12-27-2016 06:12 PM - edited 03-17-2019 09:02 AM
Hi All
Could some one please tell me if we can configure some permanent meeting numbers (conference bridges) in CUCM, lets say for weekly meetings ?
Please find below the example for your reference :
Join the meeting by dialing in from your phone
45xxx ( Internal Only)
(123) 456-5xxx (External Dial in)
1 (855) 456-5xxx (Toll Free Dial in)
Access Code:
882 643 279
Solved! Go to Solution.
12-27-2016 07:10 PM
Hi Rohit,
You might want to check the Conference now feature in CUCM 11.5
The Conference Now feature allows both external and internal callers to join a conference by dialing a Conference Now IVR Directory Number, which is a centralized conference assistant number. An IVR application guides the caller to join the conference by playing announcements.
A conference is established using a Meeting Number, which is the same as the Self-Service User ID. The meeting number is configured by the administrator in the end user's window. The Self-Service User ID is usually same as the user's primary extension number.
The host (End User) provides the Meeting Number, Time slot, and Attendees Access Code to all the participants. The host requires a PIN to join the conference, but the participants do not require it. If a participant dials into the meeting before the host, the participant hears Music on Hold (MOH).
After the host enters both Meeting Number and PIN correctly, a conference bridge is allocated based on the MRGL (Media Resource Group List) of the host. Participants who join before the start of the meeting are redirected to the same conference bridge.
The host can set the Attendees Access Code for a secure conference call. For more information, see topics related to Set the Access Code for Conference Now in the Cisco Unified Communications Self Care Portal Guide.
Configuration of Conference now
Please rate and mark if helpful
Adarsh Chauhan
12-27-2016 07:26 PM
No. Conference now was introduced in 11.X so you cannot use it in 10.5
Adarsh Chauhan
12-27-2016 07:10 PM
Hi Rohit,
Adarsh Chauhan
12-27-2016 07:23 PM
Hi Adarsh
Thanks a lot for your reply and helping me out.
But could you please tell me if we xcan configure the same in 10.5 version of CUCM ?
Rohit
12-27-2016 07:26 PM
Adarsh Chauhan
12-27-2016 07:45 PM
ok...Thanks for your help.
12-27-2016 08:50 PM
Do you have CMS in your deployment?
12-27-2016 09:52 PM
Hi Jaime
We have webEx server in our cluster.
