Outgoing calls to Emergency numbers only
abuahmed.sd
Hi, community,
I need to determine some IP phones extensions to call Emergency numbers only (its looks like 900, 999, 992, and so on )
I need to do that from CUCM instead of a router.
How can I do that?
Create  new Partition
P_Emergency
Create New Calling Search Space
CSS_Emergency >> Add P_Emergency
On Phone >> Dn >> Assign Calling search space CSS_Emergency.
Create RP and put them on P_Emergency
Response Signature
ashok_boin
Level 5
Level 5
You can limit through putting Emergency numbers only calling pattern in a partition and put in a Calling search space & assign to IP phones in question.
With best regards...
Ashok
P_Emergency
Response Signature
Thanks for all to participate and special Thanks to Mr  @Nithin Eluvathingal
It's work fine
Scott Leport
Level 7
Level 7
Only small thing to add to what Nithin suggested is to make sure you’ve assigned a Route List in your Route Patterns and your Route List has your voice gateway / trunk attached to the Route List. Otherwise your calls will fail.
