02-01-2018 05:25 AM - edited 03-17-2019 12:06 PM
Hi All,
Please help me solve this issue.
I have to configure a cisco ISR 4321.
But this routeur is no able to start.
I got this error :
Checking for PCIe device presence...%ERROR: Critical device not found on 00:02.00
%WARNING: Resetting...
Initializing Hardware ..
How can I solve this please ?
Solved! Go to Solution.
02-02-2018 02:30 AM
02-01-2018 08:25 AM
02-01-2018 12:44 PM
02-01-2018 01:22 PM
Hi Leo,
Thanks for replying.
please Find Attached all the boot-up process.
this is all that i have. I have rebooted the router many time but that the same result. the same message is displayed:
Checking for PCIe device presence...%ERROR: Critical device not found on 00:02.00 %WARNING: Resetting... Initializing Hardware ..
02-01-2018 10:23 PM
02-02-2018 02:01 AM
Thanks Leo,
I have readed the shared link and check if my router is affected.
But the verification tool shows "not affected".
Any other idea please?
Zanga
02-02-2018 02:30 AM
07-11-2018 03:57 PM - edited 06-07-2019 09:16 AM
May-June 2019: I Received a shipment of new ISR4321 routers. Some helpful notes listed below:
***2 different Processes worked for me****
1. If the system is caught in a boot loop...this can happen if you use: boot system flash: alk9.03.xxxxxxxxxxxxxxx-ext.SPA.bin (the system cant find the IOS), use (boot system flash bootflash:)alk9.03.xxxxxxxxxxxxxxx-ext.SPA.bin
a. if you are stuck in a boot loop - get to the rommon command to boot from the IOS.
b. rommon >1 boot bootflash:alk9.03.xxxxxxxxxxxxxxx-ext.SPA.bin
***note***5/20/19 - From rommon >1 the 'boot bootflash:command failed - However after I removed the period at the end of bin. (alk9.03.xxxxxxxxxxxxxxx-ext.SPA.bin) the rommon >1 the 'boot bootflash:command worked, I was able to bootup the system.
2. If you uploaded a new or different IOS version to flash: and the system wont boot up to that version and or is caught in a boot loop - tell it to stop booting to IOSv1 and to boot to IOSv2.
**note the verbage on the boot command** boot system flash bootflash:
config t
no boot system flash:alk9.03.xxxxxxxxxxxxxxxIOSv1-ext.SPA.bin
boot system flash bootflash:alk9.03.xxxxxxxxxxxxxxxIOSv2-ext.SPA.bin
end
wr
Verify
a. sh version
c. sh run b | i boot
I just got off the phone with Cisco Tech troubleshooting ISR4321 Boot up problem:
the command: boot system flash bootflash fixes the problem.
router# conf t
router(config)# no boot system
router(config)# boot system flash bootflash:isr4300-universalkxxxxxxxxx-ext.SPA.bin
After this you should be getting this on the running config
boot-start-marker
boot system flash bootflash:isr4300-universalkxxxxxxxxxxxx-ext.SPA.bin
boot-end-marker
If this is what you have just save configuration and reload.
enjoy
07-11-2018 04:00 PM
router# conf t
boot-start-marker
boot-end-marker
enjoy
06-10-2022 03:44 PM
The thing is; the device is just stuck in the loop below;
Initializing Hardware ...
it does not even give a prompt to enter any configurations, if there are any other ways to resolve this please let's know.
06-10-2022 07:17 PM
@ghmpro123, create a new thread (it is free).
In the thread, post the entire bootup process of the router.
