Personal Directory missing from Ip Phones running on CME 7.1
Hi to all
i have installed a CME 7.1.3 and i have the following problem
On the (ip phones_all the ip phones(using now 7941,7961GE) in directories buttom its show only Missed calls, Recieved calls, Placed calls.The other services are missing
Do you have any idea?
Below is the config
tftp-server flash:/7941_61/apps41.8-5-4TH1-6.sbn alias apps41.8-5-4TH1-6.sbn
tftp-server flash:/7941_61/cnu41.8-5-4TH1-6.sbn alias cnu41.8-5-4TH1-6.sbn
tftp-server flash:/7941_61/cvm41sccp.8-5-4TH1-6.sbn alias cvm41sccp.8-5-4TH1-6.sbn
tftp-server flash:/7941_61/dsp41.8-5-4TH1-6.sbn alias dsp41.8-5-4TH1-6.sbn
tftp-server flash:/7941_61/jar41sccp.8-5-4TH1-6.sbn alias jar41sccp.8-5-4TH1-6.sbn
tftp-server flash:/7941_61/SCCP41.8-5-4S.loads alias SCCP41.8-5-4S.loads
tftp-server flash:/7941_61/term41.default.loads alias default.loads
tftp-server flash:/7941_61/term61.default.loads alias term61.default.loads
tftp-server flash:/7941_61/apps41.8-4-1-23.sbn alias apps41.8-4-1-23.sbn
tftp-server flash:/7941_61/cnu41.8-4-1-23.sbn alias cnu41.8-4-1-23.sbn
tftp-server flash:/7941_61/cvm41sccp.8-4-1-23.sbn alias cvm41sccp.8-4-1-23.sbn
tftp-server flash:/7941_61/dsp41.8-4-1-23.sbn alias dsp41.8-4-1-23.sbn
tftp-server flash:/7941_61/jar41sccp.8-4-1-23.sbn alias jar41sccp.8-4-1-23.sbn
tftp-server flash:/7941_61/SCCP41.8-4-2S.loads alias SCCP41.8-4-2S.loads
tftp-server flash:/7941_61/term41.default.loads alias term41.default.loads
CME: 192.168.10.1
telephony-service
ip source-address 192.168.10.1 port 2000
url directories http://192.168.10.1/localdirectory
load 7941 SCCP41.8-5-4S
load 7961GE SCCP41.8-5-4S
(((i used also and the other firmware SCCP41.8-4-2S with out any success))
IN THE ATTACHED YOU WIIL FIND A TFTP  DEBUG
EV_UC#show  version
Cisco IOS Software, UC500 Software (UC500-ADVIPSERVICESK9-M), Version 12.4(24)SB, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Wed 26-Aug-09 19:01 by prod_rel_team
ROM: System Bootstrap, Version 12.4(24r)SB, RELEASE SOFTWARE (fc1)
EV_UC uptime is 2 days, 1 hour, 41 minutes
System returned to ROM by reload at 13:56:55 EDT Tue Jun 22 2010
System restarted at 13:57:36 EDT Tue Jun 22 2010
System image file is "flash:uc500-advipservicesk9-mz.124-24.SB"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco UC540W-BRI-K9 (MPC8358) processor (revision 0x100) with 249856K/12288K bytes of memory.
Processor board ID FHK141470ZX
MPC8358 CPU Rev: Part Number 0x804A, Revision ID 0x20
22 User Licenses
10 FastEthernet interfaces
2 ISDN Basic Rate interfaces
2 terminal lines
4 Voice FXS interfaces
1 Voice MoH interface
1 802.11 Radio
1 cisco service engine(s)
128K bytes of non-volatile configuration memory.
254464K bytes of ATA CompactFlash (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        UC540W-BRI-K9         FHK141470ZX
Looking forward for your earlier reply
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
Do you have the " type XXXX" where XXXX=phone model in your ephone configuration?
14 Replies 14
rchaseling
Level 4
Level 4
I've run into this before......make sure you have these 2 commands
ip http server
ip http path flash:
also make sure you put in command "type 7941 or type 7961" under each ephone then these 3 commands
telephony service
no create cnf-files
create cnf-files
Russell
Hi Russell
Thank you for the reply
i have the below without any success
ip http server
ip http authentication local
ip http path flash:/gui
i did also several times the below with out also any success
no create cnf-files
create cnf-files
Its very strange
do you any other idea?
Regards and thank you for the help
Aslo
EV_UC#show  flash:
-#- --length-- -----date/time------ path
1     30088700 Mar 29 2010 12:38:50 +03:00 uc500-advipservicesk9-mz.124-24.SB
2            0 Mar 29 2010 12:49:36 +03:00 phones
3            0 Mar 29 2010 12:44:22 +03:00 phones/7975
4      2918613 Mar 29 2010 12:44:06 +03:00 phones/7975/apps75.8-4-1-23.sbn
5       485244 Mar 29 2010 12:44:08 +03:00 phones/7975/cnu75.8-4-1-23.sbn
6      2661855 Mar 29 2010 12:44:18 +03:00 phones/7975/cvm75sccp.8-4-1-23.sbn
7       335003 Mar 29 2010 12:44:20 +03:00 phones/7975/dsp75.8-4-1-23.sbn
8       757132 Mar 29 2010 12:44:22 +03:00 phones/7975/jar75sccp.8-4-1-23.sbn
9          638 Mar 29 2010 12:44:22 +03:00 phones/7975/SCCP75.8-4-2S.loads
10         642 Mar 29 2010 12:44:22 +03:00 phones/7975/term75.default.loads
11           0 Mar 29 2010 12:44:50 +03:00 phones/7970_7971
12     2915997 Mar 29 2010 12:44:34 +03:00 phones/7970_7971/apps70.8-4-1-23.sbn
13      460275 Mar 29 2010 12:44:36 +03:00 phones/7970_7971/cnu70.8-4-1-23.sbn
14     2665016 Mar 29 2010 12:44:44 +03:00 phones/7970_7971/cvm70sccp.8-4-1-23.sbn
15      539441 Mar 29 2010 12:44:46 +03:00 phones/7970_7971/dsp70.8-4-1-23.sbn
16      700829 Mar 29 2010 12:44:50 +03:00 phones/7970_7971/jar70sccp.8-4-1-23.sbn
17         638 Mar 29 2010 12:44:50 +03:00 phones/7970_7971/SCCP70.8-4-2S.loads
18         642 Mar 29 2010 12:44:50 +03:00 phones/7970_7971/term70.default.loads
19         642 Mar 29 2010 12:44:50 +03:00 phones/7970_7971/term71.default.loads
20           0 Mar 29 2010 12:45:16 +03:00 phones/7945_7965
21     2918613 Mar 29 2010 12:45:00 +03:00 phones/7945_7965/apps45.8-4-1-23.sbn
22      485266 Mar 29 2010 12:45:02 +03:00 phones/7945_7965/cnu45.8-4-1-23.sbn
23     2662633 Mar 29 2010 12:45:10 +03:00 phones/7945_7965/cvm45sccp.8-4-1-23.sbn
24      335003 Mar 29 2010 12:45:12 +03:00 phones/7945_7965/dsp45.8-4-1-23.sbn
25      754716 Mar 29 2010 12:45:14 +03:00 phones/7945_7965/jar45sccp.8-4-1-23.sbn
26         638 Mar 29 2010 12:45:14 +03:00 phones/7945_7965/SCCP45.8-4-2S.loads
27         642 Mar 29 2010 12:45:16 +03:00 phones/7945_7965/term45.default.loads
28         642 Mar 29 2010 12:45:16 +03:00 phones/7945_7965/term65.default.loads
29           0 Mar 29 2010 12:45:40 +03:00 phones/7942_7962
30     2918613 Mar 29 2010 12:45:24 +03:00 phones/7942_7962/apps42.8-4-1-23.sbn
31      485066 Mar 29 2010 12:45:26 +03:00 phones/7942_7962/cnu42.8-4-1-23.sbn
32     2659498 Mar 29 2010 12:45:36 +03:00 phones/7942_7962/cvm42sccp.8-4-1-23.sbn
33      335003 Mar 29 2010 12:45:36 +03:00 phones/7942_7962/dsp42.8-4-1-23.sbn
34      628112 Mar 29 2010 12:45:40 +03:00 phones/7942_7962/jar42sccp.8-4-1-23.sbn
35         658 Mar 29 2010 12:45:40 +03:00 phones/7942_7962/SCCP42.8-4-2S.loads
36         662 Mar 29 2010 12:45:40 +03:00 phones/7942_7962/term42.default.loads
37         662 Mar 29 2010 12:45:40 +03:00 phones/7942_7962/term62.default.loads
38           0 Mar 29 2010 12:46:06 +03:00 phones/7941_7961
39     2915997 Mar 29 2010 12:45:50 +03:00 phones/7941_7961/apps41.8-4-1-23.sbn
40      459836 Mar 29 2010 12:45:52 +03:00 phones/7941_7961/cnu41.8-4-1-23.sbn
41     2660448 Mar 29 2010 12:46:02 +03:00 phones/7941_7961/cvm41sccp.8-4-1-23.sbn
42      539441 Mar 29 2010 12:46:04 +03:00 phones/7941_7961/dsp41.8-4-1-23.sbn
43      500440 Mar 29 2010 12:46:06 +03:00 phones/7941_7961/jar41sccp.8-4-1-23.sbn
44         638 Mar 29 2010 12:46:06 +03:00 phones/7941_7961/SCCP41.8-4-2S.loads
45         642 Mar 29 2010 12:46:06 +03:00 phones/7941_7961/term41.default.loads
46         642 Mar 29 2010 12:46:06 +03:00 phones/7941_7961/term61.default.loads
47           0 Mar 29 2010 12:46:10 +03:00 phones/7940_7960
48      130548 Mar 29 2010 12:46:08 +03:00 phones/7940_7960/P00308001000.bin
49         458 Mar 29 2010 12:46:08 +03:00 phones/7940_7960/P00308001000.loads
50      707328 Mar 29 2010 12:46:10 +03:00 phones/7940_7960/P00308001000.sb2
51      130952 Mar 29 2010 12:46:12 +03:00 phones/7940_7960/P00308001000.sbn
52           0 Mar 29 2010 12:46:12 +03:00 phones/7937
53     7922596 Mar 29 2010 12:46:38 +03:00 phones/7937/apps37sccp.1-3-2-0.bin
54           0 Mar 29 2010 12:46:38 +03:00 phones/7936
55     1849756 Mar 29 2010 12:46:44 +03:00 phones/7936/cmterm_7936.3-3-16-0.bin
56           0 Mar 29 2010 12:47:10 +03:00 phones/7931
57     2925555 Mar 29 2010 12:46:54 +03:00 phones/7931/apps31.8-4-1-23.sbn
58      464028 Mar 29 2010 12:46:56 +03:00 phones/7931/cnu31.8-4-1-23.sbn
59     2661176 Mar 29 2010 12:47:06 +03:00 phones/7931/cvm31sccp.8-4-1-23.sbn
60      335003 Mar 29 2010 12:47:06 +03:00 phones/7931/dsp31.8-4-1-23.sbn
61      485636 Mar 29 2010 12:47:08 +03:00 phones/7931/jar31sccp.8-4-1-23.sbn
62         639 Mar 29 2010 12:47:10 +03:00 phones/7931/SCCP31.8-4-2S.loads
63         643 Mar 29 2010 12:47:10 +03:00 phones/7931/term31.default.loads
64           0 Mar 29 2010 12:47:40 +03:00 phones/7925
65     2628733 Mar 29 2010 12:47:20 +03:00 phones/7925/APPSH-1.3.1.SBN
66         819 Mar 29 2010 12:47:20 +03:00 phones/7925/CP7925G-1.3.1.LOADS
67     1883285 Mar 29 2010 12:47:28 +03:00 phones/7925/GUIH-1.3.1.SBN
68     2118665 Mar 29 2010 12:47:36 +03:00 phones/7925/SYSH-1.3.1.SBN
69      936361 Mar 29 2010 12:47:40 +03:00 phones/7925/TNUXH-1.3.1.SBN
70     1963130 Mar 29 2010 12:47:46 +03:00 phones/7925/WLANH-1.3.1.SBN
71           0 Mar 29 2010 12:48:20 +03:00 phones/7921
72     2593969 Mar 29 2010 12:47:56 +03:00 phones/7921/APPS-1.2.1.SBN
73         894 Mar 29 2010 12:47:56 +03:00 phones/7921/CP7921G-1.2.1.LOADS
74     1833102 Mar 29 2010 12:48:02 +03:00 phones/7921/GUI-1.2.1.SBN
75     2083047 Mar 29 2010 12:48:08 +03:00 phones/7921/SYS-1.2.1.SBN
76      895905 Mar 29 2010 12:48:12 +03:00 phones/7921/TNUX-1.2.1.SBN
77     2196478 Mar 29 2010 12:48:20 +03:00 phones/7921/TNUXR-1.2.1.SBN
78     1350650 Mar 29 2010 12:48:24 +03:00 phones/7921/WLAN-1.2.1.SBN
79           0 Mar 29 2010 12:48:24 +03:00 phones/7916
80      165355 Mar 29 2010 12:48:26 +03:00 phones/7916/B016-1-0-3.SBN
81           0 Mar 29 2010 12:48:26 +03:00 phones/7915
82      146463 Mar 29 2010 12:48:26 +03:00 phones/7915/B015-1-0-3.SBN
83           0 Mar 29 2010 12:48:26 +03:00 phones/7914
84       49986 Mar 29 2010 12:48:26 +03:00 phones/7914/S00105000300.sbn
85           0 Mar 29 2010 12:48:50 +03:00 phones/7906_7911
86     2925555 Mar 29 2010 12:48:36 +03:00 phones/7906_7911/apps11.8-4-1-23.sbn
87      463556 Mar 29 2010 12:48:38 +03:00 phones/7906_7911/cnu11.8-4-1-23.sbn
88     2666103 Mar 29 2010 12:48:46 +03:00 phones/7906_7911/cvm11sccp.8-4-1-23.sbn
89      335003 Mar 29 2010 12:48:48 +03:00 phones/7906_7911/dsp11.8-4-1-23.sbn
90      485341 Mar 29 2010 12:48:50 +03:00 phones/7906_7911/jar11sccp.8-4-1-23.sbn
91         658 Mar 29 2010 12:48:50 +03:00 phones/7906_7911/SCCP11.8-4-2S.loads
92         662 Mar 29 2010 12:48:50 +03:00 phones/7906_7911/term06.default.loads
93         662 Mar 29 2010 12:48:52 +03:00 phones/7906_7911/term11.default.loads
94           0 Mar 29 2010 12:48:52 +03:00 phones/5x5
95     3339810 Mar 29 2010 12:49:02 +03:00 phones/5x5/spa5x5-7-1-3c.bin
96           0 Mar 29 2010 12:49:02 +03:00 phones/525
97     9803264 Mar 29 2010 12:49:34 +03:00 phones/525/spa525g-7-1-9.bin
98           0 Mar 29 2010 12:49:36 +03:00 phones/521_524
99      892511 Mar 29 2010 12:49:38 +03:00 phones/521_524/cp524g-8-1-17.bin
100          0 Mar 29 2010 12:49:52 +03:00 Desktops
101     131470 Mar 29 2010 12:49:46 +03:00 Desktops/CampusNight.png
102      80565 Mar 29 2010 12:49:46 +03:00 Desktops/CiscoFountain.png
103       8156 Mar 29 2010 12:49:46 +03:00 Desktops/CiscoLogo.png
104     138278 Mar 29 2010 12:49:48 +03:00 Desktops/Fountain.png
105     109076 Mar 29 2010 12:49:48 +03:00 Desktops/MorroRock.png
106     108087 Mar 29 2010 12:49:48 +03:00 Desktops/NantucketFlowers.png
107      10820 Mar 29 2010 12:49:50 +03:00 Desktops/TN-CampusNight.png
108       9657 Mar 29 2010 12:49:50 +03:00 Desktops/TN-CiscoFountain.png
109       2089 Mar 29 2010 12:49:50 +03:00 Desktops/TN-CiscoLogo.png
110       7953 Mar 29 2010 12:49:50 +03:00 Desktops/TN-Fountain.png
111       7274 Mar 29 2010 12:49:50 +03:00 Desktops/TN-MorroRock.png
112       9933 Mar 29 2010 12:49:50 +03:00 Desktops/TN-NantucketFlowers.png
113          0 Mar 29 2010 12:49:50 +03:00 Desktops/320x216x16
114        651 Mar 29 2010 12:49:50 +03:00 Desktops/320x216x16/List.xml
115          0 Mar 29 2010 12:49:50 +03:00 Desktops/320x212x16
116        651 Mar 29 2010 12:49:52 +03:00 Desktops/320x212x16/List.xml
117          0 Mar 29 2010 12:49:52 +03:00 Desktops/320x212x12
118        651 Mar 29 2010 12:49:52 +03:00 Desktops/320x212x12/List.xml
119          0 Mar 29 2010 12:49:52 +03:00 autoattendant
120      94503 Mar 29 2010 12:49:52 +03:00 autoattendant/AA_SBCS_v01.aef
121      96166 Mar 29 2010 12:49:52 +03:00 autoattendant/AA_SBCS_v02.aef
122      15891 Mar 29 2010 12:49:52 +03:00 autoattendant/AA_transfer.aef
123          0 Mar 29 2010 12:49:58 +03:00 bacdprompts
124      30421 Mar 29 2010 12:49:54 +03:00 bacdprompts/app-b-acd-3.0.0.2.tcl
125      55599 Mar 29 2010 12:49:54 +03:00 bacdprompts/app-b-acd-aa-3.0.0.2.tcl
126      75650 Mar 29 2010 12:49:54 +03:00 bacdprompts/en_bacd_allagentsbusy.au
127      83291 Mar 29 2010 12:49:54 +03:00 bacdprompts/en_bacd_disconnect.au
128      63055 Mar 29 2010 12:49:56 +03:00 bacdprompts/en_bacd_enter_dest.au
129      37952 Mar 29 2010 12:49:56 +03:00 bacdprompts/en_bacd_invalidoption.au
130     496521 Mar 29 2010 12:49:58 +03:00 bacdprompts/en_bacd_music_on_hold.au
131     123446 Mar 29 2010 12:49:58 +03:00 bacdprompts/en_bacd_options_menu.au
132      42978 Mar 29 2010 12:49:58 +03:00 bacdprompts/en_bacd_welcome.au
133      34794 Mar 29 2010 12:49:58 +03:00 bacdprompts/en_bacd_xferto_operator.au
134          0 Mar 29 2010 12:50:00 +03:00 cca
135        658 Mar 29 2010 12:50:00 +03:00 cca/Key_Phoneloads.csv
136      78001 Mar 29 2010 12:50:00 +03:00 cca/sccpphoneloadstable.csv
137        385 Mar 29 2010 12:50:00 +03:00 cca/UC500_CCA_Dir_7.1.3.txt
138          0 Mar 29 2010 12:50:06 +03:00 gui
139       4118 Mar 29 2010 12:50:00 +03:00 gui/admin_user.html
140     664796 Mar 29 2010 12:50:02 +03:00 gui/admin_user.js
141       1029 Mar 29 2010 12:50:02 +03:00 gui/CiscoLogo.gif
142        657 Mar 29 2010 12:50:04 +03:00 gui/CME_GUI_README.TXT
143        953 Mar 29 2010 12:50:04 +03:00 gui/Delete.gif
144      16948 Mar 29 2010 12:50:04 +03:00 gui/dom.js
145        864 Mar 29 2010 12:50:04 +03:00 gui/downarrow.gif
146       6315 Mar 29 2010 12:50:04 +03:00 gui/ephone_admin.html
147       4558 Mar 29 2010 12:50:04 +03:00 gui/logohome.gif
148       3978 Mar 29 2010 12:50:04 +03:00 gui/normal_user.html
149      80123 Mar 29 2010 12:50:04 +03:00 gui/normal_user.js
150       1347 Mar 29 2010 12:50:06 +03:00 gui/Plus.gif
151        843 Mar 29 2010 12:50:06 +03:00 gui/sxiconad.gif
152        174 Mar 29 2010 12:50:06 +03:00 gui/Tab.gif
153       2492 Mar 29 2010 12:50:06 +03:00 gui/telephony_service.html
154        870 Mar 29 2010 12:50:06 +03:00 gui/uparrow.gif
155      10230 Mar 29 2010 12:50:06 +03:00 gui/xml-test.html
156       3493 Mar 29 2010 12:50:06 +03:00 gui/xml.template
157          0 Mar 29 2010 12:50:06 +03:00 gui/sn
158      11899 Mar 29 2010 12:50:06 +03:00 gui/sn/handshake.html
159     633459 Mar 29 2010 12:50:10 +03:00 gui/sn/handshake.swf
160          0 Mar 29 2010 12:50:12 +03:00 media
161     496521 Mar 29 2010 12:50:12 +03:00 media/music-on-hold.au
162     496521 Mar 29 2010 12:50:14 +03:00 media/music-on-hold_10db.au
163          0 Mar 29 2010 12:50:22 +03:00 ringtones
164       8160 Mar 29 2010 12:50:14 +03:00 ringtones/Analog1.raw
165       8160 Mar 29 2010 12:50:14 +03:00 ringtones/Analog2.raw
166       5280 Mar 29 2010 12:50:14 +03:00 ringtones/AreYouThere.raw
167       5040 Mar 29 2010 12:50:14 +03:00 ringtones/AreYouThereF.raw
168       8160 Mar 29 2010 12:50:14 +03:00 ringtones/Bass.raw
169      12240 Mar 29 2010 12:50:16 +03:00 ringtones/CallBack.raw
170      16040 Mar 29 2010 12:50:16 +03:00 ringtones/Chime.raw
171       8160 Mar 29 2010 12:50:16 +03:00 ringtones/Classic1.raw
172      16080 Mar 29 2010 12:50:16 +03:00 ringtones/Classic2.raw
173      10800 Mar 29 2010 12:50:16 +03:00 ringtones/ClockShop.raw
174       2823 Mar 29 2010 12:50:16 +03:00 ringtones/DistinctiveRingList.xml
175       9600 Mar 29 2010 12:50:16 +03:00 ringtones/Drums1.raw
176      13440 Mar 29 2010 12:50:18 +03:00 ringtones/Drums2.raw
177      15840 Mar 29 2010 12:50:18 +03:00 ringtones/FilmScore.raw
178      16080 Mar 29 2010 12:50:18 +03:00 ringtones/HarpSynth.raw
179       8160 Mar 29 2010 12:50:18 +03:00 ringtones/Jamaica.raw
180      16080 Mar 29 2010 12:50:18 +03:00 ringtones/KotoEffect.raw
181      12720 Mar 29 2010 12:50:18 +03:00 ringtones/MusicBox.raw
182       8160 Mar 29 2010 12:50:18 +03:00 ringtones/Piano1.raw
183      15360 Mar 29 2010 12:50:20 +03:00 ringtones/Piano2.raw
184       9360 Mar 29 2010 12:50:20 +03:00 ringtones/Pop.raw
185       7200 Mar 29 2010 12:50:20 +03:00 ringtones/Pulse1.raw
186       4000 Mar 29 2010 12:50:20 +03:00 ringtones/Ring1.raw
187       4000 Mar 29 2010 12:50:20 +03:00 ringtones/Ring2.raw
188       4000 Mar 29 2010 12:50:20 +03:00 ringtones/Ring3.raw
189       4000 Mar 29 2010 12:50:20 +03:00 ringtones/Ring4.raw
190       4000 Mar 29 2010 12:50:20 +03:00 ringtones/Ring5.raw
191       4000 Mar 29 2010 12:50:22 +03:00 ringtones/Ring6.raw
192       4000 Mar 29 2010 12:50:22 +03:00 ringtones/Ring7.raw
193       2823 Mar 29 2010 12:50:22 +03:00 ringtones/RingList.xml
194      10800 Mar 29 2010 12:50:22 +03:00 ringtones/Sax1.raw
195      14160 Mar 29 2010 12:50:22 +03:00 ringtones/Sax2.raw
196      16080 Mar 29 2010 12:50:22 +03:00 ringtones/Vibe.raw
197          0 Mar 29 2010 12:50:22 +03:00 sn
198          0 Mar 29 2010 12:50:22 +03:00 sn/tmp
199          0 Mar 29 2010 12:50:22 +03:00 sn/status
200        660 May 26 2010 11:44:10 +03:00 vlan.dat
201      24489 Mar 29 2010 12:50:28 +03:00 UC540W-BRI-K9-factory-7.1.3.cfg
202       1162 May 25 2010 16:30:14 +03:00 FHK141470ZX_20100525062025036.lic
203          0 May 26 2010 17:06:22 +03:00 7941_61
204    2933341 May 26 2010 17:07:18 +03:00 7941_61/apps41.8-5-4TH1-6.sbn
205     499863 May 26 2010 17:08:22 +03:00 7941_61/cnu41.8-5-4TH1-6.sbn
206    2102770 May 26 2010 17:09:10 +03:00 7941_61/cvm41sccp.8-5-4TH1-6.sbn
207     539513 May 26 2010 17:09:32 +03:00 7941_61/dsp41.8-5-4TH1-6.sbn
208    1628021 May 26 2010 17:11:06 +03:00 7941_61/jar41sccp.8-5-4TH1-6.sbn
209        650 May 26 2010 17:12:56 +03:00 7941_61/SCCP41.8-5-4S.loads
210        654 May 26 2010 17:13:08 +03:00 7941_61/term41.default.loads
211        654 May 26 2010 17:13:24 +03:00 7941_61/term61.default.loads
Can you post your show run up here?
hi
here are the necessary infos for this problem
EU#show run
ip http server
ip http secure-server
tftp-server flash:/ringtones/Analog1.raw alias Analog1.raw
tftp-server flash:/ringtones/Analog2.raw alias Analog2.raw
tftp-server flash:/ringtones/AreYouThere.raw alias AreYouThere.raw
tftp-server flash:/ringtones/DistinctiveRingList.xml alias DistinctiveRingList.xml
tftp-server flash:/ringtones/RingList.xml alias RingList.xml
tftp-server flash:/ringtones/AreYouThereF.raw alias AreYouThereF.raw
tftp-server flash:/ringtones/Bass.raw alias Bass.raw
tftp-server flash:/ringtones/CallBack.raw alias CallBack.raw
tftp-server flash:/ringtones/Chime.raw alias Chime.raw
tftp-server flash:/ringtones/Classic1.raw alias Classic1.raw
tftp-server flash:/ringtones/Classic2.raw alias Classic2.raw
tftp-server flash:/ringtones/ClockShop.raw alias ClockShop.raw
tftp-server flash:/ringtones/Drums1.raw alias Drums1.raw
tftp-server flash:/ringtones/Drums2.raw alias Drums2.raw
tftp-server flash:/ringtones/FilmScore.raw alias FilmScore.raw
tftp-server flash:/ringtones/HarpSynth.raw alias HarpSynth.raw
tftp-server flash:/ringtones/Jamaica.raw alias Jamaica.raw
tftp-server flash:/ringtones/KotoEffect.raw alias KotoEffect.raw
tftp-server flash:/ringtones/MusicBox.raw alias MusicBox.raw
tftp-server flash:/ringtones/Piano1.raw alias Piano1.raw
tftp-server flash:/ringtones/Piano2.raw alias Piano2.raw
tftp-server flash:/ringtones/Pop.raw alias Pop.raw
tftp-server flash:/ringtones/Pulse1.raw alias Pulse1.raw
tftp-server flash:/ringtones/Ring1.raw alias Ring1.raw
tftp-server flash:/ringtones/Ring2.raw alias Ring2.raw
tftp-server flash:/ringtones/Ring3.raw alias Ring3.raw
tftp-server flash:/ringtones/Ring4.raw alias Ring4.raw
tftp-server flash:/ringtones/Ring5.raw alias Ring5.raw
tftp-server flash:/ringtones/Ring6.raw alias Ring6.raw
tftp-server flash:/ringtones/Ring7.raw alias Ring7.raw
tftp-server flash:/ringtones/Sax1.raw alias Sax1.raw
tftp-server flash:/ringtones/Sax2.raw alias Sax2.raw
tftp-server flash:/ringtones/Vibe.raw alias Vibe.raw
tftp-server flash:/media/music-on-hold.au alias music-on-hold.au
!telephony-service
no auto-reg-ephone
authentication credential admin !!!!!
max-ephones 40
max-dn 100
ip source-address 10.1.1.1 port 2000
timeouts interdigit 3
system message Eu
url directories http://10.1.1.1/localdirectory
url services http://10.1.10.1/voiceview/common/login.do
url authentication http://10.1.10.2/CCMCIP/authenticate.asp
time-zone 30
time-format 24
date-format dd-mm-yy
voicemail 200
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
moh flash:/media/music-on-hold.au
multicast moh 239.10.16.16 port 2000
web admin system name admin secret 5 !!!!!
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 9.T
transfer-pattern .T
secondary-dialtone 9
create cnf-files version-stamp 7960 May 26 2010 17:31:25
NO ONES EXPERT CAN ANSWER HERE?????????
jbillingsley
You must specify the phone type under the ephone configuration. I would suggest setting this, re-creating the cnf files and resetting the ephone. Now you should have the directory.
ephone  1
  mac-address 0011.1111.0000
  type 7941
  button  1:1
-Jake
hi
thank you for your reply
unfortunatelly i have done all the below steps several times with out any success
all the ip phones have ONLY on directories/Missed calls, Received calls , Placed calls
The correct command is
ip http server
ip http path flash:
Hi aokanlawon
Nothing change
Maybe is a bug to this IOS or no?
After entering the command, did you issue the create cnf files command?
Yes of course
Thanks a lot for your patience
My mistake, i thought that i put correct the type but unfortunatelly not
The problem finally was to the wrong type on ephone
Thank you for your time
