06-02-2022 10:22 AM
Hi I saw some threads on here about this same condition but could not find any that refer to Cisco SPA122 VOIP ATA.
Is there some particular setting that could be causing this? It only cuts out when I call out, not when calls come in.
thanks.
06-02-2022 10:52 AM
Very likely a problem that is related to signaling. When a call disconnects at or after 15 minutes that’s the most common issue.
06-04-2022 07:25 AM
on other threads, people say they changed some settings and got it to work however those threads don't related to SPA122 device.
06-04-2022 07:53 AM
I have no first hand experience with that specific model of device, so I can not give you any specific pointers on what to check or change. In general it’s a lack of response to signalling that causes this type of issues.
06-04-2022 09:45 AM
06-06-2022 10:35 AM
hi thanks for your response I cannot find any of these settings;
I saved a screen shot, turned it into a pdf but see no way of posting a pdf here.
06-06-2022 10:00 PM - edited 06-08-2022 11:52 AM
Where are you looking for these settings, on the SPA device or in your firewall? If it is in the device your looking at the wrong place, those are firewall related settings.
On the attachment of files to posts. Underneath the text section you should have this.
That is how you can attach file(s) to your post.
06-08-2022 07:52 AM
yes I attached a laptop to the CICSO SPA122. If Im supposed to look in the firewall, how do I do that? would that be something through the modem? Recently my SP changed my modem but this problem has been occurring under both modems.
06-08-2022 11:51 AM
That is well outside of the topic in the community. It’s your network and you alone would be able to know how it’s setup. That’s not really anything that we in the community can help you with.
06-09-2022 06:38 AM
06-09-2022 07:14 AM
There are no 1 correct setting for a device, it would depend on the service that you're connecting it to. Your service provider should give you the settings that you should use for their service.
06-11-2022 04:41 AM
I understand but the provider no longer supports their system.
The codes that make it unique to their system are intact.
What I'm looking for are generic settings of the CISCO device that may be causing the phone to quit after 15 min. Some sort of timer or similar value. For instance, 15 min = 900 seconds so I was looking for something of that nature but found nothing.
Surely other such devices would have similar settings? Or other CISCO devices on other systems would need to have the same settings, in respect to timing, not proprietary settings like those unique to the Service Provider.
