Phone con logs - no numbers visible
Clutz5250
I'm pretty use to running a cntrl-f and punching in a DN to cut to the chase if im searching for a calling/called number. This newly deployed phone I'm testing with doesn't seem to show the DN in the logs when I search. It is on newer firmware: 14-0-1 (SIP 7841)
Is there some manner of config to enable so this can be generated in con logs?
Thanks!
