13 11:09:31.605: %VOICE_IEC-3-GW: SIP: Internal Error (200, codec mismatch): IEC=1.1.278.7.106.1 on callID 14655 GUID=7270180000010000000033FD0C190F0A
--More--
000175: Apr 13 11:09:35.801: %VOICE_IEC-3-GW: SIP: Internal Error (200, codec mismatch): IEC=1.1.278.7.106.1 on callID 14657 GUID=74D2720000010000000033FE0C190F0A
--More--
000176: Apr 13 11:10:51.413: %VOICE_IEC-3-GW: SIP: Internal Error (200, codec mismatch): IEC=1.1.278.7.106.1 on callID 14665 GUID=A21F200000010000000034050C190F0A
04-13-2016 04:25 AM
We asked you for traces but you are yet to provide them. The configuration you provided only shows the outbound dial-peer. What about the inboud dial-peer. Please send your full sh run and a "debug ccsip message"
04-14-2016 05:04 PM
Sorry, i couldn't provide the traces for the issue mentioned before because some non-working user i converted to E1. Some other users have complained but i did't receive their detail from the department. I will provide it soon.
Now, on the same SIP trunk we are facing another issue. Route Pattern for the SIP-Local for outgoing call is created to call within the city. Call is successful, but some local number in the same city are not dialable; gives busy signal. These same non-working number can be dialed from E1. This problem is only on the SIP trunk not E1.
Calling number : 1515
Called number : 7 digits Local numbers, 01 is access code for local dialing. 014193193(working) ; 014565235 and 014791233 (non-working)
Traces are attached with file name
Like above the national call to other cities are successful but for some other cities is not working.
Called number : 10 digits national numbers, 02 is access code for national dialing.
(non-working cities) 020126480008 and 020138267888 ; (working cities) 020163250488 and 020125374003
CM Route pattern --> SIP_Outgoing-RL (Three sip trunks toward VGW with 172.18.0.10 ; 10.14.22.1 ; 10.14.22.5 destination IPs respectively.)
Route Pattern, VGW configu, Numbers and Traces are attached for working and non working calls.
