Outside Dial Tone in CUCM 9.1
Dmitri Popkov
Good day!
Today, i've configured an outside route pattern to PSTN (through CCME-2901 - Gateway)
Route pattern - 9.8XXXXXXXXXX
Call Classification - Offnet
Checked - "provide outside Dial Tone"
And Configured Called Party Transformations
Discard digits - "PreDot"
But When i tried to dial outside - there is no dial tone at all...
Where is a mistake? Can you help me pleas.
Also I have second route pattern
Route pattern - 7XX
Call Classification - Onnet
Unchecked - "provide outside Dial Tone"
Here is a trace:
  • Results Summary
    • Calling Party Information
      • Calling Party = 6501
      • Partition = GD_MAIN_CENTER
      • Device CSS = GD_CENTER
      • Line CSS =
      • AAR Group Name =
      • AAR CSS =
    • Dialed Digits = 989166047801
    • Match Result = RouteThisPattern
    • Matched Pattern Information
      • Pattern = 9.8XXXXXXXXXX
      • Time Schedule =
    • Called Party Number =  8916604XXXX
    • Time Zone = Europe/Moscow
    • End Device = 172.16.4.5
    • Call Classification = OffNet
    • InterDigit Timeout = NO
    • Device Override = Disabled
    • Outside Dial Tone = NO
  • Call Flow
    • TranslationPattern :Pattern=
      • Partition =
      • Positional Match List = 8916604XXXX
      • Calling Party Number = 6501
      • PreTransform Calling Party Number =
      • PreTransform Called Party Number =
      • Calling Party Transformations
        • External Phone Number Mask = NO
        • Calling Party Mask =
        • Prefix =
        • CallingLineId Presentation =
        • CallingName Presentation =
      • ConnectedParty Transformations
        • ConnectedLineId Presentation =
        • ConnectedName Presentation =
      • Called Party Transformations
        • Called Party Mask =
        • Discard Digits Instruction =
        • Prefix =
        • Called Number =
    • Route Pattern :Pattern= 9.8XXXXXXXXXX
      • DialPlan =
      • Route Filter
        • Filter Name =
        • Filter Clause =
      • Require Forced Authorization Code = No
      • Authorization Level = 0
      • Require Client Matter Code = No
      • PreTransform Calling Party Number = 6501
      • PreTransform Called Party Number = 98916604XXXX
        • Prefix =
        • CallingLineId Presentation = Default
        • CallingName Presentation = Default
        • ConnectedLineId Presentation = Default
        • ConnectedName Presentation = Default
        • Discard Digits Instruction = PreDot
        • Prefix =
        • Called Number = 89166047801
    • Device :Type= H323Gateway
      • End Device Name = 172.16.4.5
      • PortNumber =
      • Device Status = UnKnown
      • AAR Group Name =
      • AAR Calling Search Space =
      • AAR Prefix Digits =
      • Inbound Fast Start = Disabled
      • Outbound Fast Start = Disabled
      • Call Classification = Use System Default
      • Tunneled Protocol = None
        • Calling Party Selection = Originator
        • Calling Party Presentation = Default
        • CallerID DN =
  • Alternate Matches
    • Note: Information Not Available
    13 Replies 13
    Chris Deren
    When you say you have no dial tone, do you mean the secondary dial tone after your press 9?
    Or that the call never goes out?
    If the first then this is a common mistake and you will need to ensure all of your patterns including translations need to have "provide outside dial tone" checked and you cannot have any DNs starting with 9 or X or anything that would create an overlap.
    If the second then please post the GW config and let us know what type of circuit the call goes out of.
    HTH,
    Chris
    Yes, i have no secondary dial tone when i dial outside.
    I have checked "provide outside Dial Tone" in another pattern, but still dont have secondary dial tone, but outbound call successfully goes out.
    But when i change pattern to - 98XXXXXXXXXX, i receive a secondary dial tone but call never goes out...
    Do you have the dial-peers configured for such calls??
    Since you mention it's pointing to a CME, I assume you're using H323
    And BTW, that's not a trace, that's a DNA result.
    java
    if this helps, please rate
    www.cisco.com/go/pdihelpdesk
    java
    OK, so which pattern does not and which provides secondary dial tone?
    Chris
    Dmitri Popkov
    Yes, on CME i've outgoing dial-peer
    dial-peer voice 2100 voip
    translation-profile outgoing TRANSFORM-OUT-9
    huntstop
    destination-pattern 9T
    session protocol sipv2
    session target ipv4:195.88.224.20
    dtmf-relay rtp-nte
    codec g711ulaw
    fax rate 9600
    fax nsf 000000
    fax protocol t38 version 0 ls-redundancy 5 hs-redundancy 2 fallback none
    no vad
    And translation-profile, because ISP only allows strings with "8" at the begining
    voice translation-rule 1
    rule 1 /9/ //
    voice translation-profile TRANSFORM-OUT-9
    translate called 1
    Dmitri Popkov
    Route pattern - 7XX - provides outside dial tone
    Route pattern - 9.8XXXXXXXXXX - doesn't provide
    And as i mentioned earlier if i change my pattern - 9.8XXXXXXXXXX - to 98XXXXXXXXXX - i cant make outgoinig calls.
    Called phone rings (mobile phones), but two-way connection - doesnt establish
    Still cant solve this problem?...( Any thoughts...
    Dmitri,
    The reason why 9.8XXXXXXXXXX doesn't work is because CUCM is configured to drop predot which would make the call appear to your GW at 8XXXXXXXXXX, which you probably don't have a dialpeer that would match that pattern. What happens when you're able to dial out successfully? Could you provide a full config of your GW?
    Yosh
    HTH Regards, Yosh
    Yes, you are right& i've added additional route 8XXXXXXXXXX and finally i can make a call, but again there was no
    secondary dial tone.
    Here is part of GW config:
    voice service voip
    allow-connections h323 to sip
    allow-connections sip to h323
    allow-connections sip to sip
    fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
    h323
    sip
      bind control source-interface GigabitEthernet0/0
      bind media source-interface GigabitEthernet0/0
      registrar server expires max 1200 min 300
    voice class codec 1
    codec preference 1 g711alaw
    codec preference 2 g711ulaw
    codec preference 3 g729br8
    voice class h323 1
      h225 timeout tcp establish 3
    interface GigabitEthernet0/1
    description GWD-LAN$ES_LAN$
    ip address 172.16.4.5 255.255.255.0
    ip access-group 23 in
    duplex auto
    speed auto
    h323-gateway voip interface
    h323-gateway voip bind srcaddr 172.16.4.5
    dial-peer voice 2001 voip
    description TO TOPTELECOM
    huntstop
    destination-pattern 8T
    dtmf-relay rtp-nte
    codec g711ulaw
    fax rate 9600
    fax nsf 000000
    no vad
    dial-peer voice 1020 voip
    description TRUNK-TO-CUCM-9.1
    destination-pattern 65..
    session target ipv4:172.16.4.250
    voice-class codec 1
    voice-class h323 1
    dtmf-relay cisco-rtp
    Do you still have the "Provide Outside Dialtone" on Route pattern - 9.8XXXXXXXXXX? Also as Chris mentioned, you can't have any extensions starting with 9 since this would cause you to not to hear a secondary dialtone.
    Yosh
    HTH Regards, Yosh
    anytime I have an issue with providing secondary dial tone I will use "Route Plan Report" and do a search for all patterns that begins with 9. Like has been mentioned it could be a phone DN, Call Park, Call Pickup, voicemail ports, or any other DN and\or pattern.  Happy hunting
    Everything has working correctly for years, then while working with Cisco TAC on an Attendant Console issue. He created a directory number of 99999 for a template.
    Then everyone who pressed 9 to get a outside line would have to wait until the 2nd number was pressed to get a tone.
    I exported my route patterns to verify that all patterns contained Provide Outside Dial Tone.
    I don't create Directory Numbers with "9" but a search provided me the answer i was looking for.
    I had a similar issue too. it turned out that if you want to use 9 for outside dial tone you need to be sure there are no DN's that begin with 9. If there is you need to remove them or use a digit that no extensions are starting with.
    In CUCM go to Call Routing and then click Route Plan Report to see the all DN's in your route paln.
