phone button label
alessandro.dona
Level 3
Level 3
Hi to all,
any of you knows if it is possible to customize phoene button label?
i'm going to explain better...i confugured the third button of a 7965 to work as a log out hunt group button and i want change the label in something like filter on...
Is it possible and if yes how can change it?
regards,
Ale.
7 Replies 7
Log on to the CCMuser url for that userid and password , choose from the user option -> device then choose the service url
when you choose the selected URL with a button , you can assign a label and ASCII name.
Please try it.
Amer
thx for your early reply.
It is a good idea but not useful because Hunt group logout is not a service with a service url so from ccmuser page i cannot customize it
hello,
then what is the hunt group logout ???
Amer
Hi think it is just a status of DN and it is not managed
by a service url...
No you cannot change the name, they will look the same as if they were softkeys just assigned to a device button.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Dennis Mink
If you use the appropriate softkey template, there is a
button with the description "HLOG" this will let a user log in and out of a huntgroup.
the name cannot be change, so you will have to communicate to your users to use the button that says "HLOG"
Please remember to rate useful posts, by clicking on the stars below.
Thx...probably it is possible by changing hunt_lo
gin.jsp file...
