outgoing calls from cisco 9951 drops after 79 seconds
bernsplagata
I have an issue with my sip phones configured on a 2911 router running CME Version 8.6. outgoing calls automatically gets droped after 79 sec see below configuration for voice service voip and voice register global as well as the sip DN's
voice service voip
qsig decode
dtmf-interworking standard
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service h450.2
no supplementary-service h450.3
supplementary-service h450.12
no supplementary-service sip moved-temporarily
redirect ip2ip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
  bind control source-interface Loopback0
  bind media source-interface Loopback0
  rel1xx disable
  registrar server expires max 6300 min 3600
  transport switch udp tcp
  options-ping 60
  no update-callerid
mode cme
source-address 192.168.1.1 port 5060
max-dn 300
max-pool 58
load 9951 sip9951.9-4-1-9.loads
timezone 31
tftp-path flash:
create profile sync 0368313124528633
ntp-server 192.168.100.1 mode directedbroadcast
camera
video
voice register dn  1
number 100
mwi
voice register dn  2
number 110
mwi
voice register template  1
camera
video
voice register template  2
camera
video
voice register pool  1
id mac XXXXXXXXXXXX
type 9951
number 1 dn 1
dtmf-relay sip-notify
voice-class codec 1
username cisco password cisco
description XXXXXXX
no vad
camera
video
voice register pool  2
id mac XXXXXXXXXXXX
type 9951
number 1 dn 2
voice-class codec 1
username musbah password musbah
description 110-XXXXXX
no vad
camera
video
6 Replies 6
can you supply us with a debug isdn q931 output please.
Best Regards
i cannot iput this command in the router.. even i only call the local internal extension call gets cut after 79 secs.  this problem is only hapenning on the SIP phone sccp phones got no issues.  this issue started when i configured a SIP trunk on the CME.
Hi, could you please post debug ccsip message & debug voice ccapi inout for a test call? please provide the calling & called number too.
Please rate all the useful posts
//Suresh Please rate all the useful posts.
I cannot provide as of now the debugs as i took out the phones from my client.  But i can recall the issue came up after configuring a SIP trunk on the CME which affected the SIP phones.  SCCP phones are working jut fine.  I suspect the translation profiles i put in.  See below:
voice translation-rule 3
rule 1 /^.../ /4818300/
voice translation-rule 8
rule 1 /^8/ //
dial-peer voice 10 voip
description **SIP TRUNK PEER**
translation-profile outgoing SIP_2
preference 1
destination-pattern 8T
session protocol sipv2
session target ipv4:X.X.X.X
session transport udp
voice-class codec 1
voice-class sip rel1xx disable
voice-class sip dtmf-relay force rtp-nte
voice-class sip options-ping 60
voice-class sip options-keepalive up-interval 12 down-interval 65 retry 3
voice-class sip bind control source-interface GigabitEthernet0/2
voice-class sip bind media source-interface GigabitEthernet0/2
dtmf-relay rtp-nte
no vad
dial-peer voice 9 voip
description **Incoming call from SIP trunk**
translation-profile incoming IVR_888
incoming called-number .%
voice-class codec 1
dtmf-relay rtp-nte
no vad
hi suresh,
I am curious by the source ip address media 192.168.1.1 i have forced this in the SIP peer interface i am not sure why it is still showing
Please see below debug ccsip calls:
Feb  3 14:43:44: //224742/23D6DCD4BEB8/SIP/Call/sipSPICallInfo:
Disconnect Cause (CC)    : 16
Disconnect Cause (SIP)   : 200
Feb  3 14:44:07: //224759/4AB743D1BECD/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x2B702550
State of The Call        : STATE_ACTIVE
TCP Sockets Used         : NO
Calling Number           : 999
Called Number            : 90535665576
Source IP Address (Sig  ): 192.168.1.1
Destn SIP Req Addr:Port  : 10.10.100.35:5060
Destn SIP Resp Addr:Port : 10.10.100.35:5060
Destination Name         : 10.10.100.35
Feb  3 14:44:07: //224759/4AB743D1BECD/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 2
Media Stream             : 1
Negotiated Codec         : g711alaw
Negotiated Codec Bytes   : 160
Nego. Codec payload      : 8 (tx), 8 (rx)
Negotiated Dtmf-relay    : 0
Dtmf-relay Payload       : 0 (tx), 0 (rx)
Source IP Address (Media): 192.168.1.1
Source IP Port    (Media): 27822
Destn  IP Address (Media): 10.10.100.35
Destn  IP Port    (Media): 20624
Orig Destn IP Address:Port (Media): [ - ]:0
UC-2911-GIZ#
Media Stream             : 2
Negotiated Codec         :
Negotiated Codec Bytes   : 0
Nego. Codec payload      : 97 (tx), 97 (rx)
Source IP Port    (Media): 0
Destn  IP Port    (Media): 0
Feb  3 14:45:26: //224759/4AB743D1BECD/SIP/Call/sipSPICallInfo:
State of The Call        : STATE_DEAD
Feb  3 14:45:26: //224759/4AB743D1BECD/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Media Stream             : 2
Negotiated Codec         :
Disconnect Cause (CC)    : 127
DEBUG voice ccapi inout
Call Control Block (CCB) : 0x2B729AE0
Feb  3 14:49:17: //224814/03763F40BF08/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Source IP Port    (Media): 22960
Destn  IP Port    (Media): 9458
Media Stream             : 2
Negotiated Codec         :
Feb  3 14:49:53: //-1/2167A935BF19/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=101
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=0   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Feb  3 14:49:53: //-1/2167A935BF19/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x2BF1D2B0, Call Info(
   Calling Number=101,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
   Incoming Dial-peer=20001, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Feb  3 14:49:53: //-1/2167A935BF19/CCAPI/ccCheckClipClir:
   In: Calling Number=101(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=101(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Feb  3 14:49:53: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Feb  3 14:49:53: :cc_get_feature_vsa malloc success
Feb  3 14:49:53:  cc_get_feature_vsa count is 3
Feb  3 14:49:53: :FEATURE_VSA attributes are: feature_name:0,feature_time:736025752,feature_id:4499
Feb  3 14:49:53: //224827/2167A935BF19/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=101(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown))
Feb  3 14:49:53: //224827/2167A935BF19/CCAPI/cc_process_call_setup_ind:
   Event=0x2B449320
Feb  3 14:49:53: //224827/2167A935BF19/CCAPI/ccCallSetContext:
   Context=0x2C635D4C
   >>>>CCAPI handed cid 224827 with tag 20001 to app "_ManagedAppProcess_Default"
Feb  3 14:49:53: //224827/2167A935BF19/CCAPI/ccCallSetupAck:
   Call Id=224827
Feb  3 14:49:53: //224827/2167A935BF19/CCAPI/cc_api_set_transfer_info:
   Transfer Number=, Transfer Reason=0x0
Feb  3 14:49:53: //224827/2167A935BF19/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=TRUE, Tone=Dial Tone,
   Tone Direction=Network, Params=0x0, Call Id=224827
Feb  3 14:49:53: //224827/2167A935BF19/CCAPI/ccSetDigitTimeouts:
   Initial Digit Timeout=-1000(ms), Inter Digit Timeout=-1000(ms)
   Call Entry(Inter Digit Timeout=10000(ms), Initial Digit Timeout=10000(ms))
Feb  3 14:49:53: //224827/2167A935BF19/CCAPI/ccCallReportDigits:
   (callID=0x36E3B, digit_event=0x1, enable=TRUE, consume=FALSE)
   Enabled=TRUE, Call Id=224827
Feb  3 14:49:53: //224827/2167A935BF19/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x2BF1D2B0, callID=0x36E3B, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
   Enabled=TRUE, Disposition=0x0, Interface=0x2BF1D2B0, Call Id=224827
   Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=10000(ms))
Feb  3 14:49:54: //224827/2167A935BF19/CCAPI/cc_api_call_digit_begin:
   Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
   Source Call Id=224827, Digit=1, DigitBeginFlags=0x0,
   Rtp Timestamp=0x3973080, Rtp Expiration=0x0
Feb  3 14:49:54: //224827/2167A935BF19/CCAPI/cc_api_call_digit_end:
   Source Call Id=224827, Digit=1, Duration=100,
   Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
   Call Entry(Handoff Depth=0)
   Rtp Timestamp=0x397AD80, Rtp Expiration=0x0
   Rtp Timestamp=0x3982A80, Rtp Expiration=0x0
Feb  3 14:49:54: //224827/2167A935BF19/CCAPI/ccCallReportDigits:
   (callID=0x36E3B, digit_event=0x0, enable=FALSE, consume=FALSE)
Feb  3 14:49:54: //224827/2167A935BF19/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x2BF1D2B0, callID=0x36E3B, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
Feb  3 14:49:54: //224827/2167A935BF19/CCAPI/ccCallProceeding:
   Progress Indication=NULL(0)
Feb  3 14:49:54: //224827/2167A935BF19/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=20002, Params=0x2C6348DC, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Feb  3 14:49:54: //224827/2167A935BF19/CCAPI/ccCheckClipClir:
   Destination Pattern=111$, Called Number=111, Digit Strip=TRUE
   Called Number=111(TON=Unknown, NPI=Unknown),
   Redirect Number=, Display Info=Esra Abukar
   Account Number=, Final Destination Flag=FALSE,
   Guid=2167A935-8C00-11E3-BF19-E048D6366222, Outgoing Dial-peer=20002
Feb  3 14:49:54: //224827/2167A935BF19/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=101
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=111
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
Feb  3 14:49:54: //224827/2167A935BF19/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x2BB2F93C, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=101,(Calling Name=Esra Abukar)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=111(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE, Outgoing Dial-peer=20002, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Feb  3 14:49:54: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Feb  3 14:49:54: :cc_get_feature_vsa malloc success
Feb  3 14:49:54:  cc_get_feature_vsa count is 4
Feb  3 14:49:54: :FEATURE_VSA attributes are: feature_name:0,feature_time:736025304,feature_id:4500
Feb  3 14:49:54: //224828/2167A935BF19/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Feb  3 14:49:54: //224828/2167A935BF19/CCAPI/ccCallSetContext:
   Context=0x2C63488C
Feb  3 14:49:54: //224827/2167A935BF19/CCAPI/ccSaveDialpeerTag:
Feb  3 14:49:54: //224828/2167A935BF19/CCAPI/cc_api_update_call_info:
   Interface=0x2BB2F93C, Call Id=0x36E3C
Feb  3 14:49:54: //224828/2167A935BF19/CCAPI/cc_api_call_proceeding:
   Interface=0x2BB2F93C, Progress Indication=NULL(0)
Feb  3 14:49:54: //224828/2167A935BF19/CCAPI/cc_api_call_alert:
   Interface=0x2BB2F93C, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
   Call Entry(Retry Count=0, Responsed=TRUE)
Feb  3 14:49:54: //224827/2167A935BF19/CCAPI/ccCallAlert:
   Call Entry(Responsed=TRUE, Alert Sent=TRUE)
Feb  3 14:49:54: //224827/2167A935BF19/CCAPI/ccCallFeature:
   Feature Type=25, Call Id=224827
Feb  3 14:49:56: //224828/2167A935BF19/CCAPI/cc_api_call_connected:
   Interface=0x2BB2F93C, Data Bitmask=0x1, Progress Indication=NULL(0),
   Connection Handle=0
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Feb  3 14:49:56: //224827/2167A935BF19/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
Feb  3 14:49:56: //224827/2167A935BF19/CCAPI/ccConferenceCreate:
   (confID=0x2BE909C0, callID1=0x36E3B, gcid=2167A935-8C0011E3-BF19E048-D6366222, tag=0x0)
Feb  3 14:49:56: //224828/2167A935BF19/CCAPI/ccConferenceCreate:
   (confID=0x2BE909C0, callID2=0x36E3C, gcid=2167A935-8C0011E3-BF19E048-D6366222, tag=0x0)
   Conference Id=0x2BE909C0, Call Id1=224827, Call Id2=224828, Tag=0x0
Feb  3 14:49:56: //224827/2167A935BF19/CCAPI/cc_api_bridge_done:
   Conference Id=0x442, Source Interface=0x2BF1D2B0, Source Call Id=224827,
   Destination Call Id=224828, Disposition=0x0, Tag=0xFFFFFFFF
Feb  3 14:49:56: //224828/2167A935BF19/CCAPI/cc_api_bridge_done:
   Conference Id=0x442, Source Interface=0x2BB2F93C, Source Call Id=224828,
   Destination Call Id=224827, Disposition=0x0, Tag=0xFFFFFFFF
Feb  3 14:49:56: //224827/2167A935BF19/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x442, Destination Call Id=224828)
   Call Entry(Conference Id=0x442, Destination Call Id=224827)
Feb  3 14:49:56: //224827/2167A935BF19/CCAPI/cc_api_caps_ind:
   Destination Interface=0x2BB2F93C, Destination Call Id=224828, Source Call Id=224827,
   Caps(Codec=0x1, Fax Rate=0x2, Vad=0x1,
   Modem=0x2, Codec Bytes=160, Signal Type=2)
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
Feb  3 14:49:56: //224828/2167A935BF19/CCAPI/cc_api_caps_ind:
   Destination Interface=0x2BF1D2B0, Destination Call Id=224827, Source Call Id=224828,
Feb  3 14:49:56: //224828/2167A935BF19/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1),
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=6739)
Feb  3 14:49:56: //224827/2167A935BF19/CCAPI/cc_api_caps_ack:
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=3884)
Feb  3 14:49:56: //224827/2167A935BF19/CCAPI/ccCallConnect:
   Progress Indication=NULL(0), Data Bitmask=0x1
   Call Entry(Connected=TRUE, Responsed=TRUE)
Feb  3 14:49:56: //224827/2167A935BF19/CCAPI/ccCallFeature:
Feb  3 14:49:56: //224828/2167A935BF19/CCAPI/cc_api_voice_mode_event:
   Call Id=224828
   Call Entry(Context=0x2C63488C)
Feb  3 14:49:56: //224827/2167A935BF19/CCAPI/cc_api_voice_mode_event:
   Call Id=224827
   Call Entry(Context=0x2C635D4C)
Feb  3 14:49:56: //224827/2167A935BF19/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x442, Call Id1=224827, Call Id2=224828
Feb  3 14:50:36: //224814/03763F40BF08/CCAPI/cc_api_call_disconnected:
   Cause Value=127, Interface=0x30C81BC0, Call Id=224814
   Call Entry(Responsed=TRUE, Cause Value=127, Retry Count=0)
Feb  3 14:50:36: //224814/03763F40BF08/CCAPI/ccConferenceDestroy:
   Conference Id=0x441, Tag=0x0
Feb  3 14:50:36: //224814/03763F40BF08/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0x441, Source Interface=0x30C81BC0, Source Call Id=224814,
   Destination Call Id=224819, Disposition=0x0, Tag=0x0
Feb  3 14:50:36: //224819/03763F40BF08/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0x441, Source Interface=0x3109559C, Source Call Id=224819,
   Destination Call Id=224814, Disposition=0x0, Tag=0x0
Feb  3 14:50:36: //224814/03763F40BF08/CCAPI/cc_generic_bridge_done:
Feb  3 14:50:36: //224814/03763F40BF08/CCAPI/ccCallDisconnect:
   Cause Value=127, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=127)
   Cause Value=127, Call Entry(Responsed=TRUE, Cause Value=127)
Feb  3 14:50:36: //224819/03763F40BF08/CCAPI/ccCallDisconnect:
   Cause Value=127, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Feb  3 14:50:36: //224819/03763F40BF08/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
Feb  3 14:50:36: //224819/03763F40BF08/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x3109559C, Tag=0x0, Call Id=224819,
   Call Entry(Disconnect Cause=127, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Feb  3 14:50:36: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Feb  3 14:50:36: :cc_free_feature_vsa freeing 2BDED830
Feb  3 14:50:36:  vsacount in free is 3
Feb  3 14:50:36: //224814/03763F40BF08/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x30C81BC0, Tag=0x0, Call Id=224814,
Feb  3 14:50:36: :cc_free_feature_vsa freeing 2BDEDE50
Feb  3 14:50:36:  vsacount in free is 2
i get the same result eventhough i have changed the bind source interface to that of the ip for the sip peer...
