Outgoing calling number
waqas sardar
Hi Guys,
We have added new DID number. when i am calling outside, it showing pilot number instead of DID .
In Debug outgoing number 042356820 showing perfectly.
Phone configure with 6820 and masking 042356820
Voice gateway 2901
cucm 11.5
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98382
Exclusive, Channel 2
Calling Party Number i = 0x0181, '042356820'
Plan:ISDN, Type:Unknown
Called Party Number i = 0x81, '0562386570'
217287: Mar 13 16:31:27.775: ISDN Se0/0/1:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x9273
217288: Mar 13 16:31:31.143: ISDN Se0/0/1:15 Q931: RX <- ALERTING pd = 8 callref = 0x9273
217289: Mar 13 16:31:31.695: ISDN Se0/0/2:15 Q931: RX <- PROGRESS pd = 8 callref = 0x926F
voice translation-rule 2
rule 12 /^6.../ /04235&/
voice translation-profile TO_PSTN
translate calling 2
dial-peer voice 201 pots
trunkgroup PRI
translation-profile outgoing TO_PSTN
Please advise .
Dennis Mink
is the debug below from an outbound call made by 042356820?
the Q931 debug, whicg shows 042356820  as the calling number. so what is being displayed on the called party? not 042356820?
Please remember to rate useful posts, by clicking on the stars below.
+ Yes, debug is when i called from 6820 extension.
+ Display number is pilot number (043613333)
If I am not wrong you are trying to state that whenever you call out to PSTN from extension 6820 [which masked as 042356820 ] the caller ID on called PSTN phone displays 043613333 [which is the pilot number].
In this case I would suggest you to involve provider, reason being the caller ID in the Q.931 set up message which is being sent out to the provider and is absolutely correct as below.
Abhay
Abhay Singh Reyal
The Only Way To Do Great Work Is To Love What You Do. If You Haven’t Found It Yet, Keep Looking. Don’t Settle
