Persistent Chat
arashad
hi all ,
I installed win server 2012 r2 and sql 2014 and made two databases for chat and compliance , in imp 11.5 configuration the external database for compliance had no problems but in chat i get this message
"The following connections between the IM and Presence Service node and the external database server failed:"
7 Replies 7
M02@rt37
do you try this:
Restart the Cisco XCP router service and start the Cisco unified persence Message
archiver. I explain depeer:
Restart the Cisco XCP Router on all nodes in the cluster by choosing Cisco Unified IM and
Presence Serviceability > Tools > Control Center - Network Services. Note the following:
If the Cisco XCP Text Conference Manager service was already running, it will automatically
restart when you restart the Cisco XCP Router.
If the Cisco XCP Text Conference Manager service was not already running, you must start it
after the Cisco XCP Router has restarted. To start the Cisco XCP Text Conference Manager
service, choose Cisco Unified IM and Presence Serviceability > Tools > Control Center - Feature
Services.
And check this about External database connection:
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/im_presence/database_setup/10_5_2/CUP0_BK_D4BFFAC9_00_database-setup-guide-imp-1052/CUP0_BK_D4BFFAC9_00_database-setup-guide-imp-1052_chapter_011.pdf
Last question, are you in IPv6?
If the IM and Presence Service connects to an external database server using IPv6, ensure that the enterprise parameter is configured for IPv6 and that Eth0 is set for IPv6 on each node in the deployment; otherwise, the connection to the external database server fails. The message archiver and Cisco XCP Text Conference Manager will be unable to connect to the external database and will fail. For information about configuring IPv6 on the IM and Presence Service, see Configuration and Administration of IM and Presence Service on Cisco Unified Communications Manager :
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/im_presence/configAdminGuide/11_5_1/CUP0_BK_CE08159C_00_config-admin-guide-imp-1151.html
Best Regards,
If this helps, please rate.
Ben
Best regards
R0g22
Go to IM Admin web >> Messaging >> External sever setup >> External Database. Choose the database to view the entries and see if it tells you anything.
If not helpful, go to Diagnostics and run the troubleshooter.
its working but i get error in database schema !!!!
M02@rt37
do you try this:
Services.
Best Regards,
Ben
Best regards
M02@rt37
do you try this:
Services.
Best Regards,
Ben
Best regards
i get this error now "The following external database server's database schema verification failed:"
for the schema failed issue you need to unassign the external database from the node, and reassign it again.
Verify following logfiles on your presence node which you connect to the DB server:
file list activelog /epas/trace/xcp/log/*txt-conf-1* det dat
which are the logs from  XCP Text Conference Manager
Example of a non-sucessful SQL connection:
admin:file tail activelog /epas/trace/xcp/log/txt-conf-1_00000014.log.gz
13:54:17.934 |f76cfb70| error| ODBCConnection.cpp:1765
13:54:17.935 |f76cfb70| error| ODBCConnection.cpp:1790 (SQLError -1, 101; SQLState 08001) Could not connect to the server;
No route to host [n.n.n.n:5432]
13:54:17.935 |f76cfb70| error| ODBCConnection.cpp:211 failed to connect dsn:6b2f1c81-8564-419d-bfa8-90dad393e719 username:tcuser type:2
13:54:17.935 |f76cfb70| info| ODBCConnection.cpp:237 disconnect dsn:6b2f1c81-8564-419d-bfa8-90dad393e719 username:tcuser type:2
13:54:17.936 |f76cfb70| error| ConnectionPool.cpp:179 connection pool checkout: 6b2f1c81-8564-419d-bfa8-90dad393e719/tcuser (failure)
13:54:17.936 |f76cfb70| error| PersistentGearFactory Unable to initialize connection to the database server.
13:54:17.936 |f76cfb70| error| ODBCConnection.cpp:245 already disconnected dsn:6b2f1c81-8564-419d-bfa8-90dad393e719 username:tcuser type:2
13:54:17.937 |f76cfb70| error| TC Configuration One of the gears told us to stop. Application exiting.
13:54:17.937 |f76cfb70| info| bedrock Application exit requested (-1): gear load failed.
As you can see in the logs the service stopped.
Typical root causes are e.g. simply local firewall on server or you DB is not running or listening on another port.
Recent documentation can be found there:
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/im_presence/database_setup/11_5_1/cup0_b_database-setup-guide-imp-115/cup0_b_database-setup-guide-imp-115_chapter_011.html
BR,
Christoph
