Phone Debug Display
pkentsmith
I've got a Cisco 7940G phone which is playing up so I thought i'd look in the Debug Display log....There's lots in there, but i can't find anywhere on the net which actually tells me what it all means.
Does anyone know of a Cisco (or any) URL which explains the error codes?
For reference, this is what i'm getting: -
2008-12-15 14:03:17.990 Code:8107, P:0, S:0
2008-12-16 08:11:09.360 Code:8103, P:0, S:12300802
2008-12-16 08:35:29.870 Code:8103, P:0, S:12300800
2008-12-17 16:32:31.440 Code:8103, P:0, S:12300800
2008-12-29 08:36:38.480 Code:8103, P:0, S:12300802
TFTP Retry: File SEP00152B67A99A.cnf.xml
2008-12-29 08:41:02.180 Code:8103, P:0, S:12300806
0x57b67:Malloc error for size 32768
2008-12-29 13:12:39.460 Code:306, P:0, S:12300000
Config Task Call Stack:
0009552a
00057b8c
00092044
000a06fc
000789ce
00058e1c
0005e106
0009231c
000a0796
000584b2
2008-12-29 13:16:36.120 Code:8103, P:0, S:12300800
Thanks in advance, and a Happy New Year
Paul
gogasca
Level 10
Level 10
Hi Paul,
Hope you are fine, This is for developer use only and is of no use to a customer or partner. There is no document describing what it means.
What is the problem the IP Phone is experiencing?
I am experiencing the same error messages on a 7940g as well.  Has anyone found out what it means?  The user reports intermittent loss and recovery of sound during phone calls.  We have mls qos configured on the ports and this particular phone is on a 10 meg full duplex grounded outside run.  The switch port appears fine (no errors).
0x5962f:Malloc error for size 32768
0x58e83:Malloc error for size 32768
2010-12-22 18:34:26.340 Code:306, P:0, S:12300000
00096dba
00058ea8
0008a016
0008a562
00089f8e
0008a016
000938b4
000a1fac
00078d5a
0005a14c
0005f422
00093b8c
000a2046
000597cc
Start updating phone firmware to 8.1(2).
We're already there...
MAC Address000A8A5CCAD2Host NameSEP000A8A5CCAD2Phone DN7340App Load IDP00308010200Boot Load IDPC0303010000Version8.1(2.0)DSP4.0(5.0)[A0]Expansion Module 1Expansion Module 2Hardware Revision2.4Serial NumberINM0630B1N6Model NumberCP-7940GCodecADLCodecAmps5V AmpC3PO Revision2
