Kindly note that the deployed phones are dual line mapped with a 3 digit extn and a DID number. now if some one calls on the mapped DID numbers the call lands up on the right extension, the issue is if some one from internal calls up the outward numbers the system picks up the Board number as such the mapped DID number dosent display on the called number... would any one help me in this regard... attached is the current configuration.
FYi
Board number : 4540700
Extn Number : 705
Extn mapped with DID: 4540705
when this extn makes an outward dial the displayed number is : 4540700
Since the numbers are masked in the config, i couldn't find out where 4540700 is configured. Where exactly is 4540700 number configured?
Enable 'debug isdn q931' , 'debug voip translation', 'debug voip ccapi inout' and make an outbound call. Check what calling number is sent out to the Telco and where the translation is being performed.
Nitesh
PS:Pl rate helpful posts
Hi Syed,
I feel it's problem with your translation rules as I see the following translation rule to be matched when you are calling out for "calling" numbers.
voice translation-rule 30
rule 1 /^055/ /9055/
rule 2 /^04/ /904/
This will not have any impact on source calling number as "705" as this rule matches only the numbers beginning with 055 or 04.
Can you pls try once with the following rule?
rule 3 /\(.*\)/ /4540\1/
Regards...
-Ashok.
Dear Sir,
Acknowledge, Let me check and confirmed to you!
Dear Sir,
I had tried this by deleting this rule
and configure a new rule with
But i am trying to dial out lets suppose my number to it is taking 454090552488628 and unknown prompt is coming
but when i removed i am dialing out with including 9
My current voice translation rules are
voice translation-rule 1
rule 1 /^............$/ /9000/
rule 2 /^............$/ /9/
rule 3 /^............$/ /904/
voice translation-rule 2
rule 1 /\(.*\)/ /9\1/
voice translation-rule 9
rule 1 /^911$/ /911/
rule 2 /^9\(.*\)/ /\1/
--More-- rule 3 /^[0-9]+/ /9&/
rule 4 /^............$/ /9000/
rule 5 /\(.*\)/ /00\9/
voice translation-profile PSTN-to-internal
translate calling 2
translate called 1
voice-port 0/0/0:15
translation-profile incoming PSTN-to-internal
translate calling 2
translate called 1
voice-port 0/0/0:15
My Board number is 4540700 and and everey extension is mapped with a individual DID number when i am calling form any set my borad number is appearing my question is that why my direct number is not apperaing
Hi Syed,
Have you removed the following from your config?
"translation-profile outgoing callingpstn" under Voice port 0/0/0:15
You need to concentrate on this line as you would like to change your caller ID when calling outside. And, you need to change the translation profile as well as you are using same rule to convert both calling (your internal) and called (pstn number) which is why you are seeing the called number converted and unable to call out.
voice translation-profile callingpstn
translate calling 30
translate called 30
Please try to travel with call flow...
1. Outbound - What translations do you need for calling and called number? How your calling number displays at Voice gateway before applying the translation? And then think about any translations needed for "Called number" (PSTN)? If there is no requirement, then remove "translate called 30" from the above "callingpstn" profile.
Hope it helps...
Regards..
-Ashok.
Dear Sir,
Currently my translation rule are,
translate calling 2
translate called 1
voice-port 0/0/0:15
But, the thing is that when i am dialing out form any extension to any 04 code and then number i am able to dial out properly but when i am dialing out with 04 code and to any number with the given DID List like 044540728 i am not able to dial out its giving me UNKNOWN number. In that scenario when i an incoming call is coming to that individual number that number rings.
ephone-dn 21
number 728 secondary 4540728
label 4540728
description Spare Desk 7
name Spare Desk 7
call-forward busy 7000
call-forward noan 7000 timeout 30
corlist incoming user900-international
ephone 21
mac-address 1CAA.0710.33A4
ephone-template 1
username "SpareDesk7"
type 7942
button 1:21
Now, with this setup i want to dial out to any number with my direct DID number but still its showing my main board number instead of my direct number what configuration should i do on my router ?
We have a PRI Line with 100 channels and my main board number is 4540700 coming to all outgoing calls.
Hi Syed,
You are not using any translations when dialing out under Voice port 0/0:15. Pls fix this and try with the steps mentioned in above.
Hope it helps...
Regards...
-Ashok.
Dear Sir,
Currently my setup is:
Then, I have created one profile
translate calling 2
translate called 1
Then, I have mapped my profile with my voice port for outgoing:
voice-port 0/0/0:15
Before calling to my cell number from any phone set I have enabled a Debugq931 for testing:
Jul 31 07:54:41.455: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1, Calling num 729
Jul 31 07:54:41.455: ISDN Se0/0/0:15 Q931: Sending SETUP callref = 0x0985 callID = 0x890E switch = primary-net5 interface = User
Jul 31 07:54:41.459: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0985
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839F
Exclusive, Channel 31
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x0180, '729'
Plan:ISDN, Type:Unknown
Called Party Number i = 0x81, '0552488628'
Jul 31 07:54:41.467: ISDN Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0x8985
Jul 31 07:54:44.471: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x8985
Jul 31 07:54:44.583: ISDN Se0/0/0:15 Q931: RX <- PROGRESS pd = 8 callref = 0x8985
Progress Ind i = 0x8188 - In-band info or appropriate now available
Jul 31 07:54:53.607: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x0985
Cause i = 0x8090 - Normal call clearing
Jul 31 07:54:53.615: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x8985
Jul 31 07:54:53.615: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x0985
And also enabled Debug voice capp inout:
voip ccapi inout debugging is on
AVEVA_CME#
Jul 31 07:47:43.987: //-1/35A79B1DB55D/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=
----- ccCallInfo IE subfields -----
cisco-ani=729
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
cisco-redirectreason=0 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
Jul 31 07:47:43.987: //-1/35A79B1DB55D/CCAPI/cc_api_call_setup_ind_common:
Interface=0x31B8F960, Call Info(
Calling Number=729,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
Incoming Dial-peer=20043, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Jul 31 07:47:43.987: //-1/35A79B1DB55D/CCAPI/ccCheckClipClir:
In: Calling Number=729(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Out: Calling Number=729(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Jul 31 07:47:43.987: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jul 31 07:47:43.987: :cc_get_feature_vsa malloc success
Jul 31 07:47:43.987: cc_get_feature_vsa count is 1
Jul 31 07:47:43.991: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jul 31 07:47:43.991: :FEATURE_VSA attributes are: feature_name:0,feature_time:805522552,feature_id:5377
Jul 31 07:47:43.991: //5265/35A79B1DB55D/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=729(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=(TON=Unknown, NPI=Unknown))
Jul 31 07:47:43.991: //5265/35A79B1DB55D/CCAPI/cc_process_call_setup_ind:
Event=0x313457F8
Jul 31 07:47:43.991: //5265/35A79B1DB55D/CCAPI/ccCallSetContext:
Context=0x32DA02B8
>>>>CCAPI handed cid 5265 with tag 20043 to app "_ManagedAppProcess_Default"
Jul 31 07:47:43.991: //5265/35A79B1DB55D/CCAPI/ccCallSetupAck:
Call Id=5265
Jul 31 07:47:43.991: //5265/35A79B1DB55D/CCAPI/cc_api_set_transfer_info:
Transfer Number=, Transfer Reason=0x0
Jul 31 07:47:43.991: //5265/35A79B1DB55D/CCAPI/ccGenerateToneInfo:
Stop Tone On Digit=TRUE, Tone=Dial Tone,
Tone Direction=Network, Params=0x0, Call Id=5265
Jul 31 07:47:43.991: //5265/35A79B1DB55D/CCAPI/ccSetDigitTimeouts:
Initial Digit Timeout=-1000(ms), Inter Digit Timeout=-1000(ms)
Call Entry(Inter Digit Timeout=10000(ms), Initial Digit Timeout=10000(ms))
Jul 31 07:47:43.991: //5265/35A79B1DB55D/CCAPI/ccCallReportDigits:
(callID=0x1491, digit_event=0x1, enable=TRUE, consume=FALSE)
Enabled=TRUE, Call Id=5265
Jul 31 07:47:43.991: //5265/35A79B1DB55D/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x31B8F960, callID=0x1491, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
Enabled=TRUE, Disposition=0x0, Interface=0x31B8F960, Call Id=5265
Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=2000(ms))
Jul 31 07:47:44.335: //5265/35A79B1DB55D/CCAPI/cc_api_call_digit_begin:
Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Source Call Id=5265, Digit=9, DigitBeginFlags=0x0,
Rtp Timestamp=0x2334B20, Rtp Expiration=0x0
Jul 31 07:47:44.335: //5265/35A79B1DB55D/CCAPI/cc_api_call_digit_end:
Source Call Id=5265, Digit=9, Duration=100,
Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Call Entry(Handoff Depth=0)
Jul 31 07:47:44.655: //5265/35A79B1DB55D/CCAPI/cc_api_call_digit_begin:
Source Call Id=5265, Digit=0, DigitBeginFlags=0x0,
Rtp Timestamp=0x233C820, Rtp Expiration=0x0
Jul 31 07:47:44.655: //5265/35A79B1DB55D/CCAPI/cc_api_call_digit_end:
Source Call Id=5265, Digit=0, Duration=100,
Jul 31 07:47:45.035: //5265/35A79B1DB55D/CCAPI/cc_api_call_digit_begin:
Source Call Id=5265, Digit=5, DigitBeginFlags=0x0,
Rtp Timestamp=0x2344520, Rtp Expiration=0x0
Jul 31 07:47:45.035: //5265/35A79B1DB55D/CCAPI/cc_api_call_digit_end:
Source Call Id=5265, Digit=5, Duration=100,
Jul 31 07:47:45.195: //5265/35A79B1DB55D/CCAPI/cc_api_call_digit_begin:
Rtp Timestamp=0x234C220, Rtp Expiration=0x0
Jul 31 07:47:45.195: //5265/35A79B1DB55D/CCAPI/cc_api_call_digit_end:
Jul 31 07:47:45.451: //5265/35A79B1DB55D/CCAPI/cc_api_call_digit_begin:
Source Call Id=5265, Digit=2, DigitBeginFlags=0x0,
Rtp Timestamp=0x2353F20, Rtp Expiration=0x0
Jul 31 07:47:45.451: //5265/35A79B1DB55D/CCAPI/cc_api_call_digit_end:
Source Call Id=5265, Digit=2, Duration=100,
Jul 31 07:47:45.695: //5265/35A79B1DB55D/CCAPI/cc_api_call_digit_begin:
Source Call Id=5265, Digit=4, DigitBeginFlags=0x0,
Rtp Timestamp=0x235BC20, Rtp Expiration=0x0
Jul 31 07:47:45.699: //5265/35A79B1DB55D/CCAPI/cc_api_call_digit_end:
Source Call Id=5265, Digit=4, Duration=100,
Jul 31 07:47:46.007: //5265/35A79B1DB55D/CCAPI/cc_api_call_digit_begin:
Source Call Id=5265, Digit=8, DigitBeginFlags=0x0,
Rtp Timestamp=0x2363920, Rtp Expiration=0x0
Jul 31 07:47:46.007: //5265/35A79B1DB55D/CCAPI/cc_api_call_digit_end:
Source Call Id=5265, Digit=8, Duration=100,
Jul 31 07:47:46.175: //5265/35A79B1DB55D/CCAPI
AVEVA_CME#/cc_api_call_digit_begin:
Rtp Timestamp=0x236B620, Rtp Expiration=0x0
Jul 31 07:47:46.175: //5265/35A79B1DB55D/CCAPI/cc_api_call_digit_end:
AVEVA_CME#CAPI/cc_api_call_digit_end:
Jul 31 07:47:46.399: //5265/35A79B1DB55D/CCAPI/cc_api_call_digit_begin:
Source Call Id=5265, Digit=6, DigitBeginFlags=0x0,
Rtp Timestamp=0x2373320, Rtp Expiration=0x0
Jul 31 07:47:46.399: //5265/35A79B1DB55D/CCAPI/cc_api_call_digit_end:
Source Call Id=5265, Digit=6, Duration=100,
AVEVA_CME# Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Jul 31 07:47:46.739: //5265/35A79B1DB55D/CCAPI/cc_api_call_digit_begin:
Rtp Timestamp=0x237B020, Rtp Expiration=0x0
Jul 31 07:47:46.739: //5265/35A79B1DB55D/CCAPI/cc_api_call_digit_end:
Destination Inte
AVEVA_CME#rface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Jul 31 07:47:47.043: //5265/35A79B1DB55D/CCAPI/cc_api_call_digit_begin:
Rtp Timestamp=0x2382D20, Rtp
AVEVA_CME#
AVEVA_CME#
AVEVA_CME#
AVEVA_CME#
AVEVA_CME#
AVEVA_CME# Expiration=0x0
Jul 31 07:47:47.043: //5265/35A79B1DB55D/CCAPI/cc_api_call_digit_end:
Jul 31 07:47:47.043: //5265/35A79B1DB55D/CCAPI/ccCallReportDigits:
(callID=0x1491, digit_event=0x0, enable=FALSE, consume=FAL
Jul 31 07:47:47.043: //5265/35A79B1DB55D/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x31B8F960, callID=0x1491, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
C
AVEVA_CME#all Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=2000(ms))
Jul 31 07:47:47.043: //5265/35A79B1DB55D/CCAPI/ccCallProceeding:
Progress Indication=NULL(0)
Jul 31 07:47:47.043: //5265/35A79B1DB55D/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=25, Params=0x30132340, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Jul 31 07:47:47.043: //5265/35A79B1DB55D/CCAPI/ccCheckClipClir:
AVEVA_CME#ning=Not Screened, Presentation=Allowed)
Destination Pattern=9055......., Called Number=90552488628, Digit Strip=TRUE
AVEVA_CME#lowed),
Called Number=90552488628(TON=Unknown, NPI=Unknown),
Redirect Number=, Display Info=Spare Desk 8
Account Number=, Final Destination Flag=FALSE,
Guid=35A79B1D-BA80-11E0-B55D-E8D5190EC3D0, Outgoing Dial-peer=25
Jul 31 07:47:47.043: //5265/35A79B1DB55D/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-username=
cisco-ani=729
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=90552488628
AVEVA_CME# cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
Jul 31 07:47:47.043: //5265/35A79B1DB55D/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x2B2E0228, Interface Type=6, Destination=, Mode=0x0,
Call Params(Calling Number=729,(Calling Name=Spare Desk 8)(TON=Unknown, NPI=Unknown, Screening=Not Screen
AVEVA_CME#ed, Presentation=Allowed),
Called Number=90552488628(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE, Outgoing Dial-peer=25, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Jul 31 07:47:47.043: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jul 31 07:47:47.043: :cc_get_feature_vsa malloc success
Jul 31 07:47:47.043: cc_get_feature_vsa count is 2
Jul 31 07:47:47.043: :FEATURE_VSA attributes are: feature_name:0,feature_time:805522104,feature_id:5378
Jul 31 07:47:47.043: //5266/35A79B1DB55D/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Jul 31 07:47:47.043: //5266/35A79B1DB55D/CCAPI/ccCallSetContext:
Context=0x301322F0
AVEVA_CME#CCAPI/ccSaveDialpeerTag:
Jul 31 07:47:50.059: //5266/35A79B1DB55D/CCAPI/cc_api_call_proceeding:
Interface=0x2B2E0228, Progress Indication=NULL(0)
Jul 31 07:47:50.179: //5266/35A79B1DB55D/CCAPI/cc_api_call_cut_progress:
Interface=0x2B2E0228, Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2),
Cause Value=0
Call Entry(Responsed=TRUE)
Jul 31 07:47:50.179: //5265/35A79B1DB55D/CCAPI/
AVEVA_CME#ccCallCutProgress:
Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2), Cause Value=0
Voice Call Send Alert=FALSE, Call Entry(Alert Sent=FALSE)
Jul 31 07:47:50.179: //5265/35A79B1DB55D/CCAPI/ccCallCutProgress:
Jul 31 07:47:50.179: //5265/35A79B1DB55D/CCAPI/ccGenerateToneInfo:
Stop Tone On Digit=FALSE, Tone=Null,
Jul 31 07:47:50.179: //5265/35A79B1DB55D/CCAPI/ccConferenceCreate:
(confID=0x2BF3431
AVEVA_CME#0, callID1=0x1491, gcid=35A79B1D-BA8011E0-B55DE8D5-190EC3D0, tag=0x0)
Jul 31 07:47:50.179: //5266/35A79B1DB55D/CCAPI/ccConferenceCreate:
(confID=0x2BF34310, callID2=0x1492, gcid=35A79B1D-BA8011E0-B55DE8D5-190EC3D0, tag=0x0)
Conference Id=0x2BF34310, Call Id1=5265, Call Id2=5266, Tag=0x0
Jul 31 07:47:50.183: //5265/35A79B1DB55D/CCAPI/cc_api_bridge_done:
Conference Id=0x1C3, Source Interface=0x31B8F960, Source Call Id=5265,
AVEVA_CME# Destination Call Id=5266, Disposition=0x0, Tag=0xFFFFFFFF
Jul 31 07:47:50.183: //5266/35A79B1DB55D/CCAPI/cc_api_bridge_done:
Conference Id=0x1C3, Source Interface=0x2B2E0228, Source Call Id=5266,
Destination Call Id=5265, Disposition=0x0, Tag=0xFFFFFFFF
Jul 31 07:47:50.183: //5265/35A79B1DB55D/CCAPI/cc_generic_bridge_done:
AVEVA_CME#55D/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x1C3, Destination Call Id=5266)
Jul 31 07:47:50.183: //5266/35A79B1DB55D/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x1C3, Destination Call Id=5265)
Jul 31 07:47:50.183: //5265/35A79B1DB55D/CCAPI/cc_api_caps_ind:
Destination Interface=0x2B2E0228, Destination Call Id=5266, Source Call Id=5265,
Caps(Codec=0x1, Fax Rate=0x2, Vad=0x1,
Modem=0x2, Codec Bytes=160, Signal Type=2)
AVEVA_CME#c_api_caps_ind:
Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Playout Max=1000(ms), Fax Nom=300(ms))
Jul 31 07:47:50.183: //5266/35A79B1DB55D/CCAPI/cc_api_caps_ind:
Destination Interface=0x31B8F960, Destination Call Id=5265, Source Call Id=5266,
Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
Jul 31 07:47:50.183: //5266/35A79B1DB55D/CCAPI/cc_api_caps_ack:
Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1),
Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=8590)
Jul 31 07:47:50.183: //5265/35A79B1DB55D/CCAPI/cc_api_caps_ack:
AVEVA_CME#x Rate=FAX_RATE_NONE(0x1), Vad=OFF(0x1),
Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=5912)
Jul 31 07:47:50.183: //5265/35A79B1DB55D/CCAPI/ccCallFeature:
Feature Type=25, Call Id=5265
Jul 31 07:47:50.183: //5265/35A79B1DB55D/CCAPI/cc_api_voice_mode_event:
Call Id=5265
Call Entry(Context=0x32DA02B8)
Jul 31 07:47:50.183: //5266/35A79B1DB55D/CCAPI/cc_api_voice_mode_event:
Call Id=5266
Jul 31 07:47:
AVEVA_CME#50.183: //5266/35A79B1DB55D/CCAPI/cc_api_voice_mode_event:
Call Entry(Context=0x301322F0)
Jul 31 07:47:50.183: //5265/35A79B1DB55D/CCAPI/cc_process_notify_bridge_done:
Conference Id=0x1C3, Call Id1=5265, Call Id2=5266
Jul 31 07:47:56.735: //5265/35A79B1DB55D/CCAPI/cc_api_call_disconnected:
Cause Value=16, Interface=0x31B8F960, Call Id=5265
Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Jul 31 07:47:56.73
AVEVA_CME#5: //5265/35A79B1DB55D/CCAPI/ccConferenceDestroy:
Conference Id=0x1C3, Tag=0x0
Jul 31 07:47:56.735: //5265/35A79B1DB55D/CCAPI/cc_api_bridge_drop_done:
Destination Call Id=5266, Disposition=0x0, Tag=0x0
Jul 31 07:47:56.735: //5266/35A79B1DB55D/CCAPI/cc_api_bridge_drop_done:
Destination Call Id=5265, Disposition=0x0, Tag=0x0
Jul 31 07:47:56.735: ^Z
AVEVA_CME#//5265/35A79B1DB55D/CCAPI/cc_generic_bridge_done:
Jul 31 07:47:56.735: //5266/35A79B1DB55D/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Jul 31 07:47:56.735: //5266/35A79B1DB55D/CCAPI/cc_api_get_transfer_info:
Transfer Number Is Null
Jul 31 07:47:56.735: //5265/35A79B1DB55D/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Jul 31 07:47:56.735: //5265/35A79B1DB55D/CCAPI/cc_api_get_transfer_info:
Jul 31 07:47:56.735: //5265/35A79B1DB55D/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x31B8F960, Tag=0x0, Call Id=5265,
Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Call Disconnect Event Sent
Jul 31 07:47:56.735: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jul 31 07:47:56.735: :cc_free_feature_vsa freeing 30034C70
Jul 31 07:47:56.735: vsacount in free is 1
Jul 31 07:47:56.763: //5266/35A79B1DB55D/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x2B2E0228, Tag=0x0, Call Id=5266,
Jul 31 07:47:56.763: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jul 31 07:47:56.763: :cc_free_feature_vsa freeing 30034AB0
Jul 31 07:47:56.763: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feat^Z
AVEVA_CME#
AVEVA_CME#ure_vsa:
Jul 31 07:47:56.763: vsacount in free is 0
Jul 31 07:47:57.423: //-1/3DA9C796B562/CCAPI/cc_api_display_ie_subfields:
cisco-username=
cisco-ani=729
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
cisco-redirectreas
AVEVA_CME#on=0 fwd_final_type =0
Jul 31 07:47:57.423: //-1/3DA9C796B562/CCAPI/cc_api_call_setup_ind_common:
AVEVA_CME#
AVEVA_CME#
AVEVA_CME#
AVEVA_CME#
AVEVA_CME#
AVEVA_CME# NON ISDN(3), Calling IE Present=TRUE,
Jul 31 07:47:57.423: //-1/3DA9C796B562/CCAPI/ccCheckClipClir:
Jul 31 07:47:57.423: //-1/xxxxxxxxxxxx/CCAPI/cc_ge
AVEVA_CME#t_feature_vsa:
Jul 31 07:47:57.423: :cc_get_feature_vsa malloc success
Jul 31 07:47:57.423: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jul 31 07:47:57.423: cc_get_feature_vsa count is 1
Jul 31 07:47:57.423: :FEATURE_VSA attributes are: feature_name:0,feature_time:805522104,feature_id:5379
Jul 31 07:47:57.423: //5267/3DA9C796B562/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
AVEVA_CME#TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Jul 31 07:47:57.423: //5267/3DA9C796B562/CCAPI/cc_process_call_setup_ind:
Event=0x3133BE38
Jul 31 07:47:57.423: //5267/3DA9C796B562/CCAPI/ccCallSetContext:
Context=0x30130EE8
>>>>CCAPI handed cid 5267 with tag 20043 to app "_ManagedAppProcess_Default"
AVEVA_CME#allSetupAck:
Call Id=5267
Jul 31 07:47:57.423: //5267/3DA9C796B562/CCAPI/cc_api_set_transfer_info:
Jul 31 07:47:57.423: //5267/3DA9C796B562/CCAPI/ccGenerateToneInfo:
Tone Direction=Network, Params=0x0, Call Id=5267
Jul 31 07:47:57.423: //5267/3DA9C796B562/CCAPI/ccSetDigitTimeouts:
AVEVA_CME#ts:
Jul 31 07:47:57.423: //5267/3DA9C796B562/CCAPI/ccCallReportDigits:
(callID=0x1493, digit_event=0x1, enable=TRUE, consume=FALSE)
Enabled=TRUE, Call Id=5267
Jul 31 07:47:57.423: //5267/3DA9C796B562/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x31B8F960, callID=0x1493, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
Jul 31 07:47:57.423: //^Z
AVEVA_CME#5267/3DA9C796B562/CCAPI/cc_api_call_report_digits_done:
Enabled=TRUE, Disposition=0x0, Interface=0x31B8F960, Call Id=5267
Jul 31 07:47:58.551: //5267/3DA9C796B562/CCAPI/cc_api_call_disconnected:
Cause Value=16, Interface=0x31B8F960, Call Id=5267
Call Entry(Responseddebug voip ccap inout
AVEVA_CME#
AVEVA_CME#=FALSE, Cause Value=16, Retry Count=0)
Jul 31 07:47:58.551: //5267/3DA9C796B562/CCAPI/ccCallDisconnect:
Jul 31 07:47:58.551: //5267/3DA9C796B562/CCAPI/cc_api_get_transfer_info:
Jul 31 07:47:58.551: //5267/3DA9C796B562/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x31B8F960, Tag=0x0, Call Id=5267,
Jul 31 07:47:58.551: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jul 31 07:47:58.551: :cc_free_feature_vsa freeing 30034AB0
Jul 31 07:47:58.551: vsacount in free is 0
Debug Voice Translation:
Jul 31 07:53:34.719: //-1/xxxxxxxxxxxx/RXRULE/regxrule_get_profile_from_trunkgroup_internal:
Voice port 0x31B8F960 dsl=-1 timeslot=0 does not belong to any trunk group
Jul 31 07:53:34.723: //-1/06B50F01B56A/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x2B5343EC; count=1
Jul 31 07:53:34.723: //-1/06B50F01B56A/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x2B3896E4
Jul 31 07:53:34.723: //-1/06B50F01B56A/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x2B5343EC; count=1
Jul 31 07:53:38.043: //-1/06B50F01B56A/RXRULE/regxrule_vp_translate: No profile found in voice port or trunk group for outgoing direction
Jul 31 07:53:38.043: //-1/06B50F01B56A/RXRULE/regxrule_vp_translate: calling_number=729 calling_octet=0x0
called_number=90552488628 called_octet=0x80
redirect_number= redirect_type=0 redirect_plan=0
Jul 31 07:53:48.379: //-1/06B50F01B56A/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x2B5343EC; count=1
Jul 31 07:53:48.379: //-1/06B50F01B56A/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x2B3896E4
Jul 31 07:53:48.403: //-1/06B50F01B56A/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x0
Hi Syed,
As I said in my earlier e-mail, you have NOT applied any translations in outgoing direction when dialing from Internal to PSTN. You have only translations for incoming calls from PSTN to internal.
It's evident in your debug for translations as well.
Regards..
-Ashok.
Dear Concern,
I have created 1 more rule
rule 1 // /044540/
translate calling 3
voice-port 0/0/0:15
Now its working fine Thanks alot for your concern in this matter
Hi Syed,
Glad to know that your problem resolved.
Regards...
-Ashok.
Pls rate if it helps...
