06-20-2008 06:37 AM - edited 03-15-2019 11:25 AM
Is it possible to display the name of a caller which is stored in the PAB on the phone display? We can see only the caller-id of the incoming call, not the stored name in the PAB entry.
Marcus
Solved! Go to Solution.
06-20-2008 10:46 AM
sorry, CUCM does not have that capability
javalenc
if this helps, please rate
06-20-2008 10:46 AM
javalenc
