Unable to make outbound calls via h323 gateway using SCCP phone but works using SIP phone
Deepak Mehta
Hi All,
I am using a remote LAB set up from one of  cisco training providers.
I have two phones at HQ site one is 9971 and other is 7962 phone.
I have R1 router on Hq site which i am using to make outbound calls to PSTN phone .I have set up this as h323 gateway .All inbound calls are working fine. I can also successfully make outbound calls using SIP phone to the PSTN phone and it is negoiating g729 codec.( Region is same for both gateway and Hq-phone which set to negotiate  g7111 codec ).My first question is why is it negotiating g729?
When i use SCCP 7962 phone outbound call doesn't even work and there is nothing in the q931 debug .
What could be the reason for this.
I would appreciate any guidance on this.
Thank you
Deepak Mehta
Looking at the logs, the call is originating from a CUCM that is not the in the gateways trust list hence why you are getting cause code 21.
Please add a second dial-peer pointing to 11.100.64.11 or add this dial-peer to your trust  list
Apr  9 07:52:06.791: //4/800ECEA10400/H323/cch323_h225_send_release: Cause = 21; Location = 0>>>>>>>>>>>>>>>>>>>>>>>>>>>
Apr  9 07:52:06.791: //4/800ECEA10400/H323/cch323_h225_send_release: h225TerminateRequest: src address = 185273089; dest address = 11.100.64.11
Apr  9 07:52:06.791: //4/800ECEA10400/H323/cch323_h225_set_new_state: Changing from H225_SETUP state to H225_IDLE state
example below:
dial-peer voice 102 voip
pref 1
 destination-pattern 2...
 session target ipv4:11.100.64.11
dtmf-relay h245-alpha
no vad
Please rate all useful posts
9 Replies 9
Jaime Valencia
Did you configure a codec in H323?? If not, g729 is the default
if you don't see the calls hit the GW, it's not making it out of CUCM, check all the basics.
java
if this helps, please rate
Thank you Jaime.
i didn't configure the codec on the h323 ,so I believe you answered the first one.
For second one both Sccp and sip phone is using exact same pattern and also same css.only difference is the protocol and model of phones.
one is 7962 and other is 9971.cucm does show call routing when I do a DNA test for both.
i will try again.
You should see h.323/voice ccapi logs in gateway and verify whether call is hitting gateway or not, so that you can conclude to start troubleshooting in CUCM or gateway.
- Vivek
First thing , i can see the call is routing for both SCCP and SIP phones from CUCM .( As per DNA same pattern is being matched )..
Both phones are matching the dial-peer 100 and 200 .SIP phone is still working fine .
For SCCP 7962 i still unable to establish a call and below debug cch323 h225.
I do not get anything for q931 debug for sccp phone.
callingNumber[2001] calledNumber[95032000]
Apr  9 07:52:06.787: //4/800ECEA10400/H323/setup_ind: ---- calling IE present
Apr  9 07:52:06.787: //4/800ECEA10400/H323/setup_ind: ====== PI = 0
Apr  9 07:52:06.787: //4/800ECEA10400/H323/setup_ind: Receive: infoXCap 0
Apr  9 07:52:06.787: //4/800ECEA10400/H323/setup_ind: Receive: infoXCap ccb 0
setup_ind: is_overlap = 0, info_complete = 0
Apr  9 07:52:06.787: //4/800ECEA10400/H323/setup_ind: Call Manager detected
Apr  9 07:52:06.787: //4/800ECEA10400/H323/cch323_h225_receiver: SETUPIND_CHOSEN: src address = 11.11.11.1; dest address = 11.100.64.11
Apr  9 07:52:06.787: //4/800ECEA10400/H323/run_h225_sm: Received event H225_EV_SETUP_IND while at state H225_IDLE
Apr  9 07:52:06.787: //-1/800ECEA10400/DPM/dpAssociateIncomingPeerCore:
   Calling Number=2001, Called Number=95032000, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
   Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=100
Apr  9 07:52:06.787: //-1/800ECEA10400/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
Apr  9 07:52:06.787: //4/800ECEA10400/H323/common_idle_setupInd_hdlr: full match is found
Apr  9 07:52:06.787: //4/800ECEA10400/H323/cch323_h225_set_new_state: Changing from H225_IDLE state to H225_SETUP state
Apr  9 07:52:06.787: //4/800ECEA10400/H323/cch323_create_incoming_callinfo_block: peer 3AB9F754, voice_peer_tag 100, ccb: 39F8BD90
Apr  9 07:52:06.787: //4/800ECEA10400/H323/cch323_create_incoming_callinfo_block: Calling Party is CCM
Apr  9 07:52:06.787: //4/800ECEA10400/H323/cch323_h225_handle_deferred_ind: UnBuffering deferred indications
Apr  9 07:52:06.791: //4/800ECEA10400/H323/run_h225_sm: Received event H225_EV_RELEASE while at state H225_SETUP>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
R1#
R1#sh run | s dial-peer voice
dial-peer voice 100 voip >>>>>>>>>
 incoming called-number .
 voice-class codec 1
 voice-class h323 1
 dtmf-relay h245-alphanumeric
 no vad
dial-peer voice 200 pots >>>>>>>>>>>>>>
 destination-pattern 9T
 direct-inward-dial
 port 0/1/0:23
 forward-digits 7
dial-peer voice 101 voip
 session target ipv4:11.100.64.12
dial-peer voice 202 pots
 translation-profile incoming hq
Then, as previously explained, you need to move over to CUCM to troubleshoot this.
java
OK , i will look through the CCM traces but what do you think could be the possible reasons of this.
Can you give me few scenrerios which can lead to this .Thank you
example below:
pref 1
no vad
Thank you Ayodeji....let me try this.
Deji-You have hit the bullseye with your expert analysis!!!!!The issue is fixed after adding CUCM to trust list.
I really thank you for guiding me here.
If you can look at below and let me know what do i need to fix this.
Can't make inbound call from SC PSTN-SB phone .Below output is taken from
SB MGCP gateway where call is coming in.
I have tried various options on MGCP gateway config in CUCM eg Display IE or redirecting IE support etc .Also on voice interface supplementary services command (isdn supp-service name calling ) is configured.
pr 13 17:58:06.555: ISDN Se0/1/0:15 Q931: RX <- SETUP pd = 8  callref = 0x0080
        Bearer Capability i = 0x8090A2
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98381
                Exclusive, Channel 1
        Facility i = 0x9F8B0100A11802010302010080105369746543204C6F63616C205053544E
                Protocol Profile =  Networking Extensions
                0xA11802010302010080105369746543204C6F63616C205053544E
                Component = Invoke component
                        Invoke Id = 3
                        Operation = CallingName
                                Name Presentation Allowed Extended
                                Name = SiteC Local PSTN
        Display i = 'SiteC Local PSTN'
        Calling Party Number
R3# i = 0x4181, '70054000'
                Plan:ISDN, Type:Subscriber(local)
        Called Party Number i = 0xA1, '70044001'
                Plan:ISDN, Type:National
Apr 13 17:58:06.559: ISDN Se0/1/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x8080
        Cause i = 0x80E4 - Invalid information element contents>>>>>>>>>>>
